Текущее время: Вс ноя 08, 2026 05:54
СообщениеДобавлено: Пт июн 02, 2017 17:42
Доброго времени суток.
С роутером происходят проблемы.
Он категорически не хочет подключаться к pppoe, логин и пароль введены верно ибо с обоих компьютеров они в полне работают.
Планета горит зелёным цветом, но стоит подключиться любому устройству Загорается оранжевым.
Вот логи:
Jun 1 23:16:58 PPPoE: Sending PADI for session1.
Jun 1 23:16:57 Remote management is disabled.
Jun 1 23:16:57 Block WAN PING is enabled.
Jun 1 23:16:57 DMZ disabled.
Jun 1 23:16:56 VPN (L2TP) Pass-Through enabled.
Jun 1 23:16:56 VPN (IPSec) Pass-Through enabled.
Jun 1 23:16:56 VPN (PPTP) Pass-Through enabled.
Jun 1 23:16:56 Domain blocking disabled.
Jun 1 23:16:56 URL blocking disabled.
Jun 1 23:16:56 MAC filter disabled.
Jun 1 23:16:55 PPPoE: Sending PADT for session1. (Session ID: 198)
Jun 1 23:16:54 PPP: Connection terminated.
Jun 1 23:16:54 CHAP authentication failed.
Jun 1 23:16:53 PPPoE: Received PADS for session1. (Session ID: 198)
Jun 1 23:16:53 PPPoE: Sending PADR for session1.
Jun 1 23:16:53 PPPoE: Received PADO for session1, from 0c:a4:02:17:b5:56.
Jun 1 23:16:53 PPPoE: Sending PADI for session1.
Jun 1 23:16:52 Remote management is disabled.
Jun 1 23:16:52 Block WAN PING is enabled.
Jun 1 23:16:51 DMZ disabled.
Jun 1 23:16:51 VPN (L2TP) Pass-Through enabled.
Jun 1 23:16:51 VPN (IPSec) Pass-Through enabled.
Jun 1 23:16:51 VPN (PPTP) Pass-Through enabled.
Jun 1 23:16:51 Domain blocking disabled.
Jun 1 23:16:51 URL blocking disabled.
Jun 1 23:16:51 MAC filter disabled.
Jun 1 23:16:50 PPPoE: Sending PADT for session1. (Session ID: 238)
Jun 1 23:16:49 PPP: Connection terminated.
Jun 1 23:16:49 CHAP authentication failed.
Jun 1 23:16:48 PPPoE: Sending PADR for session1.
Jun 1 23:16:48 PPPoE: Received PADO for session1, from a0:f3:e4:04:6d:56.
Jun 1 23:16:48 PPPoE: Sending PADI for session1.
Jun 1 23:16:47 Remote management is disabled.
Jun 1 23:16:47 Block WAN PING is enabled.
Jun 1 23:16:47 DMZ disabled.
Jun 1 23:16:47 VPN (L2TP) Pass-Through enabled.
Jun 1 23:16:47 VPN (IPSec) Pass-Through enabled.
Jun 1 23:16:47 VPN (PPTP) Pass-Through enabled.
Настройки сбрасывались и не раз, нет вообще никаких результатов.
Что странно, проверяли в другом доме у того же провайдера и с другими логином и паролем, роутер работает.
Звонили оператору, говорят что все в норме.
СообщениеДобавлено: Пт июн 02, 2017 21:21
А вы с других устройств тоже ппое подключаете?
Или как ваши устройства подключаются?
СообщениеДобавлено: Пт июн 02, 2017 22:19
Использую только ппое, другие подключения оператор не поддерживает
СообщениеДобавлено: Сб июн 03, 2017 07:47
Судя по повторяющемуся сообщению в логах "CHAP authentication failed", все же какая-то проблема с логином/паролем. Также возможно у провайдера используется привязка по MAC, попробуйте нажать "Клонировать MAC-адрес".
Сейчас этот форум просматривают: Baidu [Spider], Google [Bot] и гости: 15
