Текущее время: Ср апр 15, 2026 02:44
 Заголовок сообщения: где ошибка в настройке DAS-3216
СообщениеДобавлено: Чт янв 12, 2006 15:57
Железо
System name: DAS-3216
Contact:
Console name: IPDSLAM
1.Hardware version: A1
2.Software version: 1.05
3.Serial number: 00-11-95-10-fb-e5
4.Description: D-Link DAS-3216 ADSL IP DSLAM
5.Temperature: Normal
настройки
[system]
  name DAS-3216
  location
  contact
  description D-Link DAS-3216 ADSL IP DSLAM
  iana_name 1.3.6.1.4.1.171
  cli_prompt IPDSLAM
  portfilter disable
[snmp]
  ipconfig 192.168.2.35 255.255.255.192 192.168.2.40
  community public public
[chassis]
[port]
  line 1/2  adsl disable disable enable
  line 1/3  adsl disable disable enable
  line 1/4  adsl disable disable enable
  line 1/5  adsl disable disable enable
  line 1/6  adsl disable disable enable
  line 1/7  adsl disable disable enable
  line 1/8  adsl disable disable enable
  line 1/9  adsl disable disable enable
  line 1/10 adsl disable disable enable
  line 1/11 adsl disable disable enable
  line 1/12 adsl disable disable enable
  line 1/13 adsl disable disable enable
  line 1/14 adsl disable disable enable
  line 1/15 adsl disable disable enable
  line 1/16 adsl disable disable enable
[adsl_config_profile]
  profile 1024-512
    atu-c adaptAtStartup interleaved 6 1024 1024 16
    atu-r adaptAtStartup interleaved 6 512 512 16
  profile 128-64
    atu-c adaptAtStartup interleaved 6 128 128 16
    atu-r adaptAtStartup interleaved 6 64 64 16
  profile 256-128
    atu-c adaptAtStartup interleaved 6 256 256 16
    atu-r adaptAtStartup interleaved 6 128 128 16
  profile 512-256
    atu-c adaptAtStartup interleaved 6 32 512 16
    atu-r adaptAtStartup interleaved 6 32 256 16
  profile DEFAULT
    atu-c adaptAtStartup interleaved 6 32 8064 16
    atu-r adaptAtStartup interleaved 6 32 1024 16
[adsl_alarm_profile]
  profile DEFAULT
    atu-c 0 0 0 0 0 disable
    atu-r 0 0 0 0
[vcc2vlan]
  line 1/1  up 8/81 0  7 7 8192 8192 b
  line 1/2  up 0/35 0  7 7 8192 8192 b
  line 1/3  up 0/35 0  7 7 8192 8192 b
  line 1/4  up 0/35 0  7 7 8192 8192 b
  line 1/5  up 0/35 0  7 7 8192 8192 b
  line 1/6  up 0/35 0  7 7 8192 8192 b
  line 1/7  up 0/35 0  7 7 8192 8192 b
  line 1/8  up 0/35 0  7 7 8192 8192 b
  line 1/9  up 0/35 0  7 7 8192 8192 b
  line 1/10 up 0/35 0  7 7 8192 8192 b
  line 1/11 up 0/35 0  7 7 8192 8192 b
  line 1/12 up 0/35 0  7 7 8192 8192 b
  line 1/13 up 0/35 0  7 7 8192 8192 b
  line 1/14 up 0/35 0  7 7 8192 8192 b
  line 1/15 up 0/35 0  7 7 8192 8192 b
  line 1/16 down 0/35 0  7 7 8192 8192 b
[adsl_line]
  line 1/1  512-256 DEFAULT
[igmp]
  chassis 1 Disable Sparse Disable 250 Disable
[sntp]
  config disable
  timezone UTC
[route_cfg]
клиентская часть Zyxel Prestige 600
настроен в режиме bridge
Собственно проблема
1. Долго "подымается" линк, хотя линия всего 5 метров (для тестирования)
2. После "поднятия" линка не идёт пинг с/на клиентскую машину.
Что я неправильно сделал?
у меня растёт IQ, скоро 18!
СообщениеДобавлено: Пт янв 13, 2006 10:49
кто нить ответит?
 Заголовок сообщения: Re: где ошибка в настройке DAS-3216
СообщениеДобавлено: Пт сен 27, 2024 07:19
у меня также была проблема с настройкой DAS-3216. Вы нашли решение проблемы? iq test free
