Текущее время: Пн авг 10, 2026 11:39
Начать новую тему Ответить на тему  [ Сообщений: 3073 ]  На страницу Пред.  1 ... 90, 91, 92, 93, 94, 95, 96 ... 205  След.
СообщениеДобавлено: Ср дек 26, 2012 17:12
prohor754 писал(а):
to T4NZWUT дайте "потрогать" 1.0.15 . если можно на почту : prohor754@mail.ru . Спасибо!
Все вопросы не ко мне, я не могу выкладывать в паблик то, что мне дали в личку.
К тому же сейчас занят проверкой L2TP+Static IP.
СообщениеДобавлено: Ср дек 26, 2012 17:33
На прошивке 1.0.15 тоже рвет подключение
вот логи
g call request [callid 3] has not been accepted.
Dec 26 14:15:59 pptp[843]: Result code is 7 'Not Accepted, Call is administratively prohibited'. Error code is 0, Cause code is 0
Dec 26 14:15:59 pptp[843]: Closing connection (call state)
Dec 26 14:15:59 pptp[844]: IP: 10.9.0.204
Dec 26 14:15:59 pptp[844]: control connection
Dec 26 14:15:59 pptp[844]: unix_sock
Dec 26 14:15:59 pptp[845]: Sent control packet type is 1 'Start-Control-Connection-Request'
Dec 26 14:15:59 pptp[845]: Received Start Control Connection Reply
Dec 26 14:15:59 pptp[845]: Client connection established.
Dec 26 14:16:00 pptp[845]: Sent control packet type is 7 'Outgoing-Call-Request'
Dec 26 14:16:01 pptp[845]: Received Outgoing Call Reply.
Dec 26 14:16:01 pptp[845]: Our outgoing call request [callid 3] has not been accepted.
Dec 26 14:16:01 pptp[845]: Result code is 7 'Not Accepted, Call is administratively prohibited'. Error code is 0, Cause code is 0
Dec 26 14:16:01 pptp[845]: Closing connection (call state)
Dec 26 14:16:01 pptp[846]: IP: 10.9.0.204
Dec 26 14:16:01 pptp[846]: control connection
Dec 26 14:16:01 pptp[846]: unix_sock
Dec 26 14:16:01 pptp[847]: Sent control packet type is 1 'Start-Control-Connection-Request'
Dec 26 14:16:01 pptp[847]: Received Start Control Connection Reply
Dec 26 14:16:01 pptp[847]: Client connection established.
Dec 26 14:16:02 pptp[847]: Sent control packet type is 7 'Outgoing-Call-Request'
Dec 26 14:16:02 pptp[847]: Received Outgoing Call Reply.
Dec 26 14:16:02 pptp[847]: Our outgoing call request [callid 3] has not been accepted.
Dec 26 14:16:02 pptp[847]: Result code is 7 'Not Accepted, Call is administratively prohibited'. Error code is 0, Cause code is 0
Dec 26 14:16:02 pptp[847]: Closing connection (call state)
Dec 26 14:16:02 pptp[848]: IP: 10.9.0.204
Dec 26 14:16:02 pptp[848]: control connection
Dec 26 14:16:02 pptp[848]: unix_sock
Dec 26 14:16:02 pptp[849]: Sent control packet type is 1 'Start-Control-Connection-Request'
Dec 26 14:16:02 pptp[849]: Received Start Control Connection Reply
Dec 26 14:16:02 pptp[849]: Client connection established.
Dec 26 14:16:03 pptp[849]: Sent control packet type is 7 'Outgoing-Call-Request'
Dec 26 14:16:03 pptp[849]: Received Outgoing Call Reply.
Dec 26 14:16:03 pptp[849]: Our outgoing call request [callid 3] has not been accepted.
Dec 26 14:16:03 pptp[849]: Result code is 7 'Not Accepted, Call is administratively prohibited'. Error code is 0, Cause code is 0
Dec 26 14:16:03 pptp[849]: Closing connection (call state)
Dec 26 14:16:03 pptp[850]: IP: 10.9.0.204
Dec 26 14:16:03 pptp[850]: control connection
Dec 26 14:16:03 pptp[850]: unix_sock
Dec 26 14:16:03 pptp[851]: Sent control packet type is 1 'Start-Control-Connection-Request'
Dec 26 14:16:03 pptp[851]: Received Start Control Connection Reply
Dec 26 14:16:03 pptp[851]: Client connection established.
Dec 26 14:16:04 pptp[851]: Sent control packet type is 7 'Outgoing-Call-Request'
Dec 26 14:16:04 pptp[851]: Received Outgoing Call Reply.
Dec 26 14:16:04 pptp[851]: Our outgoing call request [callid 3] has not been accepted.
