Текущее время: Сб авг 29, 2026 12:39
СообщениеДобавлено: Чт дек 15, 2016 07:20
Добрый день!
На DGS-3420-26SC собрано 2 полукольца, где 23 порт общий.
Настроил ERPS на версии DGS3420_Run_1_70_B018.had
 create erps raps_vlan 215
 config erps raps_vlan 215 timer holdoff_time 0 guard_time 500 wtr_time 5
 config erps raps_vlan 215 rpl_port none
 config erps raps_vlan 215 rpl_owner disable
 config erps raps_vlan 215 ring_mel 1
 config erps raps_vlan 215 revertive  enable
 config erps raps_vlan 215 ring_port west 22
 config erps raps_vlan 215 ring_port east 23
 config erps raps_vlan 215 protected_vlan add vlanid 1-214
 config erps raps_vlan 215 protected_vlan add vlanid 216-1000
 create erps raps_vlan 216
 config erps raps_vlan 216 timer holdoff_time 0 guard_time 500 wtr_time 5
 config erps raps_vlan 216 rpl_port none
 config erps raps_vlan 216 rpl_owner disable
 config erps raps_vlan 216 ring_mel 1
 config erps raps_vlan 216 revertive  enable
 config erps raps_vlan 216 ring_port west 21
 config erps raps_vlan 216 ring_port east virtual_channel
 config erps raps_vlan 216 protected_vlan add vlanid 1-215
 config erps raps_vlan 216 protected_vlan add vlanid 217-1000
 config erps raps_vlan 215 add sub_ring raps_vlan 216
 config erps raps_vlan 215 sub_ring raps_vlan 216 tc_propagation state enable
 config erps raps_vlan 215 state enable
 config erps raps_vlan 216 state enable
 enable erps
 config erps log enable
 config erps trap enable
Всё работает.
Обновился до DGS3420_Run_1_82_B004.had
Конфиг сконвертировался и стал таким
 config erps version g.8032v1
 create erps ring ring_215
 config erps ring ring_215 ring_port west 22
 config erps ring ring_215 ring_port east 23
 config erps ring ring_215 ring_id 1
 config erps ring ring_215 add instance 1
 config erps instance 1 raps_vlan 215
 config erps instance 1 protected_vlan add vlanid 1-214
 config erps instance 1 protected_vlan add vlanid 216-1000
 create erps ring ring_216
 config erps ring ring_216 ring_port west 21
 config erps ring ring_216 ring_port east virtual_channel
 config erps ring ring_216 ring_type sub_ring
 config erps ring ring_216 ring_id 1
 config erps ring ring_216 add instance 2
 config erps instance 2 raps_vlan 216
 config erps instance 2 protected_vlan add vlanid 1-215
 config erps instance 2 protected_vlan add vlanid 217-1000
 config erps instance 1 add sub_ring_instance 2
 config erps instance 1 state enable
 config erps instance 2 state enable
 enable erps
Тоже вроде работает, но ring_id для обоих полуколец = 1
Для ring_216 сделал ring_id 2 и в этом полукольце порт west стал послоянно заблокированным.
Пытаюсь вернуть ring_id сделать снова 1 - ругается:
Different physical ring must be assigned different value of the ring IDs.
Fail!
Помогите разобраться, как всё-таки правильно настроить конфигурацию с сабрингом.
Сейчас этот форум просматривают: Google [Bot] и гости: 16
