Текущее время: Вт окт 13, 2026 20:06
Начать новую тему Ответить на тему  [ Сообщений: 133 ]  На страницу Пред.  1 ... 5, 6, 7, 8, 9  След.
 Заголовок сообщения: Re: DGS 3627 & hol_prevention & hol
СообщениеДобавлено: Чт окт 26, 2017 14:56
Заменили свич.
show util cpu
Command: show utilization cpu
CPU Utilization
Five seconds - 3 % One minute - 3 % Five minutes - 4 %
show ports
Command: show ports
Port Port Settings Connection Address
State Speed/Duplex/FlowCtrl Speed/Duplex/FlowCtrl Learning
1 Enabled Auto/Disabled 1000M/Full/None Enabled
2 Disabled Auto/Disabled Link Down Enabled
3 Enabled Auto/Disabled 1000M/Full/None Enabled
4 Enabled Auto/Disabled Link Down Enabled
5 Disabled Auto/Disabled Link Down Enabled
6 Enabled Auto/Disabled 1000M/Full/None Enabled
7 Enabled Auto/Disabled 1000M/Full/None Enabled
8 Enabled Auto/Disabled Link Down Enabled
9 Enabled Auto/Disabled Link Down Enabled
10 Enabled Auto/Disabled 1000M/Full/None Enabled
11 Enabled Auto/Disabled 1000M/Full/None Enabled
12 Enabled Auto/Disabled 1000M/Full/None Enabled
13 Enabled Auto/Disabled 1000M/Full/None Enabled
14 Enabled Auto/Disabled 1000M/Full/None Enabled
15 Enabled Auto/Disabled 1000M/Full/None Enabled
16 Enabled Auto/Disabled Link Down Enabled
17 Enabled Auto/Disabled Link Down Enabled
18 Enabled Auto/Disabled Link Down Enabled
19 Enabled 1000M/Full/Disabled Link Down Enabled
20 Enabled Auto/Disabled Link Down Enabled
21 (C) Enabled Auto/Disabled Link Down Enabled
21 (F) Enabled Auto/Disabled Link Down Enabled
22 (C) Enabled Auto/Disabled Link Down Enabled
22 (F) Enabled Auto/Disabled Link Down Enabled
23 (C) Enabled Auto/Disabled 10M/Half/None Enabled - пинговалка
23 (F) Enabled Auto/Disabled Link Down Enabled
24 (C) Enabled Auto/Disabled Link Down Enabled
24 (F) Enabled Auto/Disabled Link Down Enabled
25 Enabled Auto/Disabled 10G/Full/None Enabled
26 Enabled Auto/Disabled Link Down Enabled
27 Enabled Auto/Disabled Link Down Enabled
q
show error ports
Command: show error ports 1-24
Port number : 1
RX Frames TX Frames
CRC Error 0 Excessive Deferral 0
Undersize 0 CRC Error 0
Oversize 0 Late Collision 0
Fragment 0 Excessive Collision 0
Jabber 0 Single Collision 0
Drop Pkts 2239 Collision 0
Symbol Error 0
Buffer Full Drop 0
ACL Drop 216
Multicast Drop 0
VLAN Ingress Drop 230
Port number : 3
RX Frames TX Frames
Drop Pkts 1691 Collision 0
Symbol Error 0
Buffer Full Drop 0
ACL Drop 0
Multicast Drop 0
VLAN Ingress Drop 15
Port number : 6
RX Frames TX Frames
Drop Pkts 3679 Collision 0
Symbol Error 0
Buffer Full Drop 0
ACL Drop 0
Multicast Drop 0
Port number : 7
RX Frames TX Frames
Drop Pkts 3281 Collision 0
Symbol Error 0
Buffer Full Drop 0
ACL Drop 238
Multicast Drop 0
VLAN Ingress Drop 254
Port number : 10
RX Frames TX Frames
Drop Pkts 1928 Collision 0
Symbol Error 0
Buffer Full Drop 0
ACL Drop 0
Multicast Drop 0
VLAN Ingress Drop 16
Port number : 11
RX Frames TX Frames
Drop Pkts 1893 Collision 0
Symbol Error 0
Buffer Full Drop 0
ACL Drop 0
Multicast Drop 0
Port number : 12
RX Frames TX Frames
Drop Pkts 16 Collision 0
Symbol Error 0
Buffer Full Drop 0
ACL Drop 0
Multicast Drop 0
Port number : 13
RX Frames TX Frames
Drop Pkts 304 Collision 0
Symbol Error 0
Buffer Full Drop 0
ACL Drop 251
Multicast Drop 0
VLAN Ingress Drop 268
Port number : 14
RX Frames TX Frames
Drop Pkts 339 Collision 0
Symbol Error 0
Buffer Full Drop 0
ACL Drop 252
Multicast Drop 0
VLAN Ingress Drop 269
Port number : 15
RX Frames TX Frames
Drop Pkts 282 Collision 0
Symbol Error 0
Buffer Full Drop 0
ACL Drop 256
Multicast Drop 0
VLAN Ingress Drop 256
show_util_ports.JPG [ 32.99 KiB | Просмотров: 11867 ]
Комментарий к файлу: show switch
show_sw.JPG [ 52.44 KiB | Просмотров: 11867 ]
СообщениеДобавлено: Чт окт 26, 2017 14:57
вот еще фото кондеров на установленном свиче
cond2.jpg [ 149.32 KiB | Просмотров: 11867 ]
cond1.jpg [ 144.14 KiB | Просмотров: 11867 ]
СообщениеДобавлено: Чт окт 26, 2017 15:40
error ports что-то не весь
СообщениеДобавлено: Чт окт 26, 2017 15:42
аплинк не добавил. Для сравнения еще раз ошибки с 1го порта
Port number : 1
RX Frames TX Frames
Drop Pkts 12803 Collision 0
Symbol Error 0
Buffer Full Drop 0
ACL Drop 1696
Multicast Drop 0
VLAN Ingress Drop 1806
Port number : 25
RX Frames TX Frames
Drop Pkts 31208 Collision 0
Symbol Error 0
Buffer Full Drop 0
ACL Drop 0
Multicast Drop 0
VLAN Ingress Drop 120
СообщениеДобавлено: Чт окт 26, 2017 16:00
Загрузка CPU в норме. Проблем с физикой подключений нет. Те, конденсаторы, что видны, похоже в порядке.