Dec 26 14:16:04 pptp[851]: Result code is 7 'Not Accepted, Call is administratively prohibited'. Error code is 0, Cause code is 0
Dec 26 14:16:04 pptp[851]: Closing connection (call state)
Dec 26 14:16:04 pptp[852]: IP: 10.9.0.204
Dec 26 14:16:04 pptp[852]: control connection
Dec 26 14:16:04 pptp[852]: unix_sock
Dec 26 14:16:04 pptp[853]: Sent control packet type is 1 'Start-Control-Connection-Request'
Dec 26 14:16:04 pptp[853]: Received Start Control Connection Reply
Dec 26 14:16:04 pptp[853]: Client connection established.
Dec 26 14:16:05 pptp[853]: Sent control packet type is 7 'Outgoing-Call-Request'
Dec 26 14:16:05 pptp[853]: Received Outgoing Call Reply.
Dec 26 14:16:05 pptp[853]: Our outgoing call request [callid 3] has not been accepted.
Dec 26 14:16:05 pptp[853]: Result code is 7 'Not Accepted, Call is administratively prohibited'. Error code is 0, Cause code is 0
Dec 26 14:16:05 pptp[853]: Closing connection (call state)
Dec 26 14:16:05 pptp[854]: IP: 10.9.0.204
Dec 26 14:16:05 pptp[854]: control connection
Dec 26 14:16:05 pptp[854]: unix_sock
Dec 26 14:16:05 pptp[855]: Sent control packet type is 1 'Start-Control-Connection-Request'
Dec 26 14:16:05 pptp[855]: Received Start Control Connection Reply
Dec 26 14:16:05 pptp[855]: Client connection established.
Dec 26 14:16:06 pptp[855]: Sent control packet type is 7 'Outgoing-Call-Request'
Dec 26 14:16:06 pptp[855]: Received Outgoing Call Reply.
Dec 26 14:16:06 pptp[855]: Our outgoing call request [callid 3] has not been accepted.
Dec 26 14:16:06 pptp[855]: Result code is 7 'Not Accepted, Call is administratively prohibited'. Error code is 0, Cause code is 0
Dec 26 14:16:06 pptp[855]: Closing connection (call state)
Dec 26 14:16:06 pptp[856]: IP: 10.9.0.204
Dec 26 14:16:06 pptp[856]: control connection
Dec 26 14:16:06 pptp[856]: unix_sock
Dec 26 14:16:06 pptp[857]: Sent control packet type is 1 'Start-Control-Connection-Request'
Dec 26 14:16:06 pptp[857]: Received Start Control Connection Reply
Dec 26 14:16:06 pptp[857]: Client connection established.
Dec 26 14:16:07 pptp[857]: Sent control packet type is 7 'Outgoing-Call-Request'
Dec 26 14:16:07 pptp[857]: Received Outgoing Call Reply.
Dec 26 14:16:07 pptp[857]: Outgoing call established (call ID 3, peer's call ID 28111).
Dec 26 14:16:07 kernel: pptp_ctf_rcv_classify: *** No such session. call_id=3 saddr=CC00090A
Dec 26 14:16:07 pptp[794]: Using interface ppp0
Dec 26 14:16:07 pptp[794]: Connect: ppp0 <--> pptp (pptp.ufanet.ru)
Dec 26 14:16:07 pptp[794]: Terminating on signal 15
Dec 26 14:16:07 pptp[794]: lcp_close: unit:0, reason: "User request" (status: 5, state: 6, was_ip_down: 0)
Dec 26 14:16:07 pptp[794]: Connection terminated.
Dec 26 14:16:07 pptp[857]: Closing connection (unhandled)
Dec 26 14:16:07 pptp[857]: Sent control packet type is 12 'Call-Clear-Request'
Dec 26 14:16:07 pptp[857]: Closing connection (call state)
Dec 26 14:16:07 pptp[794]: lcp_close: unit:0, reason: "" (status: 5, state: 0, was_ip_down: 0)
Dec 26 14:16:07 pptp[794]: Exit.(5)
Dec 26 14:29:52 resident: getting wan port status
Dec 26 14:29:55 resident: getting wan port status
Dec 26 14:29:58 resident: getting wan port status
Dec 26 14:30:02 resident: getting wan port status
Dec 26 14:30:05 resident: getting wan port status
Dec 26 14:30:08 resident: getting wan port status
Dec 26 14:30:11 resident: getting wan port status
Dec 26 14:30:14 resident: getting wan port status
Dec 26 14:30:21 kernel: COEX: downgraded chanspec 0x2d03 to 0x2b01: channel 2 used by exiting BSSs
Dec 26 14:30:21 kernel: COEX: downgraded chanspec 0x2d06 to 0x2b04: channel 1 used by exiting BSSs
Dec 26 14:30:21 kernel: COEX: downgraded chanspec 0x2d07 to 0x2b05: channel 2 used by exiting BSSs
Dec 26 14:30:33 resident: getting wan port status
Dec 26 14:30:36 resident: getting wan port status
Dec 26 14:30:39 resident: getting wan port status
l: _ctf_pppox_assoc_tunnel: found ipc:[6]-[192.168.0.55]:[63050]-[87.240.155.73]:[80]
СообщениеДобавлено: Ср дек 26, 2012 19:42
мой отзыв о прошивке 1.0.15
прошил, на заводские скинул, настроил заново.
ppoe работает стабильно, все ок. Проброс портов (виртуальные серверы) у меня не заработал вообще :( правила создаются, а порты извне не доступны. Все делал так же как и в 14 прошивке. Один раз в самом начале был доступен почему то интерфейс самого роутера по 80 порту извне (как - я не понял), и все, как отрезало.
