Текущее время: Вс июн 21, 2026 21:26
СообщениеДобавлено: Вт июн 07, 2005 10:18
3.00-B01 для DGS-3212SR и 4.02-B26 для DES-3226S
СообщениеДобавлено: Чт июн 09, 2005 12:20
поставил рекомендованые прошивки.. проблема осталас с Vlan
DGS-3212SR:4#sh sw
Command: show switch
Device Type : DGS-3212SR Gigabit-Ethernet Switch
Module 1 Type : DEM-540 4-port stacking module
Module 2 Type : Empty
Unit ID : 15
MAC Address : 00-0D-88-55-B3-C2
IP Address : 192.168.10.5 (Manual)
VLAN Name : default
Subnet Mask : 255.255.255.0
Default Gateway : 0.0.0.0
Boot PROM Version : Build 2.00.001
Firmware Version : Build 3.00-B01
Hardware Version : 3A1
Device S/N :
System Name :
System Location :
System Contact :
Spanning Tree : Disabled
GVRP : Disabled
IGMP Snooping : Disabled
TELNET : Enabled (TCP 23)
WEB : Enabled (TCP 80)
RMON : Disabled
DGS-3212SR:4#sh vlan
Command: show vlan
VID : 1 VLAN Name : default
VLAN TYPE : static Advertisement : Enabled
Member ports : 15:1-15:12,6:1-6:26,7:1-7:26
Static ports : 15:1-15:4,15:9-15:12,6:1-6:25,7:1-7:25
Current Untagged ports : 15:1-15:4,15:9-15:12,6:1-6:25,7:1-7:25
Static Untagged ports : 15:1-15:4,15:9-15:12,6:1-6:25,7:1-7:25
Forbidden ports :
VID : 4094 VLAN Name : Buh
VLAN TYPE : static Advertisement : Disabled
Member ports : 15:5-15:8,6:26,7:26
Static ports :
Forbidden ports :
Total Entries : 2
DGS-3212SR:4#sh sta
Command: show stacking
ID MAC Address Port Range Mode Version RPS Status Model Name
*15 00-0D-88-55-B3-C2 1 - 12 MASTER 3.00-B01 Not Present DGS-3212SR
6 00-0F-3D-CA-E6-93 301 - 326 AUTO 4.02-B26 Not Support DES-3226S
7 00-0F-3D-CA-E5-F3 351 - 376 AUTO 4.02-B26 Not Support DES-3226S
Total Entries :3
DGS-3212SR:4#sh ipif
Command: show ipif
IP Interface Settings
Interface Name : System
IP Address : 192.168.10.5 (MANUAL)
VLAN Name : default
Admin. State : Enabled
Link Status : Link UP
Member Ports : 15:1-15:12,6:1-6:26,7:1-7:26
Total Entries : 1
DGS-3212SR:4#sh router_ports
Command: show router_ports
VLAN Name : default
Static router port :
Dynamic router port :
VLAN Name : Buh
Total Entries: 2
DGS-3212SR:4#delete vlan Buh
Command: delete vlan Buh
This VLAN is used by routing interface, it cannot be removed.
VLAN Name : default
VLAN Name : Buh
Total Entries: 2
DGS-3212SR:4#config router_ports Buh delete 15:5-15:8,6:26,7:26
Command: config router_ports Buh delete 15:5-15:8,6:26,7:26
Fail!
Vlan пропадает только после перезагрузки свитча
Как грится куда смотреть?!
Ожидается ли в ближайшем будующем прошивка для DGS-3212SR с поддержкой Asymetric Vlan ????
СообщениеДобавлено: Чт июн 09, 2005 12:25
Подскажите в приведенной ниже конфигурации
DGS-3212SR:4#sh sta
Total Entries :3
Forbidden ports :
Задача изолировать группу 7:1-7:8 , разрешить ей доступ ТОЛЬКО к портам 15:1-15:4 (минимум на сервер 15:1 )
Это можно сделать ТОЛЬКО установив в сервер в сетевые карты и заняв еще 15:2 скажем? Или как-то все же можно решить, если сетевая карта не поддерживает теги
СообщениеДобавлено: Чт июн 09, 2005 12:27
Довольно странная у вас ситуация... Для DGS-3212SR вообще не ожидается прошивки с Assymetric VLAN
СообщениеДобавлено: Чт июн 09, 2005 14:22
Странная с изоляцией?
Есть контролер домена. Есть разные пользователи.
Есть бухгалтерия, ее надо от всех оградить, к контролеру доступ, естественно нужен, да и админу не помешал бы..
Дык что с решением????? Ставить две сетевые карты ?? Все?
СообщениеДобавлено: Чт июн 09, 2005 17:04
Я имел в виду странно, что не удаляется
Лучший вариант приобрести сетевой адаптер с поддержкой тегов!
СообщениеДобавлено: Чт июн 23, 2005 11:34
Модератор
Модератор
VLAN Name : default
VLAN Name : Buh
Total Entries: 2
Fail!
Как можно сделать "config router_ports Buh delete 15:5-15:8,6:26,7:26", если перед этим "sh router_ports" показал, что там пусто??
Попробуйте сперва удалить порты из vlan через "config vlan Buh delete". Либо все сразу, либо по очереди, быстро найдете порт, который не дает глобально удалить всё.
