Текущее время: Пт дек 26, 2025 20:08
СообщениеДобавлено: Чт май 19, 2016 14:56
DGS-3627G/3612G БАГ при использовании ISM vlan + QinQ.
Device Type : DGS-3627G Gigabit Ethernet Switch
Boot PROM Version : Build 1.10-B09
Firmware Version : Build 3.00.B38
Hardware Version : A1
Serial Number : P1JN189000112
Настроено QinQ и ISM vlan.
ххх:admin#show igmp_snooping vlan IP_TV
Command: show igmp_snooping vlan IP_TV
IGMP Snooping Global State : Enabled
Multicast router Only : Enabled
VLAN Name : IP_TV
Query Interval : 125
Max Response Time : 10
Robustness Value : 3
Last Member Query Interval : 1
Host Timeout : 385
Router Timeout : 385
Leave Timer : 3
Querier State : Disabled
Querier Router Behavior : Non-Querier
State : Enabled
Fast Leave : Disabled
Report Suppression : Disabled
Receive Query Count : 14625
Send Query Count : 0
Version : 2
Total Entries: 1
ххх:admin#show igmp_snooping multicast_vlan IP_TV
Command: show igmp_snooping multicast_vlan IP_TV
VLAN Name : IP_TV
VID : 56
Member(Untagged) Ports :
Tagged Member Ports : 1-18,23
Source Ports : 19
Source(Untagged) Ports :
Status : Enabled
Replace Source IP : 0.0.0.0
Remap Priority : None
ххх:admin#
Соответственно в Vlan-ах ISM vlan не создан.
ххх:admin#show vlan vlanid 56
Command: show vlan vlanid 56
No valid VLAN entry in the list!
ххх:admin#
На части портов настроено QinQ.
ххх:admin#show qinq
Command: show qinq
QinQ Status : Enabled
ххх:admin#show qinq ports
Command: show qinq ports
Port Role Missdrop TPID Use Inner Priority
1 UNI Disabled 0x8100 Disabled
2 UNI Disabled 0x8100 Disabled
3 UNI Disabled 0x8100 Disabled
4 UNI Disabled 0x8100 Disabled
5 UNI Disabled 0x8100 Disabled
6 UNI Disabled 0x8100 Disabled
7 UNI Disabled 0x8100 Disabled
8 UNI Disabled 0x8100 Disabled
9 UNI Disabled 0x8100 Disabled
10 UNI Disabled 0x8100 Disabled
11 UNI Disabled 0x8100 Disabled
12 UNI Disabled 0x8100 Disabled
13 NNI Disabled 0x8100 Disabled
14 NNI Disabled 0x8100 Disabled
15 NNI Disabled 0x8100 Disabled
16 NNI Disabled 0x8100 Disabled
17 NNI Disabled 0x8100 Disabled
18 NNI Disabled 0x8100 Disabled
19 NNI Disabled 0x8100 Disabled
20 NNI Disabled 0x8100 Disabled
21 NNI Disabled 0x8100 Disabled
22 NNI Disabled 0x8100 Disabled
23 UNI Disabled 0x8100 Disabled
24 NNI Disabled 0x8100 Disabled
25 NNI Disabled 0x8100 Disabled
26 NNI Disabled 0x8100 Disabled
27 NNI Disabled 0x8100 Disabled
Для ISM прописано vlan_translation.
ххх:admin#show vlan_translation ports 1
Command: show vlan_translation ports 1
Port CVID SPVID Action Priority
1 1 1 Replace -
1 56 56 Replace -
1 820 820 Replace -
Total Entries: 16
При перезагрузке узла по питанию vlan_translation для ISM vlan слетает.
В Active и Boot_up команда есть но при перезагрузке она игнорируется.
# QINQ
config qinq ports 1-12,23 role uni missdrop disable tpid 0x8100
create vlan_translation ports 1-12,23 cvid 56 replace svid 56
СообщениеДобавлено: Пт май 20, 2016 12:19
У вас клиенты подключены непосредственно к DGS-3627?
