Настройки портов на текущий момент. Менял порты в vlanах по всякому. По факту работают порты только если они находятся в vlan default.
1. DGS-3620-28SC
Device Type : DGS-3620-28SC Gigabit Ethernet Switch Unit ID : 1 MAC Address : 10-62-EB-B8-68-00 IP Address : 192.168.30.254 (Manual) VLAN Name : default Subnet Mask : 255.255.255.0 Default Gateway : 0.0.0.0 Boot PROM Version : Build 1.00.016 Firmware Version : Build 2.60.016 Hardware Version : B1 Firmware Type : EI Serial Number : PVXE2H3000050 System Name : CORE-1 System Location : System Uptime : 3 days, 1 hours, 10 minutes, 41 seconds System Contact : Spanning Tree : Disabled GVRP : Disabled IGMP Snooping : Disabled MLD Snooping : Disabled RIP : Disabled RIPng : Disabled DVMRP : Disabled PIM : Disabled PIM6 : Disabled OSPF : Disabled OSPFv3 : Disabled BGP : Disabled VLAN Trunk : Disabled Telnet : Enabled (TCP 23) Web : Enabled (TCP 80) SNMP : Disabled SSL Status : Disabled SSH Status : Disabled 802.1X : Disabled Jumbo Frame : Off CLI Paging : Enabled MAC Notification : Disabled Port Mirror : Disabled SNTP : Disabled DHCP Relay : Disabled DNSR Status : Disabled VRRP : Disabled HOL Prevention State : Enabled Syslog Global State : Disabled Single IP Management : Disabled Password Encryption Status : Disabled DNS Resolver : Disabled
# VLAN
enable pvid auto_assign config vlan default delete 1:1,2:1 config vlan default add untagged 1:2-1:26,2:2-2:26 config vlan default advertisement enable create vlan Control tag 11 config vlan Control add tagged 1:1,2:1 config vlan Control add untagged 1:2-1:26,2:2-2:26 advertisement disable create vlan WorkStations tag 12 config vlan WorkStations add untagged 1:1-1:20,1:24-1:26,2:1-2:8,2:12-2:16,2:19-2:20 advertisement disable create vlan DigitalSignages tag 13 config vlan DigitalSignages add untagged 1:1-1:20,1:22,1:24-1:26,2:1-2:8,2:12-2:16,2:19-2:20 advertisement disable create vlan ReservationMeetingRoom tag 14 config vlan ReservationMeetingRoom add untagged 1:1-1:20,1:22,1:24-1:26,2:1-2:8,2:12-2:16,2:19-2:20 advertisement disable create vlan Videomonitoring tag 15 config vlan Videomonitoring add untagged 1:1-1:20,1:22,1:24-1:26,2:1-2:8,2:12-2:16,2:19-2:20 advertisement disable create vlan ClassRoom tag 16 config vlan ClassRoom add untagged 1:1-1:20,1:22,1:24-1:26,2:1-2:8,2:12-2:16,2:19-2:20 advertisement disable create vlan Matrix tag 17 config vlan Matrix add untagged 1:1-1:20,1:22,1:24-1:26,2:1-2:8,2:12-2:16,2:19-2:20 advertisement disable create vlan Trunk_to_V1 tag 100 config vlan Trunk_to_V1 add tagged 1:19-1:20,2:19-2:20 config vlan Trunk_to_V1 add untagged 1:21 advertisement disable disable gvrp enable asymmetric_vlan disable vlan_trunk config port_vlan 1:1,1:21,1:23 gvrp_state disable ingress_checking enable acceptable_frame admit_all pvid 1 config port_vlan 1:2-1:20,1:24-1:26 gvrp_state disable ingress_checking enable acceptable_frame admit_all pvid 12 config port_vlan 1:22 gvrp_state disable ingress_checking enable acceptable_frame admit_all pvid 11 config port_vlan 2:1 gvrp_state disable ingress_checking enable acceptable_frame admit_all pvid 1 config port_vlan 2:2-2:8,2:12-2:16,2:19-2:20 gvrp_state disable ingress_checking enable acceptable_frame admit_all pvid 12 config port_vlan 2:9-2:11,2:17-2:18,2:21-2:26 gvrp_state disable ingress_checking enable acceptable_frame admit_all pvid 11
# SUBNETVLAN
create subnet_vlan network 192.168.20.0/24 vlan Control priority 0 create subnet_vlan network 192.168.21.0/24 vlan WorkStations priority 0 create subnet_vlan network 192.168.22.0/24 vlan DigitalSignages priority 0 create subnet_vlan network 192.168.23.0/24 vlan ReservationMeetingRoom priority 0 create subnet_vlan network 192.168.24.0/24 vlan Videomonitoring priority 0 create subnet_vlan network 192.168.25.0/24 vlan ClassRoom priority 0 create subnet_vlan network 192.168.100.0/29 vlan Trunk_to_V1 priority 0 create subnet_vlan network 192.168.102.0/24 vlan Matrix priority 0
