Текущее время: Сб авг 08, 2026 23:11
Начать новую тему Ответить на тему  [ Сообщений: 23 ]  На страницу 1, 2  След.
СообщениеДобавлено: Сб мар 28, 2009 19:21
К коммутатору подключено 2 порта.
Один к Л2 коммутаторам и около 1000 онлайн компьютеров.
Другой - к подсетке серверов.
Поднято 5 IP:
interface VLAN 4040
ip address x.y.0.3 255.255.255.240
interface VLAN 4043
ip address 10.x.y.1 255.255.240.0
ip address 192.168.0.1 255.255.240.0 secondary
ip address 192.168.40.254 255.255.240.0 secondary
ip address 192.168.64.254 255.255.240.0 secondary
ip route 0.0.0.0 0.0.0.0 x.y.0.2
sh cpu
CPU utilization in five seconds: 93%
CPU utilization in one minute : 91%
CPU utilization in five minutes: 93%
sh cpu mboard
Type Pps Total Drop
tp-guard 0 0 0
arp 128 584631695 1288475
dot1x 0 0 0
rldp 0 0 0
rerp 0 0 0
bpdu 0 1222372 0
dhcps 0 0 0
gvrp 0 0 0
ipv6mc 0 0 0
dvmrp 0 0 0
igmp 0 0 0
ospf 0 0 0
pim 0 0 0
rip 0 0 0
vrrp 0 0 0
unknown-ipmc 0 0 0
err-ttl 0 59026514 599
dhcp-relay-s 0 0 0
dhcp-relay-c 0 0 0
option82 0 0 0
udp-helper 0 0 0
sh mac count
Dynamic Address Count : 859
Static Address Count : 0
Filtering Address Count: 0
Total Mac Addresses : 859
Total Mac Address Space Available: 15525
sh arp
Total Numbers of Arp: 1032
Загрузка смешная
sh int gi0/19
Index(dec):19 (hex):13
GigabitEthernet 0/19 is UP , line protocol is UP
Hardware is Broadcom 5464 GigabitEthernet
Interface address is: no ip address
MTU 1500 bytes, BW 1000000 Kbit
Encapsulation protocol is Bridge, loopback not set
Keepalive interval is 10 sec , set
Carrier delay is 2 sec
RXload is 29 ,Txload is 51
Queueing strategy: WFQ
Switchport attributes:
interface's description:""
medium-type is copper
lastchange time:85 Day:20 Hour:50 Minute:49 Second
Priority is 0
admin duplex mode is AUTO, oper duplex is Full
admin speed is AUTO, oper speed is 1000M
flow control admin status is OFF,flow control oper status is OFF
broadcast Storm Control is OFF,multicast Storm Control is OFF,unicast Storm Control is OFF
5 minutes input rate 115031008 bits/sec, 24439 packets/sec
5 minutes output rate 203496056 bits/sec, 26843 packets/sec
174571916166 packets input, 125111144616146 bytes, 0 no buffer, 0 dropped
Received 166455 broadcasts, 91227625422 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 abort
176117444151 packets output, 126636296986151 bytes, 0 underruns , 1111 dropped
0 output errors, 0 collisions, 0 interface resets
DGS-3610#sh int gi0/18
Index(dec):18 (hex):12
GigabitEthernet 0/18 is UP , line protocol is UP
RXload is 41 ,Txload is 18
lastchange time:85 Day:22 Hour:44 Minute:13 Second
Priority is 0
5 minutes input rate 162552320 bits/sec, 17539 packets/sec
5 minutes output rate 72474852 bits/sec, 14037 packets/sec
35620099367 packets input, 30644807037604 bytes, 0 no buffer, 369 dropped
Received 86994466 broadcasts, 10414711151 runts, 2 giants
3 input errors, 1 CRC, 0 frame, 0 overrun, 0 abort
29719318843 packets output, 22781772783359 bytes, 0 underruns , 6941 dropped
Наблюдается потеря пакетов(как при пинге самого коммутатора так и компов за ним)
200 packets transmitted, 194 packets received, 3.0% packet loss
round-trip min/avg/max/stddev = 0.580/0.681/0.888/0.054 ms
Не ужели данному коммутатору 100-200 arp пакетов предел по производительности?
