Текущее время: Пн авг 17, 2026 20:11
СообщениеДобавлено: Пн мар 11, 2019 04:32
Не понимаю в чём причина. Настроек минимум, где мог ошибиться? В той же сети 1100-06/ME и 1100-10/ME успешно отчитываются на Syslog. Пробовал все уровни facility, severity - толку нет.
Command : show switch
 Device Type           : DGS-1100-16/ME Gigabit Metro Access Switch
 MAC Address           : 18-0f-76-fb-80-15
 IP Address            : 203.0.113.2 (Manual)
 VLAN Name             : admin
 Subnet Mask           : 255.255.255.0
 Default Gateway       : 203.0.113.1
 Boot PROM Version     : Build 1.00.003
 Firmware Version      : Build 1.00.B025
 Hardware Version      : B2
 System Serial Number  : SG0K2I9000068
 System Name           : SWITCH
 System Location       :
 System Contact        :
 Spanning Tree         : Disabled
 IGMP Snooping         : Disabled
 MLD Snooping          : Disabled
 TELNET                : Enabled (TCP 23)
 SNMP                  : Enabled
 SNTP                  : Enabled
Command : show config current_config
#                   DGS-1100-16/ME Gigabit Ethernet Switch
#                               Configuration
#                          Firmware: Build 1.00.B025
#           Copyright(C) 2014 D-Link Corporation. All rights reserved.
#EEE#
config eee portlist 1-16 state disable
#MIRROR#
disable mirror
#MULTICAST FILTER#
config multicast filter forward
#VOICE VLAN#
disable voice_vlan
config voice_vlan ports list 1-16 state disable
config voice_vlan ports list 1-16 mode autountagged
config voice_vlan priority 5
config voice_vlan aging_time 720
#SURVEILLANCE_VLAN VLAN#
disable surveillance_vlan
config surveillance_vlan priority 5
config surveillance_vlan aging_time 720
#SAFEGUARD ENGINE#
config safeguard_engine state disable
#LBD#
enable loopdetect
config loopdetect lbd_recover_time 60
config loopdetect interval_time 10
config loopdetect ports port_list 1-16 state enable
config loopdetect trap none
#IPIF#
config ipif System dhcp retry_time 7
config ipif System ipaddress 203.0.113.2/24
config ipif System ipv6 state disable
create iproute default 203.0.113.1
#ASYMMETRIC VLAN#
disable asymmetric_vlan
#TELNET#
#DOS_PREVENTION#
config dos_prevention dos_type land_attack state disable
config dos_prevention dos_type blat_attack state disable
config dos_prevention dos_type tcp_null_scan state disable
config dos_prevention dos_type tcp_xmasscan state disable
config dos_prevention dos_type tcp_synfin state disable
config dos_prevention dos_type tcp_syn_srcport_less_1024 state disable
config dos_prevention dos_type ping_death_attack state disable
#QOS#
config 802.1p default_priority ports 1-16 Medium
config scheduling_mechanism ports 1-16 sp
config bandwidth_control 1-16 rx_rate no_limit
config bandwidth_control 1-16 tx_rate no_limit
#STP#
disable stp
config stp ports 1-16 edge true
config stp trap new_root disable
config stp trap topo_change disable
config stp version rstp
#SNTP#
enable sntp
config sntp ipaddress 203.0.113.1
config sntp poll_interval 720
#DST#
config dst disable
#TIME_RANGE#
#TIME_ZONE#
config time_zone operator + hour 8 minute 0
#SNMP#
create snmp community public read_only
create snmp community private read_write
enable snmp
disable snmp authenticate_traps
disable snmp traps
config snmp linkup_traps disable
config snmp linkdown_traps disable
config snmp coldstart_traps disable
config snmp warmstart_traps disable
config snmp system_contact
config snmp system_location
config snmp system_name SWITCH
#ZONE_DEFENSE#
disable zone_defense
#DDP#
disable ddp
config ddp report_time never
#JUMBO_FRAME#
config jumbo_frame ports 1-16 state disable
#LINK_AGGREGATION#
#LACP#
#LLDP#
disable lldp
config lldp notification disable
#SYSLOG#
enable syslog
config syslog host severity all
config syslog host state enable
config syslog host facility local7
config syslog host ipaddress 198.51.100.20
config syslog host udp_port 514
#IGMPSNOOP#
disable igmp_snooping multicast_vlan
config igmp_snooping vlanid 1,100,169,198,203 fast_leave disable
config igmp_snooping vlanid 1,100,169,198,203 state disable
config igmp_snooping querier vlanid 1,100,169,198,203 state disable
#MLDSNOOP#
disable mld_snooping multicast_vlan
config mld_snooping vlanid 1,100,169,198,203 fast_leave disable
config mld_snooping vlanid 1,100,169,198,203 state disable
config mld_snooping querier vlanid 1,100,169,198,203 state disable
#VLAN#
create vlan vlanid 1,100,169,198,203
disable pvid auto_assign
enable management_vlan
config port_vlan 2 pvid 100
config port_vlan 3 pvid 100
config port_vlan 4 pvid 100
config port_vlan 5 pvid 100
config port_vlan 6 pvid 100
config port_vlan 7 pvid 100
config port_vlan 8 pvid 100
config port_vlan 9 pvid 100
config port_vlan 9-10 pvid 100
config port_vlan 9-11 pvid 100
config port_vlan 9-12 pvid 100
config port_vlan 9-13 pvid 100
config port_vlan 9-14 pvid 100
config port_vlan 9-15 pvid 203
config port_vlan 9-16 pvid 203
config management_vlan 203
config vlan vlanid 100,169,198,203 add tagged 15-16
config vlan vlanid 1 add untagged
config vlan vlanid 100 add untagged 1-14
config vlan vlanid 100 name video
config vlan vlanid 169 name computer
config vlan vlanid 198 name server
config vlan vlanid 203 name admin
#FDB#
config fdb aging_time 300
#PORTS#
config ports 1 description add video
config ports 2 description add video
config ports 3 description add video
config ports 4 description add video
config ports 5 description add video
config ports 6 description add video
config ports 7 description add video
config ports 8 description add video
config ports 9 description add video
config ports 10 description add video
config ports 11 description add video
config ports 12 description add video
config ports 13 description add video
config ports 14 description add video
config ports 15 description add servers
config ports 16 description add uplink
config ports 1-16 flow_control disable
config ports 1-5,7-16 learning enable
config ports 6 learning disable
config ports 1-16 mdix auto
config ports 1-16 speed auto
config ports 1-16 state enable
#POWER SAVING#
config power_saving global link_detection_scheduled disable
config power_saving global port_shutdown_scheduled disable
config power_saving global hibernation_scheduled disable
config power_saving global dim-led_scheduled disable
config power_saving global administrative_dim_led disable
#POE#
#TRAFFIC_SEGMENTATION#
config traffic_segmentation 1-16 forward_list all
СообщениеДобавлено: Вт мар 12, 2019 20:53
Сегодня ни с того ни с сего DGS 1100-16/ME вдруг подал признаки того, что умеет слать логи в Syslog, но как-то странно:
И больше ни на что не реагирует - ни на логин, ни на логаут, ни вообще ни на что. А вот так выглядят сообщения с DGS 1100-06/ME:
Причём, 6-портовый фиксирует все события, как и задумано. Вообще у вас очень хороший форум для того, чтобы пообщаться с самим собой, но я надеялся получить какие-нибудь комментарии представителей производителя.
СообщениеДобавлено: Чт мар 14, 2019 11:43
но как-то странно
он всегда так слал, похоже на наследство от SmartConsole, там на 64514 порт нечто подобное
