Текущее время: Сб авг 29, 2026 03:06
 Заголовок сообщения: Проблема с DGS-3120-24SC
СообщениеДобавлено: Вт май 31, 2016 09:08
Добрый день!
После ребута возникла проблема с данным коммутатором, перестал грузиться. В консоль выдает следующее
Boot Procedure V2.00.003
Power On Self Test ........................................ 100 %
MAC Address : D8-FE-E3-8B-4F-20
H/W Version : A2
Please Wait, Loading V3.00.022 Runtime Image .............. 100 %
UART init ................................................. 100 %
Starting runtime image
Device Discovery .......................................... 100 %
Configuration init ........................................ 100 %
Press any key to login...
H/W Version : A2
./src\drv_i2c.c(line572): Error! -->
_drv_i2c_Start, TIMEOUT after START at I2C_0
./src\drv_i2c.c(line664): Error! -->
_drv_i2c_Start, Need STOP to release bus to idle state.
./src\drv_i2c.c(line2334): Error! -->
drv_i2c_Detect,Failed on START stage in Read I2C OP
dev_eeprom.c(line395): Error! --> Initialize EEPROM chip driver failure! eeprom_id = 0, errstate = 0x00000003
prom_dev.c(line170): Error! --> DEV_EEPROM_Init fail!
dev_gpio.c(line555): Error! --> Initialize GPIO chip driver failure! gpio_id = 2, errstate = 0x00000003
./src\drv_i2c.c(line2130): Error! --> drv_i2c_read_dev,Failed on START stage in Read I2C OP
./src\drv_i2c.c(line2183): Error! -->
drv_i2c_read_dev, Bus receovering through STOP
prom_dev.c(line193): Error! --> DEV_LED_Init fail!
dev_rtc.c(line522): Error! --> Initialize RTC chip driver failure! rtc_id = 0, errstate = 0x00000003
prom_dev.c(line207): Error! --> DEV_RTC_Init fail!
utl_nif_Get_Info(line67): Get CPU Information Fail!
MAC Address : 00-01-02-03-04-00
H/W Version :
Please Wait, Loading V3.00.022 Runtime Image .............. 5 %
30 %
55 %
85 %
100 %
Initialize EEPROM chip driver failure! eeprom_id = 0, errstate = 0x00000003Read BoxType configuration fail!
 Заголовок сообщения: Re: Проблема с DGS-3120-24SC
СообщениеДобавлено: Вт май 31, 2016 09:23
Обратитесь в СЦ
СообщениеДобавлено: Пн дек 12, 2016 13:15
Аналогичная проблема с DES-3200-26/C1:
Boot Procedure V4.00.002
H/W Version :
Please Wait, Loading V4.46.B004 Runtime Image ............. 100 %
SRead BoxType configuration fail!ystem Warning : Fatal at: Ѓ †И(-2119936488) -> Project Pre-init fail!
System Warning : Fatal at: Ѓ †И(-2119936488) -> Box type not detected!
System Warning : Fatal at: Ѓ ЈL(-2119936488) -> DEV_EEPROM_Init fail!Initialize GPIO chip driver failure! gpio_id = 1, errstate = 0x00000003
./src\drv_i2c.c(line653): Error! -->
_drv_i2c_Start,TIMEOUT on retriving the bus status at I2C_0
prom_dev.c(line183): Error! --> DEV_EEPROM_Init fail!
Через Shift+3 заходит нормально, более того если обновить прошивку оттуда - нормально загружается до ребута, вспоминает свой mac вместо 00-01-02-03-04-00, загружает конфиг, сохраняет конфиг. Отключаю питание - всё по новой.
Может быть стоит обновить Boot PROM? Сейчас 4.00.002
