Текущее время: Ср сен 23, 2026 13:46
СообщениеДобавлено: Пн мар 29, 2021 17:28
Имею проблему с одим из экземпляров , на прошивках второй ветки (DGS36xxRun_2.52-B45) никаких проблем у коммутатора нет.
Заливаю FW из третьей ветки и имею такое :
Boot Procedure 1.10-B09
Power On Self Test ...................................... 100 %
MAC Address : 00-22-B0-35-1B-00
H/W Version : A1
Please wait, loading V3.03.B04 Runtime image ............ 100 %
UART init ............................................... 100 %
Device Discovery ........................................ -
OS_Fatal_Error_Handler :
errormsg =
SSL Semaphore fail!!
Current Stack Pointer = 620965C
!! System in EXCEPTION MODE !!!
Prom: 1.10-B09, Runtime: 3.03.B04
PAUSE System Exception:
Pause source code : 1
Current Task: ST_Tic
Current Stack Pointer : 0620964C
0620964C : 0620965C 00020938 0620965C 010C47FC
0620965C : 062096EC 0000D198 010C47FC 00000000
0620966C : 00000000 0000004D 0620970C 00000134
0620967C : 00000000 00000000 0100008C 062096F4
0620968C : 06209664 0A0D0D20 53534C20 53656D61
0620969C : 70686F72 65206661 696C2121 0A0D0000
062096AC : 00000000 04BD8C34 04BD8C40 04BD8C40
062096BC : 062096D4 00025B84 062096DC 04BD8C34
062096CC : 00000015 04BD8C34 062096F4 0000DF20
062096DC : 062096EC 00000000 00000015 00000002
062096EC : 062096F4 010C3FE0 06209704 010C4730
062096FC : 00000015 00000002 06209714 002043C0
0620970C : 06209714 0000EEF4 0620972C 003021F4
0620971C : 0620972C 00000000 00000000 00000002
0620972C : 0620973C 00301F48 00000002 00000001
0620973C : 0620975C 0031CC5C 0620975C 061EEF14
0620974C : 0620976C 00000000 00000000 00000000
0620975C : 06209764 0031D518 0620976C 002F9508
0620976C : 06209784 003131C0 00000001 00000000
0620977C : 00000000 00000000 0620978C 000254F8
0620978C : A5A5A5A5 00000000 A5A5A5A5 A5A5A5A5
0620979C : 454E424B 000001D3 00008019 0000F5E0
062097AC : 00000205 017F0CC0 A5A5A5A5 A5A5A5A5
062097BC : A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
062097CC : A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
062097DC : A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
062097EC : A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
062097FC : A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
0620980C : A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
0620981C : A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
0620982C : A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
0620983C : A5A5A5A5 A5A5A5A5 A5A5A5A5 A5A5A5A5
The relation of function calling:
000254F8
003131C0
002F9508
0031D518
0031CC5C
00301F48
003021F4
002043C0
010C4730
010C3FE0
0000D198
00020938
TCD_Interrupt_Level=00000000 Interrrupt Disabled
TCD_Current_Thread=058E9D8C Thread name=ST_Tic
TCD_Execute_Task=058E9D8C Current Task=ST_Tic
TCD_Execute_HISR=00000000
TCD_System_Stack=04BB811C
Подскажите, куда покопать ?
СообщениеДобавлено: Ср мар 31, 2021 11:20
Последняя версия ПО на данное устройство 3.04.В01. Загрузить можно по ссылке - https://cloud.dlink.ru/owcl/index.php/s/8fTEuujt4kpNvod
Какие версии пытались загружать вы?
Каким образом подключены к коммутатору?
Какой командой выполняете обновление?
СообщениеДобавлено: Чт апр 01, 2021 00:06
Загружаю через Z- модем версию DGS36xxRun_2.52-B45.had - все работает .
Эта DGS36xxRun_3.03-B04.had и эта DGS36xx_Run_3_00_B48.had - уже нет .
Коммандой Apply в BOOT CONFIGURATION MENU.
Масса других экземпляров обновилась без проблем .
СообщениеДобавлено: Чт апр 01, 2021 09:30
а ченджлог есть где почитать?
СообщениеДобавлено: Чт апр 01, 2021 10:09
DGS-3600 R3.04:
1. Added the function "ip pim bsr-border".
config pim ipif <ipif_name 12> bsr_border [enable | disable]
2. Added log messages when uploading/downloading configuration/firmware/log file via SNMP.
3. Support Radius option of NAS-IP-Address
СообщениеДобавлено: Чт апр 01, 2021 10:15
нет возможности попробовать обновиться через TFTP?
СообщениеДобавлено: Чт апр 01, 2021 15:33
download firmware_fromTFTP хх.хх.хх.хх src_file DGS36xx_Run_3_00_B48.had
Так пробовал - результат одинаков.
СообщениеДобавлено: Ср янв 15, 2025 11:52
Подскажите, пожалуйста, если последняя версия ПО 3.04.В01, тогда почему в теме про прошивки указана 3.03.B04?
Дело в том, что я столкнулся с аналогичной ситуацией на DGS-3627 (ревизия A1): коммутатор не загружается, получаю System in EXCEPTION MODE.
Device Type       : DGS-3627 Gigabit Ethernet Switch
MAC Address       : 00-1E-58-5E-B0-00
IP Address        : 10.90.90.90 (Manual)
VLAN Name         : default
Subnet Mask       : 255.0.0.0
Default Gateway   : 0.0.0.0
Boot PROM Version : Build 1.10-B09
Firmware Version  : Build 3.00.B48
Hardware Version  : A1
Serial Number     : P40Z183000008
Загружал файлы прошивки из разных источников, сравнивал файлы — одинаковые:
Загружал в коммутатор и штатно через TFTP (команда: download firmware_fromTFTP 10.90.90.3 src_file DGS36xxRun_3.03-B0
4.had), и через zmodem — результат одинаковый. Версия 3.03.B03 работает исправно, получается, это последняя публичная рабочая версия.
Сейчас этот форум просматривают: Bing [Bot] и гости: 18