# IP
config ipif_mac_mapping ipif System mac_offset 0 config ipif System ipaddress 192.168.30.254/24 config ipif System vlan default config ipif_mac_mapping ipif iC mac_offset 1 create ipif iC 192.168.20.254/24 Control state enable config ipif iC proxy_arp disable local disable config ipif_mac_mapping ipif iM mac_offset 7 create ipif iM 192.168.102.254/24 Matrix state enable config ipif iM proxy_arp disable local disable config ipif_mac_mapping ipif iV mac_offset 5 create ipif iV 192.168.24.254/24 Videomonitoring state enable config ipif iV proxy_arp disable local disable config ipif_mac_mapping ipif iCR mac_offset 6 create ipif iCR 192.168.25.254/24 ClassRoom state enable config ipif iCR proxy_arp disable local disable config ipif_mac_mapping ipif iDS mac_offset 3 create ipif iDS 192.168.22.254/24 DigitalSignages state enable config ipif iDS proxy_arp disable local disable config ipif_mac_mapping ipif iWS mac_offset 2 create ipif iWS 192.168.21.254/24 WorkStations state enable config ipif iWS proxy_arp disable local disable config ipif_mac_mapping ipif iRMR mac_offset 4 create ipif iRMR 192.168.23.254/24 ReservationMeetingRoom state enable config ipif iRMR proxy_arp disable local disable config ipif_mac_mapping ipif Trunk_to_V1 mac_offset 8 create ipif Trunk_to_V1 192.168.100.2/29 Trunk_to_V1 state enable config ipif Trunk_to_V1 proxy_arp disable local disable config ipif iC ip_mtu 1500 config ipif iM ip_mtu 1500 config ipif iV ip_mtu 1500 config ipif iCR ip_mtu 1500 config ipif iDS ip_mtu 1500 config ipif iWS ip_mtu 1500 config ipif iRMR ip_mtu 1500 config ipif System ip_mtu 1500 config ipif Trunk_to_V1 ip_mtu 1500 config ipif iC ip_directed_broadcast disable config ipif iM ip_directed_broadcast disable config ipif iV ip_directed_broadcast disable config ipif iCR ip_directed_broadcast disable config ipif iDS ip_directed_broadcast disable config ipif iWS ip_directed_broadcast disable config ipif iRMR ip_directed_broadcast disable config ipif System ip_directed_broadcast disable config ipif Trunk_to_V1 ip_directed_broadcast disable disable autoconfig
# ROUTE
config route preference static 60 config route preference rip 100 config route preference default 1 config route preference ospfIntra 80 config route preference ospfInter 90 config route preference ospfExt1 110 config route preference ospfExt2 115 config route preference ebgp 70 config route preference ibgp 130 create iproute 192.168.10.0/255.255.255.0 192.168.100.1 1 primary create iproute 192.168.11.0/255.255.255.0 192.168.100.1 1 primary create iproute 192.168.12.0/255.255.255.0 192.168.100.1 1 primary create iproute 192.168.13.0/255.255.255.0 192.168.100.1 1 primary create iproute 192.168.14.0/255.255.255.0 192.168.100.1 1 primary create iproute 192.168.15.0/255.255.255.0 192.168.100.1 1 primary create iproute 192.168.101.0/255.255.255.0 192.168.100.1 1 primary config ecmp algorithm ip_destination crc_low enable ecmp ospf
2. Коммутатор доступа 1210
System name : SW-3-2 System Contact : System Location : System up time : 7 days, 2 hrs, 29 min, 9 secs System Time : 14/09/2017 16:03:14 System hardware version : C1 System firmware version : 4.10.004 System boot version : 1.00.016 System serial number : S34L1H1000148 MAC Address : 10-62-EB-F9-22-C4
Настройки vlan DGS-1210 в приложении.
| Вложения: |
vlan 1210.jpg [ 120.86 KiB | Просмотров: 3279 ]
