Текущее время: Пт окт 09, 2026 22:06
СообщениеДобавлено: Вт июн 07, 2005 10:18
3.00-B01 для DGS-3212SR и 4.02-B26 для DES-3226S
СообщениеДобавлено: Чт июн 09, 2005 12:20
поставил рекомендованые прошивки.. проблема осталас с Vlan
DGS-3212SR:4#sh sw
Command: show switch
Device Type : DGS-3212SR Gigabit-Ethernet Switch
Module 1 Type : DEM-540 4-port stacking module
Module 2 Type : Empty
Unit ID : 15
MAC Address : 00-0D-88-55-B3-C2
IP Address : 192.168.10.5 (Manual)
VLAN Name : default
Subnet Mask : 255.255.255.0
Default Gateway : 0.0.0.0
Boot PROM Version : Build 2.00.001
Firmware Version : Build 3.00-B01
Hardware Version : 3A1
Device S/N :
System Name :
System Location :
System Contact :
Spanning Tree : Disabled
GVRP : Disabled
IGMP Snooping : Disabled
TELNET : Enabled (TCP 23)
WEB : Enabled (TCP 80)
RMON : Disabled
DGS-3212SR:4#sh vlan
Command: show vlan
VID : 1 VLAN Name : default
VLAN TYPE : static Advertisement : Enabled
Member ports : 15:1-15:12,6:1-6:26,7:1-7:26
Static ports : 15:1-15:4,15:9-15:12,6:1-6:25,7:1-7:25
Current Untagged ports : 15:1-15:4,15:9-15:12,6:1-6:25,7:1-7:25
Static Untagged ports : 15:1-15:4,15:9-15:12,6:1-6:25,7:1-7:25
Forbidden ports :
VID : 4094 VLAN Name : Buh
VLAN TYPE : static Advertisement : Disabled
Member ports : 15:5-15:8,6:26,7:26
Static ports :
Forbidden ports :
Total Entries : 2
DGS-3212SR:4#sh sta
Command: show stacking
ID MAC Address Port Range Mode Version RPS Status Model Name
*15 00-0D-88-55-B3-C2 1 - 12 MASTER 3.00-B01 Not Present DGS-3212SR
6 00-0F-3D-CA-E6-93 301 - 326 AUTO 4.02-B26 Not Support DES-3226S
7 00-0F-3D-CA-E5-F3 351 - 376 AUTO 4.02-B26 Not Support DES-3226S
Total Entries :3
DGS-3212SR:4#sh ipif
Command: show ipif
IP Interface Settings
Interface Name : System
IP Address : 192.168.10.5 (MANUAL)
VLAN Name : default
Admin. State : Enabled
Link Status : Link UP
Member Ports : 15:1-15:12,6:1-6:26,7:1-7:26
Total Entries : 1
DGS-3212SR:4#sh router_ports
Command: show router_ports
VLAN Name : default
Static router port :
Dynamic router port :
VLAN Name : Buh
Total Entries: 2
DGS-3212SR:4#delete vlan Buh
Command: delete vlan Buh
This VLAN is used by routing interface, it cannot be removed.
VLAN Name : default
VLAN Name : Buh
Total Entries: 2
DGS-3212SR:4#config router_ports Buh delete 15:5-15:8,6:26,7:26
Command: config router_ports Buh delete 15:5-15:8,6:26,7:26
Fail!
Vlan пропадает только после перезагрузки свитча
Как грится куда смотреть?!
Ожидается ли в ближайшем будующем прошивка для DGS-3212SR с поддержкой Asymetric Vlan ????
СообщениеДобавлено: Чт июн 09, 2005 12:25
Подскажите в приведенной ниже конфигурации
DGS-3212SR:4#sh sta
Total Entries :3
Forbidden ports :
Задача изолировать группу 7:1-7:8 , разрешить ей доступ ТОЛЬКО к портам 15:1-15:4 (минимум на сервер 15:1 )
Это можно сделать ТОЛЬКО установив в сервер в сетевые карты и заняв еще 15:2 скажем? Или как-то все же можно решить, если сетевая карта не поддерживает теги
СообщениеДобавлено: Чт июн 09, 2005 12:27
Довольно странная у вас ситуация... Для DGS-3212SR вообще не ожидается прошивки с Assymetric VLAN
СообщениеДобавлено: Чт июн 09, 2005 14:22
Странная с изоляцией?
Есть контролер домена. Есть разные пользователи.
Есть бухгалтерия, ее надо от всех оградить, к контролеру доступ, естественно нужен, да и админу не помешал бы..
Дык что с решением????? Ставить две сетевые карты ?? Все?
СообщениеДобавлено: Чт июн 09, 2005 17:04
Я имел в виду странно, что не удаляется
Лучший вариант приобрести сетевой адаптер с поддержкой тегов!
СообщениеДобавлено: Чт июн 23, 2005 11:34
Модератор
Модератор
VLAN Name : default
VLAN Name : Buh
Total Entries: 2
Fail!
Как можно сделать "config router_ports Buh delete 15:5-15:8,6:26,7:26", если перед этим "sh router_ports" показал, что там пусто??
Попробуйте сперва удалить порты из vlan через "config vlan Buh delete". Либо все сразу, либо по очереди, быстро найдете порт, который не дает глобально удалить всё.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 48
