Текущее время: Сб сен 26, 2026 04:10
СообщениеДобавлено: Вт ноя 21, 2017 09:13
Добрый день, в последнее время стал отваливаться магистральный порт, оставляя без сети весь этаж. Вот логи.
Command: show switch
Device Type : DGS-3000-24TC Gigabit Ethernet Switch
MAC Address : B0-C5-54-92-CC-00
IP Address : 10.255.255.24 (Manual)
VLAN Name : management
Subnet Mask : 255.255.255.0
Default Gateway : 10.255.255.1
Boot PROM Version : Build 1.00.001
Firmware Version : Build 1.19.B005
Hardware Version : A1
Serial Number : RZ4V1E2000619
System Name :
System Location : OCK, 5 etaj, 4 podjezd, 9 room
System Uptime : 6 days, 17 hours, 7 minutes, 48 seconds
System Contact :
Spanning Tree : Disabled
GVRP : Disabled
IGMP Snooping : Enabled
MLD Snooping : Disabled
VLAN Trunk : Disabled
Telnet : Disabled
Web : Enabled (TCP 80)
SNMP : Enabled
SSL Status : Disabled
SSH Status : Enabled (TCP 22)
802.1X : Disabled
Jumbo Frame : Disabled
CLI Paging : Enabled
MAC Notification : Disabled
Port Mirror : Disabled
SNTP : Enabled
Syslog Global State : Disabled
Single IP Management : Disabled
Password Encryption Status : Enabled
DNS Resolver : Disabled
в логах
940 2017-11-21 08:48:32 INFO(6) Port 24 link up, 1000Mbps FULL duplex
939 2017-11-21 08:48:24 INFO(6) Port 24 link down
938 2017-11-21 08:48:20 INFO(6) Port 24 link up, 1000Mbps FULL duplex
937 2017-11-21 08:45:51 INFO(6) Port 24 link down
936 2017-11-21 08:45:50 INFO(6) Port 24 link up, 1000Mbps FULL duplex
935 2017-11-21 08:45:29 INFO(6) Port 24 link down
DGS-3000-24TC:admin#sh vlan
Command: show vlan
VLAN Trunk State : Disabled
VLAN Trunk Member Ports :
VID : 1 VLAN Name : default
VLAN Type : Static Advertisement : Enabled
Member Ports :
Static Ports :
Current Tagged Ports :
Current Untagged Ports:
Static Tagged Ports :
Static Untagged Ports :
Forbidden Ports :
VID : 266 VLAN Name : 10.2.66.0/24
VLAN Type : Static Advertisement : Disabled
Member Ports : 23-24
Static Ports : 23-24
Current Tagged Ports : 23-24
Static Tagged Ports : 23-24
Forbidden Ports :
VID : 295 VLAN Name : 10.2.95.0/24
Forbidden Ports :
VID : 1002 VLAN Name : 10.255.7.0/24
Forbidden Ports :
VID : 1010 VLAN Name : Rukovodstvo
Member Ports : 7,23-24
Static Ports : 7,23-24
Current Untagged Ports: 7
Static Untagged Ports : 7
Forbidden Ports :
VID : 1011 VLAN Name : IPtel
Forbidden Ports :
VID : 1032 VLAN Name : DomainARM
Member Ports : 1-6,9-24
Static Ports : 1-6,9-24
Current Untagged Ports: 1-6,9-22
Static Untagged Ports : 1-6,9-22
Forbidden Ports :
VID : 1106 VLAN Name : SKUD
Forbidden Ports :
VID : 4000 VLAN Name : management
Forbidden Ports :
VID : 4040 VLAN Name : MTC
Forbidden Ports :
VID : 4050 VLAN Name : fok
Member Ports : 8,23-24
Static Ports : 8,23-24
Current Untagged Ports: 8
Static Untagged Ports : 8
Forbidden Ports :
VID : 4051 VLAN Name : bankomat
Forbidden Ports :
Total Static VLAN Entries: 12
Total GVRP VLAN Entries: 0
На 24 порту подключен магистральный свитч, т.е. приходяший от управляемого коммутатора 3Com Baseline Switch 2920
СообщениеДобавлено: Вт ноя 21, 2017 09:31
В чём вопрос то? Проверяйте физику (оптику или медь, тут не уточняется). Почему вы решили что проблема с коммутатором Длинк ?
СообщениеДобавлено: Вт ноя 21, 2017 16:03
Проблема кратковременная, да и не только на одном коммутаторе, на многих. Медь переобжимал, бестолку.
А в других коммутаторах DGS-3200-10 тож логи на падение портов. физика магазинная медь патчкорд.
СообщениеДобавлено: Ср ноя 22, 2017 03:44
Очень странно. Но я всё равно сомневаюсь что свич тут при делах
СообщениеДобавлено: Чт ноя 23, 2017 10:16
Ткните в другой порт и помониторьте. Что показывает cable diagnostic port 24 ?
Сейчас этот форум просматривают: Google [Bot] и гости: 21
