Текущее время: Пн ноя 09, 2026 04:11
 Заголовок сообщения: Issues with D-Link DIR 615 router
СообщениеДобавлено: Ср июл 25, 2018 05:03
So basically I recently started living with a relative and that's when this router started having issues. What happens is sometimes the router will drop a few or all of the devices on the network every 5-15 minutes or so. I'm not sure if it does the same for devices with a wired connection because with all our devices we connect to the router wirelessly. Usually I'm able to reconnect after a bit but it's annoying. When I am home alone however there's no problems so I'm assuming that its the number of devices connected to the router? Honestly I'm not very networking literate so I'm not sure what other details I need to provide about this problem. We tried updating the firmware to the newest version on the Dlink website but the issue persists. Here's the support page:
http://support.dlink.ca/ProductInfo.aspx?m=DIR-615
https://www.minimilitia.mobi/ https://www.applock.ooo/ https://www.7zip.vip/
 Заголовок сообщения: Re: Issues with D-Link DIR 615 router
СообщениеДобавлено: Ср июл 25, 2018 06:36
Probably, you have any other dhcp-server in your home network. Could you draw a map of your home network ?
