Текущее время: Сб сен 05, 2026 23:11
 Заголовок сообщения: DGS-3627: errormsg = PCI_Init failed!
СообщениеДобавлено: Пн июл 25, 2016 09:38
Доброго времени суток!
Беда случилась с одним из DGS-3627:
Boot Procedure 1.10-B09
Power On Self Test ...................................... 100 %
MAC Address : 00-22-B0-20-98-00
H/W Version : A1
Please wait, loading V3.00.B40 Runtime image ............ 100 %
Module Name = UNKNOWN
OS_Fatal_Error_Handler :
Current Stack Pointer = 5A721D4
!! System in EXCEPTION MODE !!!
Prom: 1.10-B09, Runtime:
PAUSE System Exception:
Pause source code : 1
Current Task: Init
Current Stack Pointer : 05A721C4
05A721C4 : 05A721D4 00020938 05A721D4 0002A044
05A721D4 : 05A72264 0000D198 0002A044 80808080
05A721E4 : FEFEFEFF 001CD7CC 574E0000 00000008
05A721F4 : 05A720C4 00000040 01000000 05A7226C
05A72204 : 05A721DC 5043495F 496E6974 20666169
05A72214 : 6C656421 00000012 033C45B8 00000000
05A72224 : 05A7223C 001CD334 00000000 F0000000
05A72234 : 00000000 00000020 05A72264 00006960
05A72244 : FFFFFFFF 00000000 00000000 00000000
05A72254 : 00000000 00000000 00000000 00000000
05A72264 : 05A7227C 00029E58 000254CC 00000000
05A72274 : 00000000 00000000 05A72284 000254F8
05A72284 : A5A5A5A5 00000000 A5A5A5A5 A5A5A5A5
05A72294 : 454E424B 00000003 00893775 00000000
05A722A4 : 00000000 00000000 00000000 00000000
05A722B4 : 00000000 00000000 05A7227C 05A39154
05A722C4 : 00000000 00000000 00000000 00000000
05A722D4 : 00000000 00000000 00000000 00000000
05A722E4 : 00000000 00000000 00000000 00000000
05A722F4 : 00000000 00000000 05A722BC 05A39154
05A72304 : 00000000 00000000 00000000 00000000
05A72314 : 00000000 00000000 00000000 00000000
05A72324 : 00000000 00000000 00000000 00000000
05A72334 : 00000000 00000000 05A722FC 05A39154
05A72344 : 00000000 00000000 00000000 00000000
05A72354 : 00000000 00001000 00000000 00000000
05A72364 : 00000000 00000000 00000000 00000000
05A72374 : 00000000 00000000 05A7233C 05A39154
05A72384 : 00000000 00000000 00000000 00000000
05A72394 : 00000000 00000000 00000000 00000000
05A723A4 : 00000000 00000000 00000000 00000000
05A723B4 : 00000000 00000000 05A7237C 05A39154
The relation of function calling:
000254F8
00029E58
0000D198
00020938
TCD_Interrupt_Level=00000000 Interrrupt Disabled
TCD_Current_Thread=058EA94C Thread name=Init
TCD_Execute_Task=058EA94C Current Task=Init
TCD_Execute_HISR=00000000
TCD_System_Stack=04BB080C
Все кулеры работают, электролиты выглядят нормальными. Как лечить?
 Заголовок сообщения: Re: DGS-3627: errormsg = PCI_Init failed!
СообщениеДобавлено: Вт июл 26, 2016 14:33
Обратитесь, пожалуйста, в сервисный центр.
СообщениеДобавлено: Пн янв 09, 2017 14:55
У меня тоже самое. Ответ понятен.
СообщениеДобавлено: Ср фев 15, 2017 00:38
Смотрите RT9164A на процессорном модуле, замена обычно помогает.
СообщениеДобавлено: Пн фев 27, 2017 11:37
Не только, и даже не столько это.
СообщениеДобавлено: Ср мар 01, 2017 02:21
Дык поделитесь своим опытом, на то и форум.
В моем случае нескольким коммутаторам это помогло, аптайм вылеченных уже скоро за год перевалит.
Второй по распространенности после электролитов вариант.
СообщениеДобавлено: Ср мар 01, 2017 09:52
Если разговор про DGS-3627G, то - убрать R117, заменить U24, U20, U25
cron