СообщениеДобавлено: Вс мар 29, 2009 10:29
Такая загрузка для него абсолютно не критична. Покажите пожалуйста sh log, возможно какая-то атака. Кстати мультикаст присутвует в сети?
СообщениеДобавлено: Вс мар 29, 2009 19:52
В логе за посление сутки нет ни одной записи(до этого записи о конфигурирования его мной).
Меня бы не волновала загрузка, если бы не было потери пакетов.
500 packets transmitted, 482 packets received, 3.6% packet loss
round-trip min/avg/max/stddev = 1.337/2.237/15.558/1.751 ms
СообщениеДобавлено: Пн мар 30, 2009 16:56
Пришлите пожалуйста конфиг мне на почту. Спасибо
СообщениеДобавлено: Вт сен 29, 2009 22:48
тоже самое
СообщениеДобавлено: Вт сен 29, 2009 22:55
Версия прошивки? И пришлите пожалуйста Ваш конфиг.
СообщениеДобавлено: Пт окт 02, 2009 00:57
тоже самое, только без потерь
загрузка 92-93
СообщениеДобавлено: Пт окт 02, 2009 17:36
уважаемая техподдержка
может быть ответите что-нибудь или как
берешь железки по 120к и ни ответа ни привета?
тут тоже viewtopic.php?t=32914
из 2-х этих топиков кроме неопределенности ничего нет
прошивка та же, что и при покупке, она же единственная на фтп
СообщениеДобавлено: Сб окт 03, 2009 00:15
Запросите последнюю версию ПО в специально предназначенном для этого топике и обновитесь. Если вы после покупки ничего не делали - у вас стоит старье.
LiveComm
СообщениеДобавлено: Сб окт 03, 2009 19:09
Где этот топик,
если этот viewtopic.php?t=43200 то тут нет упоминания про 3610, да и вообще 36хх это не тоже самое, что и 3610
на фтп лежит одна единственная прошивка, та же, что и в коммутаторе
вообще не понимаю подобное игнорирование техподдержки
нет ответа или решения, так и написали бы хоть, данная железка более не поддерживается
я понимаю, что вопросы не особо критичны, тем более, что ее функционал очень устраивает, интерфейс cisco-like просто песня, но все таки если через железку крутятся 4.5 тыс. клиентов, хотелось бы быть уверенным, что она не начнет загибаться через какое-то время, учитывая круглосуточный показатель cpu в 93%, причем не скачет, а просто ровным столбом стоит ... очень напрягает
СообщениеДобавлено: Сб окт 03, 2009 20:31
Во-первых никто Вас не игнорировал. Ещё раз подчеркну что форум это не место моментального реагирования на проблемы. Если нужно оперативнее то пишите в почту. Во-вторых Вам в понедельник ответит Станислав Козлов.
Последний раз редактировалось Demin Ivan Сб окт 03, 2009 20:32, всего редактировалось 1 раз.
СообщениеДобавлено: Сб окт 03, 2009 20:32
"Запрос прошивок и snmp howto для коммутаторов D-Link" называется.
LiveComm
СообщениеДобавлено: Сб окт 03, 2009 20:59
понял. спасибо
сначала проблема обсуждается, а потом прошивка просится, зачем мне кот в мешке
СообщениеДобавлено: Сб окт 03, 2009 22:22
cначала меняется прошивка, потом на ней тестируется проблема, потом обращаются за помощью.
не кот в мешке, а у вас прошивка хреновая. или слово "хреновая" вы не понимаете ??? уже вышли десятки build'ов с исправлениями всевозможных глюков. а вы вместо дела тут в споры ещё вступаете.
LiveComm
СообщениеДобавлено: Сб окт 03, 2009 22:48
я обращался к техподдержке, вы сотрудник техподдержки?
у вас свои понятия по тестированию проблемы у меня свои
не нужно воздух сотрясать
прошивка нормальная, пока жить не мешает