через DMZ не пробовал, т.к. это немного не то что мне нужно.
перебесился весь, плюнул и заменил роутер на свой dir-320, на нем проброс портов работает корректно.
а 615 взял домой пытать.
ps: Alexey Vitko - спасибо что дали возможность попробовать прошивку :)
СообщениеДобавлено: Ср дек 26, 2012 20:43
Тоже щас исплевался немного, попробовал впервые 1.0.5 без сброса настроек с 1.0.15 - заработало, одни косяки пропали - другие появились, залил 1.0.14 настроил с нуля, сравнил с 15-ой, в итоге достал двух-трёх годовалый запылившийся 615-ый ревизии E4, в нём не работал routing - не было выбора интерфейса WAN (пустой выбор), не все прошивки помогали - то на одной с VPN проблемы, то на другой с роутингом, приходилось вручную инет отключать/подключать для доступа к локальным ресурсам провайдера, а тут от делать нечего обновил с 5.10RU на DIR615E4_FW511RUB05beta01, стал возможен выбор интерфейса WAN/WAN(Phisical Port), настроил - маршруты, DMZ и как заработало да понеслось :!: :!: :!:
В общем решил К1 настроить и сестре малой отдать, ей для планшета, телефона и стационарного вполне хватит... :wink: Может через год К1 заберу обратно, когда стабильные прошивки будут :mrgreen:
СообщениеДобавлено: Чт дек 27, 2012 09:45
Прошивка 1.0.15, полет нормальный, но порты не тестил.
СообщениеДобавлено: Чт дек 27, 2012 10:00
извините, но наверно стоит поподробнее писать - как оно у вас включено и зачем?
а то может просто как свитч на 4 порта стоит и работает :)
СообщениеДобавлено: Чт дек 27, 2012 12:07
T4NZWUT, спасибо за развернутый ответ. Я проверю выявленные недостатки.
Полезные настройки
СообщениеДобавлено: Чт дек 27, 2012 12:43
Видимо, придется выбирать другой маршрутизатор, раз у меня не получается решить проблему с видимостью dlna через wifi.
СообщениеДобавлено: Чт дек 27, 2012 12:48
еще вспомнил - в виртуальных серверах есть выбор для какого интерфейса выполнять (поле Интерфейс), так в нем в 15-й добавилась опция "Все", раньше такого не было. И при смене на конкретный wan который настроен, сохранении и следующем входе в эти настройки - все равно отображается "Все", т.е. не запоминается выбор интерфейса
СообщениеДобавлено: Чт дек 27, 2012 17:05
Народ поделитесь прошивкой 1.0.15 попробовать, а то ни как не получается FlylinkDC заставить нормально работать. ( rev_vadim@mail.ru )
СообщениеДобавлено: Пт дек 28, 2012 06:32
Погонял версию 1.0.15 , DC клиент и торрент полет нормальный, через wi-fi пока не чего не прогонял, на праздниках попробую.
СообщениеДобавлено: Пт дек 28, 2012 09:17
Последний раз редактировалось Elavik Пт дек 28, 2012 09:28, всего редактировалось 1 раз.
СообщениеДобавлено: Пт дек 28, 2012 09:24
Elavik писал(а):
поделитесь прошивкой 1.0.15 Elavik@olympus.ru
:) скинул
СообщениеДобавлено: Пт дек 28, 2012 09:27
Alexey, тоже попробовал.15 прошивку. Рассказать в общем то неочем. Та же проблема - большой пинг при подключении провода inetrnet.
Мои действия: Прошивка 15 релиза.
Сброс, програмный и аппаратный (на всякий случай)
Настройка ppoe
Настройка wi-fi
Подключение с бука.
ping 1ms.
Но стоит воткнуть кабель wan - все. Ping возрастает до 300-3000 ms. В интерфейс не попасть. Короче: finita la comedia.
Что интересно - стоит кабель убрать - все встает на свои места (1-3 ms).
Короче - убрал я этот маршрутизатор до лучших времен. Достал.
Только что то этих проблем у других я не наблюдаю. Может мой аппарат глючный попался...
P.S. Провайдер tis-dialog (Калининград)
СообщениеДобавлено: Пт дек 28, 2012 09:29
striker78
Спасибо
