Текущее время: Вт авг 18, 2026 10:19
 Заголовок сообщения: DIR-300
СообщениеДобавлено: Вт сен 27, 2016 11:11
Добрый день. Есть ДИР-300C1B После неудачного обновления роутер полностью встал, подключился к нему по ком порту, он выдал следующее:
========== SPI =============
SDRAM CLOCK:156MHZ
------------------------- Force into Single IO Mode ------------------------
|No chipID Sft chipSize blkSize secSize pageSize sdCk opCk chipName |
| 0 c22016h 0h 400000h 10000h 1000h 100h 86 39 MX25L3205D/E|
---RealTek(RTL8196C)at 2012.05.30-11:54+0000 version v1.2 [16bit](390MHz)
no sys signature at 00010000!
no sys signature at 00020000!
no sys signature at 00011000!
no sys signature at 00012000!
no sys signature at 00013000!
no sys signature at 00014000!
no sys signature at 00015000!
no sys signature at 00016000!
no sys signature at 00017000!
no sys signature at 00018000!
no sys signature at 00019000!
no sys signature at 0001A000!
no sys signature at 0001B000!
no sys signature at 0001C000!
no sys signature at 0001D000!
no sys signature at 0001E000!
no sys signature at 0001F000!
no sys signature at 00021000!
no sys signature at 00022000!
no sys signature at 00023000!
no sys signature at 00024000!
no sys signature at 00025000!
no sys signature at 00026000!
no sys signature at 00027000!
no sys signature at 00028000!
no sys signature at 00029000!
no sys signature at 0002A000!
no sys signature at 0002B000!
no sys signature at 0002C000!
no sys signature at 0002D000!
no sys signature at 0002E000!
no sys signature at 0002F000!
no sys signature at 00031000!
no sys signature at 00032000!
no sys signature at 00033000!
no sys signature at 00034000!
no sys signature at 00035000!
no sys signature at 00036000!
no sys signature at 00037000!
no sys signature at 00038000!
no sys signature at 00039000!
no sys signature at 0003A000!
no sys signature at 0003B000!
no sys signature at 0003C000!
no sys signature at 0003D000!
no sys signature at 0003E000!
no sys signature at 0003F000!
no sys signature at 00040000!
Set 8196C PHY Patch OK
---Ethernet init Okay!
<RealTek>
И переходит в глухую оборону, другие модельки перешиваются проблем нет, а на этой в частности не могу понять как в нее запихать прошивку.
Не поможите в данной проблемке?
 Заголовок сообщения: Re: DIR-300
СообщениеДобавлено: Вт сен 27, 2016 14:29
По логам похоже, что роутер в аварийном режиме. Настройте статику на компе и попробуйте зайти по адресу роутера.
-Полезные настройки
-FAQ по разделу
-FAQ по роутерам на сайте
Наша почта: support@dlink.ru
СообщениеДобавлено: Ср сен 28, 2016 04:18
Добрый день, пинг через ван или лан порт не помог (его просто нет), 192.168.1.1, 192.168.0.1, 10.10.10.123. DHCP роутер тоже не раздает.
СообщениеДобавлено: Ср сен 28, 2016 08:16
Если роутер в аварийном режиме, пинга не будет и dhcp-сервер на нем не работает. Поставьте на компе вручную 192.168.0.2 и попробуйте зайти на вэбку роутера. Если не сработает, то остается только программатор.
СообщениеДобавлено: Ср сен 28, 2016 08:55
Не помогло, подскажите тогда ближайший сервис к г.Абакан ? если есть такая возможность
СообщениеДобавлено: Ср сен 28, 2016 09:00
http://www.dlink.ru/ru/contacts/
СообщениеДобавлено: Ср сен 28, 2016 09:49
Если он негарантийный, то нет смысла в сервис его нести. Его не примут. Нерентабельно будет ни вам, ни ДЛинку.
СообщениеДобавлено: Ср сен 28, 2016 10:10
Принять то его примут, только стоить будет восстановление минимум 20$.
-Полезные настройки
-FAQ по разделу
СообщениеДобавлено: Ср сен 28, 2016 11:11
20 долларов для того чтобы перешить флэш с образа....., да уж, к сожалению тогда я разочарован.
СообщениеДобавлено: Ср сен 28, 2016 11:15
Это минимальная сумма любого негарантийного ремонта, к сожалению. По крайней мере в наших СЦ. Как вариант, можно купить какой-нибудь USB-UART девайс и залить образ через него. Но это уже на ваш страх и риск.
Кстати, не пробовали вот такой вариант - viewtopic.php?f=3&t=70046 ?
-Полезные настройки
-FAQ по разделу
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 49
