Текущее время: Ср апр 22, 2026 17:56
 Заголовок сообщения: Грабли с DSL-1500G
СообщениеДобавлено: Вт дек 27, 2005 10:32
почему- то после перегрузки сабжа с
внесенными изменениями новая конфигурация не подымается - это видно в
месте, отмеченном "!!!!!!!!!!"
несмотря на измненные значение ip адресов и профилей -
восстанавливаются дефолтовые нестройки
192.168.0.1> ip profile add 3 bridge3 1 50 6 1 test test 3 0 192.168.60.22 255.2
55.255.0 192.168.60.20
pf_pfno_buffer=3
pf_name=bridge3
pf_vpi_buffer=1
pf_vci_buffer=50
pf_role_buffer=6
pf_encapsulation_buffer=1
pf_ppp_username=test
pf_ppp_password=test
pf_ppp_auth_buffer=3
pf_ppp_idletime_buffer=0
pf_addr_str=192.168.60.22
pf_mask_str=255.255.255.0
pf_gw_str=192.168.60.20
pf_pfno_buffer=3 pf_no=3 pf_encapsulation=1
profile add no 3
ISP name = 'bridge3'
VPI/VCI='1/50'
Role=6 ('br1483')
Encapsulation=1 ('LLC')
PPP username='test'
PPP password='test'
PPP auth=3 ('auto')
PPP idletime='0'
PPP Connection On Demand is Disabled
IP addr = 192.168.60.22
IP mask = 255.255.255.0
IP gw = 192.168.60.20
192.168.0.1> ip pfno 3
do_pfno: pfno=3
System Profile Number is changed to '3'
System Role is changed to 'Bridge with R1483'
Please do 'ip config save' and 'ip restart' to let such change take effect!!!
Encapsulation Mothod is changed to Encapsulation=1 ('LLC')
192.168.0.1> ip role 6
192.168.0.1> ip config save
Updating Flash filing system ...
done
ip: configuration saved
192.168.0.1> ip restart
NBfs1Z
PP Boot 8.2.0.8.1 (9 May 2002)
SDRAM size = 0x1000000
NPnFound valid boot information block
No, or invalid, configuration information in EEPROM - trying FLASH
Valid configuration (size 256)
NP software version is 0x00000701 (reply took 7us)
DSL-1500G version 7.1.0.30 Annex-A/B (Sep 6 2004) R2.21.002.15.b2t30
BSP: BD6000 BSP v1.2 (ISOS 7.1)
CSP: He2x0 CSP v1.5 (ISOS 7.1)
Copyright (c) 2001 D-Link Corp.
1 bridge 1 50 6 1 ppp: user password 1 0 1 wan: 192.168.60.22 255.255.255.0 192.
168.60.20
2 ISP2 0 35 6 1 ppp: user password 1 0 1 wan: 0.0.0.0 0.0.0.0 0.0.0.0
3 bridge3 1 50 6 1 ppp: test test 3 0 1 wan: 192.168.60.22 255.255.255.0 192.168
.60.20
4 bridge1 1 50 6 1 ppp: test test 3 0 0 wan: 192.168.60.22 255.255.255.0 192.168
.60.20
5 null 0 0 6 1 ppp: user password 1 0 1 wan: 0.0.0.0 0.0.0.0 0.0.0.0
6 null 0 0 6 1 ppp: user password 1 0 1 wan: 0.0.0.0 0.0.0.0 0.0.0.0
7 null 0 0 6 1 ppp: user password 1 0 1 wan: 0.0.0.0 0.0.0.0 0.0.0.0
8 null 0 0 6 1 ppp: user password 1 0 1 wan: 0.0.0.0 0.0.0.0 0.0.0.0
192.168.0.1>
Подскажите че делать ?
