Текущее время: Сб июн 13, 2026 03:36
 Заголовок сообщения: залипание картинки
СообщениеДобавлено: Пт сен 29, 2017 10:50
Добрый день!
Есть аггрегация DGS-3420-26SC, за ним коммутаторы доступа D-Link DES-3528.
Периодически идут залипание или рассыпание картинки.
3120 fw: Boot PROM Version : Build 1.00.006
Firmware Version : Build 1.70.B023
Hardware Version : A2
3528 fw: DES35xx_3.10.B059.had
3120:
# IGMP_SNOOPING
enable igmp_snooping
config igmp_snooping data_driven_learning max_learned_entry 120
config igmp_snooping vlan_name default topology_changes_notification process fast_leave disable proxy_reporting state disable source_ip 0.0.0.0 state disable
config igmp_snooping querier vlan_name default query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping data_driven_learning vlan_name default state disable aged_out disable expiry_time 600
config igmp_snooping vlan_name MCAST topology_changes_notification process fast_leave disable proxy_reporting state disable source_ip 0.0.0.0 state enable
config igmp_snooping querier vlan_name MCAST query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 2
config router_ports_forbidden MCAST add 1-24
config igmp_snooping data_driven_learning vlan_name MCAST state disable aged_out disable expiry_time 260
config igmp_snooping vlan_name MGMT topology_changes_notification process fast_leave disable proxy_reporting state disable source_ip 0.0.0.0 state disable
config igmp_snooping querier vlan_name MGMT query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping data_driven_learning vlan_name MGMT state disable aged_out disable expiry_time 300
config igmp_snooping vlan_name PPPoE topology_changes_notification process fast_leave disable proxy_reporting state disable source_ip 0.0.0.0 state disable
config igmp_snooping querier vlan_name PPPoE query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping data_driven_learning vlan_name PPPoE state disable aged_out disable expiry_time 300
config igmp_snooping forward_lookup_mode mac
И почему-то на агрегация льется весь мультикаст суда по кол-ву пакетов
25 6708 34440 2 (бывает достигает до 40000).
3528:
# IGMP_MULTICAST_VLAN
enable igmp_snooping multicast_vlan
config igmp_snooping multicast_vlan forward_unmatched disable
create igmp_snooping multicast_vlan MCAST 99
config igmp_snooping multicast_vlan MCAST state enable replace_source_ip 0.0.0.0
config igmp_snooping multicast_vlan MCAST add member_port 2-4,8-9,11
config igmp_snooping multicast_vlan MCAST add source_port 25
create mcast_filter_profile profile_id 1 profile_name IPTV
config mcast_filter_profile profile_id 1 add 225.0.0.0-239.255.255.255
# IGMP_SNOOPING
config igmp_snooping data_driven_learning max_learned_entry 128
config igmp_snooping vlan_name MCAST fast_leave disable report_suppression disable
config igmp_snooping querier vlan_name MCAST query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping data_driven_learning vlan_name MCAST state enable aged_out disable expiry_time 260
config cpu_filter l3_control_pkt 1-24 dvmrp state enable
config cpu_filter l3_control_pkt 1-24 pim state enable
config cpu_filter l3_control_pkt 1-24 igmp_query state enable
Не подскажете в какую сторону смотреть?
 Заголовок сообщения: Re: залипание картинки
СообщениеДобавлено: Сб сен 30, 2017 10:52
Для начала - http://ftp.dlink.ru/pub/Switch/DGS-3420 ... 2_B004.had
Аплинк у DGS-3420-26SC - 10-гигабитный? Возможно, что проблема на переходе с 10G на 1G.
Попробуйте пригнать мультикаст по отдельному 1G каналу, чтобы не было этого перехода.
СообщениеДобавлено: Пн окт 02, 2017 08:17
Прошивку обновил. Буду наблюдать.
А чем проблема при переходе с 10 на 1 гиговый порт?
СообщениеДобавлено: Пн окт 02, 2017 12:29
Возможны эпизодические потери пакетов.
СообщениеДобавлено: Пн окт 02, 2017 12:32
в размере пакетного буфера, который у 3420/3620 маленький для перехода 10г->1г
СообщениеДобавлено: Вт окт 03, 2017 14:26
Новая прошивка не помогла.
Переводил мультикаст на гиг - проблем нет.
Поменял на другую марку - проблем тоже нет. ))
СообщениеДобавлено: Вт окт 03, 2017 16:58
ну тогда вам сюда:
viewtopic.php?f=2&t=173610
тут мы дружно ждём ответа то же нам делать...
Сейчас этот форум просматривают: Bing [Bot] и гости: 16
