Текущее время: Чт сен 10, 2026 09:02
Начать новую тему Ответить на тему  [ Сообщений: 21 ]  На страницу Пред.  1, 2
СообщениеДобавлено: Чт дек 22, 2005 11:21
Привет всем!
Понял. Вот результат работы команд sip status и sip print. Адреса устройств: ...250 - Dynamix, ...252 - D-Link. Номера телефонов 001-004 на Dynamix и 051 на D-Link.
sip status
=== SIP Status ===
== Line 1 ==
hook_state = OnHook
call_state = StateNull
current_tone = 0
reg_state = NotRegistered, expiration = 0 seconds left
currentsd = -1, sd1 = -1, sd2 = -1, regsd = -1
active_proxy_id = 0
incoming_pstn = 0
== Line 2 ==
hook_state = OnHook
current_tone = 0
active_proxy_id = 0
incoming_pstn = 0
OK
sip show
--- SIP configurations ---
enable_server_fqdn = 0
server_ip = 0.0.0.0
server_fqdn =
server_ip2 = 0.0.0.0
server_fqdn2 =
server_port = 5060
service_domain =
url_protocol = 1
user_phone_type = 1
timer_t2 = 4
p_n_ua = 1
rfc3323_3325 = 0
rfc3311 = 0
enable_proceeding_timer = 1
non_register_mode = 1
initial_unregister_mode = 0
peertopeer_mode = 1
mwi_enable = 1
special_ring = 0
callwait_alert_tone = 1
allow_PSTNcallwaiting = 1
VoIP caller_ID = 0
184_handling method removed
pstn Reroute = 1
prov_success = 1
100rel = 1
rr_180 = 0
extend_inv = 0
kddi_503_enable = 0
same_phone_number = 1
Min-SE = 180
Supported codecs: 18 4 8 0
digit_timer = 4
inComingCallFunctionType = 2
request_uri_check = 0
enable_outbound_proxy = 0
outbound_proxy_ip = 0.0.0.0
enable_outbound_proxy_fqdn = 0
outbound_proxy_port = 0
lingo_url =
call_hold_method = 1
Line 1 configuration
phone_number = 051
display_name = Vidd. 5, #1
user_agent_port = 5060
auth_username = 051
auth_password =
sig_tos = 5
rtp_tos = 5
oob_dtmf = 1
ec = 1
vad = 0
display_cid[0]=1
hook timer:1200
Line 2 configuration
phone_number =
display_name =
user_agent_port = 5061
auth_username = 051
auth_password =
sig_tos = 5
rtp_tos = 5
oob_dtmf = 1
ec = 1
vad = 0
display_cid[1]=1
hook timer:1200
=== phone_table ===
1: [001] = 001@213.130.17.250:5060
2: [] = @0.0.0.0:0
3: [] = @0.0.0.0:0
4: [] = @0.0.0.0:0
5: [] = @0.0.0.0:0
6: [] = @0.0.0.0:0
7: [] = @0.0.0.0:0
8: [] = @0.0.0.0:0
9: [] = @0.0.0.0:0
10: [] = @0.0.0.0:0
OK
С уважением
Ярослав.
СообщениеДобавлено: Чт дек 22, 2005 11:23
Привет всем!
Да, кстати, D-Link h/w rev.A1.
С уважением
Ярослав.
СообщениеДобавлено: Чт дек 22, 2005 11:26
Модератор
Модератор
Поставьте на нашем шлюзе параметр
oob_dtmf = 1
в 0 т.е. oob_dtmf = 0
Виктор Колосов
СообщениеДобавлено: Чт дек 22, 2005 12:02
Привет всем!
Попробовал, не получилось. Во-первых, формат команды - sip set <endpoint id> oob_dtmf {0|1}, во-вторых, если ставить endpoint id == 0, то ERROR, если 1 или 001 - OK, но ничего в работе к лучшему не меняется.
Между прочим, вчера купил ещё один DVG-1402S (h/w rev. B1), сегодня попробовал установить вместо первого устройстава (у которого h/w rev. A1) - завёлся с полпинка, никаких проблем с дозвоном после доступа к линии на Dynamix! То есть, D-Link DVG-1402S h/w rev.B1 и Dynamix DW-0004/S - друзья изначально. :)
С уважением
Ярослав.
СообщениеДобавлено: Чт дек 22, 2005 19:46
Привет всем!
Вопрос о совместимости по-прежнему актуален (для h/w версии A1). Или можно бесплатно обменять A1 на B1?
С уважением
Ярослав.
СообщениеДобавлено: Пт дек 23, 2005 11:21
Модератор
Модератор
HEKPOMAH писал(а):
Привет всем!
Обратитесь в наш сервисный центр.
Виктор Колосов