Пришлите, пожалуйста, полный конфигурационный файл коммутатора мне на почту, а также укажите номера подключения клиента и аплинка.
После перезагрузки какие действия производите для восстановления работы?
СообщениеДобавлено: Пн май 23, 2016 09:10
НЕТ. DGS узел агрегации.
>Пришлите, пожалуйста, полный конфигурационный файл коммутатора мне на почту.
Выслал.
Вся информация уже есть выше.
VLAN Name : IP_TV
VID : 56
Tagged Member Ports : 1-18,23 - клиентские
Source Ports : 19 - uplink
Status : Enabled
ххх:admin#
Повторное создание vlan_translation.
Еще раз повторюсь, команда есть в загрузочном конфиге НО при загрузке она игнорируется
Судя по всему конфиг загружается построчно и блок "# VLAN" загружается до блока "# QINQ", а "# MULTICAST_VLAN" позже "# QINQ". Следовательпо при построчной загрузке конфига строка "create vlan_translation ports 1-12,23 cvid 56 replace svid 56" игнорируется т.к. такого Vlan еще нет. После загрузки всего конфига ISM Vlan 56 уже есть и команда выполняется корректно, но вводить ее нужно руками.
СообщениеДобавлено: Пн май 23, 2016 09:58
ISM vlan следует настраивать на коммутаторах доступа, если клиенты у вас не подключаются непосредственно в DGS-3627 - смысла в использовании ISM vlan нет, пробрасывайте этот vlan как обычный 802.1Q.
СообщениеДобавлено: Пн май 23, 2016 11:12
Вы шутите?
Если внимательно почитать форум в рекомендациях прокидывать ISM vlan именно так. Низлежащий коммутатор tag_member. В некоторых случаях и на других DGS мультикаст без ISM просто не работает. ISM на уровне агрегации СУЩЕСТВЕННО снизил нагрузку как на сам узел так и на низлежащие порты.
Я не прошу у вас консультации по настройке мультикаста, я сдаю вам проблему - НОРМАЛЬНО работающий мультикаст из за специфика загрузки конфига ломается при перезагрузке в схеме ISM + QinQ. При других схемах без QinQ на таких же узлах работает нормально.
СообщениеДобавлено: Пн май 23, 2016 11:32
Проблему я обязательно проверю, и если подтвердится - сообщу о ней разработчикам.
Пока что я предлагаю вам workaround - потому что в ISM vlan на агрегации, по сути, нет смысла.
СообщениеДобавлено: Пн май 23, 2016 11:49
Проблему подтверждаю, как будут новости - обязательно сообщу.
СообщениеДобавлено: Вт май 31, 2016 16:30
Проблему исправили в прошивке 3.00.B043, прошивка доступна в соответствующей теме.
СообщениеДобавлено: Ср июн 01, 2016 03:59
А 3.03 ветки этого бага нет?
С чем связанно то, что стало 2 ветки софта?
СообщениеДобавлено: Ср июн 01, 2016 11:02
Спасибо проверю.
СообщениеДобавлено: Ср июн 01, 2016 11:11
В ветке 3.03 этого бага нет, фикс делали для 3.00.
СообщениеДобавлено: Ср июн 01, 2016 12:50
СообщениеДобавлено: Ср июн 01, 2016 16:09
Подскажите разницу в ветках 3.00 и 3.03?
СообщениеДобавлено: Ср июн 01, 2016 16:21
Added configurable NAS-IP-Address.
Кто-то долгое время не хотел переходить с 2.84 на 3.00, так же и тут - кто-то остается на 3.00.
По сути, ветка осталась одна, был линейный апгрейд.
СообщениеДобавлено: Ср июн 01, 2016 16:45
Подскажите, пожалуйста, планируется ли релизная прошивка, и, соответственно, обновление release notes и документации для свичей серии DGS-36xx ?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 69
