Path of Exile keepers of the flame, 3.27, is more of an old spark to those who are a league starter, the Arc hierophant build. This combination incorporates the easy gratification of chain lightning with the durability of Hierophant due to its mana, which makes it pleasurable and reachable to both the players with high skill and low skill level. It is made to get you through the early plot of the map to the later parts with minimal resistance, and cause damage reliably, but provide sufficient defenses to protect your life
PoE 1 Currency. The Arc with its natural crowd control and the Hierophant with its mana sustain makes it a very relaxing and powerful game, which scales well as you upgrade your equipment.
The centre of the construction is Arc itself, which is a lightning spell that ricoches off one enemy to another, destroying parties with little effort. The ability of the skill to chain between targets automatically provides the skill with efficient clearing without necessarily having to aim continuously or reposition. This convenience is complemented well by the strengths of the Hierophant, which is aimed at increasing your mana pool and transforming it into offensive and defensive capabilities. With a relatively simple starting equipment, the build can provide consistent damage, and it is due to a blend of spell power and resource control that will keep you casting uninterrupted.
When it comes to Arc Hierophant, it is easy to be honest with her. At the early stages, one can associate Arc with Elemental Focus and Controlled Destruction to maintain its base power at a high level, and you collect passive nodes that enhance mana production and productivity. You may count upon spells such as Freezing Pulse or Crackling Lance before you come to grips with Arc, to help you bridge the initial shortfalls until your lightning arrangement is established. The early acquisition of Mind over Matter and the bonuses of the Hierophant that come later in the leveling process is a good defensive boost which allows you to remain in the combat longer and concentrate on cleaning rather than evading. Cheap wands, scepters, and shields which have the effects of higher spell damage or mana bonuses render gearing easy and reachable as you proceed through the acts.
As soon as you pass the midgame, the building starts glowing. The arc scales very well with mana, and with the gear that facilitates this mechanic (the scaling of Archmage in particular) the damage can climb very quickly. Large pools of mana that the Hierophant can sustain with a consistent regeneration rate provide you with the stamina to have a longer map or thicker battles. The game loop is made very generous and flowing: Arc between packages, mana is obtained automatically, and pass between fights easily. The offense-sustain ratio is stable even in more challenging regions, which enables you to concentrate on productive farming and does not make you too concerned about the sudden spikes of incoming damages.
Arc Hierophant in the endgames has strength and flexibility. Using finer equipment and access to important ascendancy nodes, the build can receive additional survivability and utility in the form of totems or auras which invest in its defenses. Arcane Surge will continue to be a staple, providing them with the ability to restore their mana and to deal more damage on spells, with optional totem configurations being able to give them the ability to absorb aggro or to add a little more pressure to the bosses. Easy to modify to suit your needs late-game version of this build - you can either go with a greater density of projectiles to clear maps faster, or lean more towards support gems that are more defensive to outlast difficult bosses. This flexibility provides Arc Hierophant with the ability to remain relevant well beyond the time that the initial acts are in place.
Rhythm is one of the best features of the build in practical play. The broad distance of Arc allows one to empty rooms before the foes are able to draw near, and the constant recharge ability allows the Hierophant to spend minimal time resting on flasks or making the necessary transposition every minute. It is a fluid experience that makes you chain maps effectively without having to hurry. The Arc Hierophant also offers a solid base to those players who like experimenting, allowing the introduction of new support combinations, or the possibility of adding chaos or elemental gear modifiers. It has been designed in such a way that it can be carefully tuned with time and does not need to upgrade in a spurt, to one big expense and as a result is suited to both the casual and the dedicated players who would like to be assured of consistency across the league.
The Arc Hierophant is successfully played by balancing mana, survivability and damage scaling. The items that should be given priority are those that have mana regeneration, maximum mana and those that have more spell damage so that you do not run out of mana in long battles. Capping resistances and having rather modest defensive levels are a long way to survive the maps of high level. The further you enter the endgame, the more important parts of Arc, such as amulets, rings, and weapons, you upgrade to add additional base power and sustain your mana engine
Divine poe 1. The ability to be forgiving in the build turns it into a great place to start in Path of Exile 3.27 that provides an easy route to stability, high-quality clearing, and consistent advancement on the first day of the league.
