Текущее время: Пн сен 07, 2026 04:37
СообщениеДобавлено: Пн июн 20, 2016 11:23
Есть схема:
DGS-3612G (1) -> DGS-3120-24TC (2)
На (1) 4 интерфейса:
  • SRC - источник мультикаста
  • ISM- заготовка для ISM vlan
  • U1 - пользовательская подсеть 1
  • U2 - пользовательская подсеть 2
Настроен pim-sm:
Command: show pim
PIM Global State          : Enabled
Last Hop SPT Switchover   : Never
Register Probe Time       : 5
Register Suppression Time : 60
PIM Interface Table
                                Designated      Hello    J/P
Interface    IP Address         Router          Interval Interval Mode  State
U2           10.3.0.1/25        10.3.0.1        30       60       SM    Disabled
ISM          10.2.0.1/24        10.2.0.1        30       60       SM    Enabled
U1           10.1.0.1/25        10.1.0.1        30       60       SM    Enabled
SRC          192.168.0.1/24     192.168.0.1     30       60       SM    Enabled
Настроен igmp:
Command: show igmp
IGMP Interface Configurations
Interface    IP Address/Netmask  Ver- Query  Maximum  Robust- Last     State
                                 sion        Response ness    Member
                                             Time     Value   Query
                                                              Interval
U2           10.3.0.1/25         2    125    10       2       1        Enabled
ISM          10.2.0.1/24         2    125    10       2       1        Enabled
U1           10.1.0.1/25         2    125    10       2       1        Enabled
SRC          192.168.0.1/24      2    125    10       2       1        Disabled
Настроен igmp_snooping:
Command: show igmp_snooping
 IGMP Snooping Global State       : Enabled
 Multicast router Only            : Disabled
 VLAN  Name                    : SRC
 Query Interval                : 125
 Max Response Time             : 10
 Robustness Value              : 2
 Last Member Query Interval    : 1
 Host Timeout                  : 260
 Router Timeout                : 260
 Leave Timer                   : 2
 Querier State                 : Disabled
 Querier Router Behavior       : Non-Querier
 State                         : Enabled
 Fast Leave                    : Disabled
 Report Suppression            : Disabled
 Receive Query Count           : 0
 Send Query Count              : 0
 Version                       : 3
 VLAN  Name                    : ISM
 Host Timeout                  : 260
 Leave Timer                   : 2
 State                         : Enabled
 Version                       : 3
 VLAN  Name                    : U2
 Host Timeout                  : 260
 Leave Timer                   : 2
 State                         : Enabled
 Receive Query Count           : 33
 Version                       : 3
 VLAN  Name                    : U1
 Host Timeout                  : 260
 Leave Timer                   : 2
 State                         : Enabled
 Version                       : 3
На (2) настроен igmp_snooping:
 Data Driven Learning Max Entries        : 128
 VLAN Name                     : ISM
 Querier State                 : Enabled
 Querier Role                  : Non-Querier
 Querier IP                    : 10.2.0.1
 Querier Expiry Time           : 137 secs
 State                         : Enabled
 Rate Limit(pkt/sec)           : No Limitation
 Proxy Reporting               : Disabled
 Proxy Reporting Source IP     : 0.0.0.0
 Version                       : 3
 Data Driven Learning State    : Enabled
 Data Driven Learning Aged Out : Disabled
 Data Driven Group Expiry Time : 260
 VLAN Name                     : U2
 Querier IP                    : 10.3.0.1
 Querier Expiry Time           : 202 secs
 State                         : Enabled
 Version                       : 3
 VLAN Name                     : U1
 Querier IP                    : 10.1.0.1
 Querier Expiry Time           : 211 secs
 State                         : Enabled
 Version                       : 3
 Data Driven Learning State    : Disabled
И ISM Vlan:
 Command: show igmp_snooping multicast_vlan
IGMP Multicast VLAN Global State        : Enabled
IGMP Multicast VLAN Forward Unmatched   : Enabled
VLAN Name                     :ISM
VID                           :401
Member(Untagged) Ports        :1:1
Tagged Member Ports           :
Source Ports                  :1:17
Untagged Source Ports         :
Status                        :Enabled
Replace Source IP             :10.2.0.75     (User Configure)
Remap Priority                :5  (Not Replaced)
В такой конфигурации мультикаст работает на (2) в обоих сетях, но трафик дублируется на аплинке.
Пытаюсь заставить идти трафик через ISM, но запросы все равно идут через основные сети.
На (1) выключаю pim/igmp для U2. По логике трафик должен начать идти через ISM, но этого не происходит.
Если я верно понимаю, необходимо:
  • отключить pim/igmp/igmp_snooping для U1/U2 на (1)
  • отключить igmp_snooping для U1/U2 на (2)
И трафик должен будет пойти через ISM. Но этого не происходит.
Для проверки пробовал настраивать ISM как обычный вилан, трафик через него идет.
Для настройки использовал инструкции с http://www.dlink.ru/up/faq/58/267.html
Может я что-то упускаю, как заставить его работать?
P/S: пытался заставить одну сеть работать с ISM, после отключения igmp_snooping в U2 на (2) получил тройное кол-во мультикаст трафика на аплинке.
Заранее спасибо.
Последний раз редактировалось zero-light Пн июн 20, 2016 12:49, всего редактировалось 1 раз.
СообщениеДобавлено: Пн июн 20, 2016 11:38
Если у вас клиенты не подключаются непосредственно в DGS-3612G - то ISM vlan на нем не нужен.
На L3 вы маршрутизируете мультикаст из одного vlan в другой, и этот второй vlan не должен быть настроен как ISM. Данные настройки выполняются только на коммутаторах доступа.
СообщениеДобавлено: Пн июн 20, 2016 12:46
Да, все верно. На L3 он обычный вилан, с 1 тегированным портом к которому подключена вторая железка.
VID             : 401             VLAN Name     : ISM
VLAN Type       : Static          Advertisement : Disabled
Member Ports    : 12
Static Ports    : 12
Current Tagged Ports  : 12
Current Untagged Ports:
Static Tagged Ports   : 12
Static Untagged Ports :
Forbidden Ports       :
СообщениеДобавлено: Пн июн 20, 2016 15:00
Смотрите презентацию.
Сейчас этот форум просматривают: Google [Bot] и гости: 30