Либо 30я прошивка кривая либо руки, больше склоняюсь к последнему! :)
Если все же дело в прошивки, то подскажите плиз правильную прошивку и где ее можно слить. Кроме того, как ее правильно залить имея только консольное подключение. Заранее благодарен
СообщениеДобавлено: Вт дек 27, 2005 10:56
Эта команда: "192.168.0.1> ip profile " была дана уже после перезагрузки? Если да, то с чего Вы решили, что настройки не сохраняются?
СообщениеДобавлено: Вт дек 27, 2005 11:05
вот последовательность действий которая должна привести к установлению модемов для рабоиы в режим моста
единственное что в ней заменено это номер профиля с 1 на 3
http://www.dlink.ru/technical/faq_xdsl_15.php
я не совсем точно выразил свою мысль.
на сколько я понима из скупой документации для этих модемов командой
ip pfno 3
мы задаем какой профиль юзать при загрузке, соответсвенно я выбрал третий который и должен юзаться
но к сожалению настройки профиля не подымаются при загрузке модема, не используются
как быть дальше ?
СообщениеДобавлено: Вт дек 27, 2005 11:26
ip pfno 3
как быть дальше ?
Почему Вы решили, что эти настройки не используются?
СообщениеДобавлено: Вт дек 27, 2005 11:38
ip pfno 3
как быть дальше ?
ок давайте по шагам ...
1) Включаем модем, имеем к енму доступ через консоль
2) подключаемся к модему
видим приглашение CLI 192.168.0.1>
3) shdsl role co
4) создаем профиль бридж ip profile add 3 bridge3 1 50 6 1 test test 3 0 192.168.60.22 255.2
5) делаем текущий профиль профиль активным ip pfno 3
6) выбираем роль ip role 6
7) сохраняем настройки ip config save
8) перегружаемся ip restart
далее происходит перезагрузка система и вновь выдается приглашение cli 192.168.0.1>
хотя на сколько я понимаю приглашение должно быть 192.168.0.22>
9) ip profile выдает сохраненные изменения профилей
168.60.20
.60.20
.60.20
192.168.0.1>
единствееной что не происходит это назначение профиля №3 активным и изменения ip адреса устройства,
может это в другом месте делать необходимо, подскажите плиз :)
СообщениеДобавлено: Вт дек 27, 2005 11:58
1. В бридж профайле поля ip адрес, gw и mask ничего не значат.
2. ip адрес в приглашении CLI - это ip адрес ethernet интерфейса, его Вы не меняли.
3. До сих пор не понимаю, почему Вы считаете, что не происходит назначение третьего профайла активным.
СообщениеДобавлено: Вт дек 27, 2005 12:10
1) Прояснилось - согласен был не прав
2) Фтыкаю в доку - пока не могу понять как это сделать (если есть терпение подскажите плиз как ) :)
3) В документации CLI - не написано вообще ничего о ip pfno - просто сказано что есть, такое - да и в FAQ по установке модемов в режим моста указано енто. pfno созвучно с profile number - как мне показалось
вообщем затык какой то у меня не понятный с Dlinkpm ентим :(
СообщениеДобавлено: Вт дек 27, 2005 13:11
Вам нужно только соединить два dsl-1500g мостами?
ip адрес на LAN интерфейсе меняется командой ip enable bridge (см. FAQ: 5. ip enable bridge 192.168.0.2 )
СообщениеДобавлено: Вт дек 27, 2005 13:53
Виктор спасибо огромное за помощь!
если можно уточните плиз почему в факе удаленная сторона выступает в качестве инициатора соединения можно ли на модеме который судя по рисунку 192.168.0.1 выполнить ip enable bridge 192.168.0.1 - и поднимется ли после ентого линк, к сожалению у себя проверить не могу ибо слой экскаваторщик порвал кабель ! :)
СообщениеДобавлено: Вт дек 27, 2005 14:28
В работе DSL-1500G мостами их ip адреса служат только для удаленного управления ими. И в FAQ на одном из DSL-1500G был сменен ip чтобы не было конфликта.