Нужно более детально анализировать ситуацию с просадкой. А на новом просадки также наблюдаются?
Бигаров Руслан.
СообщениеДобавлено: Чт окт 26, 2017 16:06
внешне не вспухшие, но запросто емкость могли потерять свою, у нас так на 3028 было
СообщениеДобавлено: Чт окт 26, 2017 16:11
А можно как-то добраться до датчиков на плате и микросхемах ?
Напряжение там, температура.
Ну не верю я, что железки там вообще не имеют датчиков.
СообщениеДобавлено: Пт окт 27, 2017 12:51
После замены никаких улучшений
СообщениеДобавлено: Вт ноя 14, 2017 14:36
Файлы DGS-3620 R3.00 доступны для скачивания здесь:
http://dlink.ru/ru/products/1/2037_d.html
Добрый день!
Куда делась прошивка 3.00.004? С ней что-то не так?
Успели прошить один коммутатор, работает.
СообщениеДобавлено: Вт ноя 14, 2017 16:12
Dwolfix писал(а):
Добрый день!
С ней всё нормально. Сегодня прошивку перевыложат.
Бигаров Руслан.
СообщениеДобавлено: Вт ноя 28, 2017 14:10
А еще такой вопрос в эту же тему. Если я использую в установке приоритета ACL:
create access_profile profile_id 2 ip dscp destination_ip_mask 224.0.0.0
conf access_profile profile_id 2 add access_id 1 ip dscp 32 port 27 permit priority 5
нужно устанавливать trust dscp для 27 порта? Или правило все равно работает как нужно?
Если включаю счетчик на правиле, то он прирастает независимо от того включен trust или нет.
СообщениеДобавлено: Вт ноя 28, 2017 17:33
Если коммутатор поддерживает DSCP Mapping и Вы доверяете меткам входящих пакетов, тогда нужно включать dscp_trust
Бигаров Руслан.
СообщениеДобавлено: Пт дек 01, 2017 13:40
Коммутатор, собственно, DGS3627G. 27 порт - аплинк, с которого приходит мультикастовый трафик раскрашенный DSCP32. Задача - выставить приоритет 5 для этого трафика, что я и пытаюсь сделать вышеупомянутым способом.
Сам коммутатор является PIM роутером. С раздачей в 2 разных vlan.
И следующий вопрос - каким образом коммутатор будет выставлять, и будет ли вообще это делать, приоритеты для такого вида трафика? Нужно ли писать какие-то дополнительные правила обработки?
СообщениеДобавлено: Пт дек 01, 2017 16:50
Как ни печально - DGS3627 - не имеет. Единственные датчики, который появляются, это SFP(XFP) с DDMI. Все. Из своих датчиков - только датчики вращения вентиляторов, и то орать начинает только тогда когда вентилятор уже практически остановится, и RPS.
СообщениеДобавлено: Пт май 04, 2018 10:48
Примерно аналогичная ситуация с потерями на DGS-3620-28SC
Прошивки последние доступные.
Топология:
порт 25 (10Г) - Uplink
порт 26-28 (10Г) - Downlink на DGS-3627, DGS-3420-28SC, DGS-3000-28SC
порт 1-3 (1Г) - Downlink на DGS-3120-24SC
порт 21 (1Г) - Downlink на DGS-3627 сюда подключен тестовый PC (1Г)
Начали замечать рост счетчика потерь.
Hol - включен. Скорость на тестовом РС не более 500Мбит и растут счетчики Hol Drop на 1Г портах (даже на 1-3, где нагрузка штатно не более 300мбит)
Hol - выключен. Скорость на тестовом РС 850Мбит и растут счетчики дропов на 25м порту (аплинк)
Получается, что данная функция только вредит.
З.Ы. В мануале написано такое:
The enable hol_prevention command enables head of line prevention on the Switch. Note: After enabling the HOL prevention option, the switch needs to be rebooted for the change to take affect.
Это как обычно "после перепрошивки сбросьте свитч в дефолт" или реально надо перегружать? На деле видны изменения даже без перезагрузки.
З.Ы.Ы.
"COS2 - это пакетики с метками 802.1p = 0"
А можно полное описание этих COS? а то оно как не "интуитивно понятно"(((((
