Текущее время: Чт окт 29, 2026 19:54
 Заголовок сообщения: DVG-7022s IGMP Snooping
СообщениеДобавлено: Чт мар 17, 2016 14:21
На центральном коммутаторе (DGS-3120-48TC) включен IGMP Snooping, он является Querier-ом. Но при включении DVG-7022s в сеть эту функцию почему-то забирает DVG-7022s. В нем нет настроек IGMP Snooping, как заставить DVG-7022s не становится Querier-ом?
 Заголовок сообщения: Re: DVG-7022s IGMP Snooping
СообщениеДобавлено: Пт мар 18, 2016 16:53
Здравствуйте. Пришлите дамп трафика IGMP запросов.
СообщениеДобавлено: Чт мар 24, 2016 10:36
"No.","Time","Source","Destination","Protocol","Length","Info"
"291","9.160671000","192.168.0.180","224.0.0.252","LLMNR","62","Standard query 0x8833 A W8"
"292","9.161081000","192.168.0.180","224.0.0.252","LLMNR","62","Standard query 0xbb6f AAAA W8"
"302","9.579876000","192.168.0.180","224.0.0.252","LLMNR","62","Standard query 0x8833 A W8"
"303","9.580074000","192.168.0.180","224.0.0.252","LLMNR","62","Standard query 0xbb6f AAAA W8"
"307","9.965084000","192.168.0.181","224.0.0.252","LLMNR","62","Standard query 0x5da3 A W8"
"308","9.965580000","192.168.0.181","224.0.0.252","LLMNR","62","Standard query 0x9f34 AAAA W8"
"318","10.381581000","192.168.0.181","224.0.0.252","LLMNR","62","Standard query 0x5da3 A W8"
"319","10.381783000","192.168.0.181","224.0.0.252","LLMNR","62","Standard query 0x9f34 AAAA W8"
"454","17.308998000","192.168.0.107","239.255.255.250","SSDP","202","M-SEARCH * HTTP/1.1 "
"455","17.309200000","192.168.0.107","239.255.255.250","SSDP","202","M-SEARCH * HTTP/1.1 "
"1176","43.317244000","192.168.0.170","239.255.255.250","SSDP","557","NOTIFY * HTTP/1.1 "
"1177","43.317540000","192.168.0.170","239.255.255.250","SSDP","541","NOTIFY * HTTP/1.1 "
"1178","43.317743000","192.168.0.170","239.255.255.250","SSDP","486","NOTIFY * HTTP/1.1 "
"1179","43.317981000","192.168.0.170","239.255.255.250","SSDP","477","NOTIFY * HTTP/1.1 "
"1180","43.318241000","192.168.0.170","239.255.255.250","SSDP","529","NOTIFY * HTTP/1.1 "
"1181","43.318443000","192.168.0.170","239.255.255.250","SSDP","543","NOTIFY * HTTP/1.1 "
"1219","45.926979000","192.168.0.45","224.0.0.251","MDNS","83","Standard query 0x0000 PTR _sleep-proxy._udp.local, ""QM"" question"
"1222","46.317047000","192.168.0.170","239.255.255.250","SSDP","529","NOTIFY * HTTP/1.1 "
"1223","46.317250000","192.168.0.170","239.255.255.250","SSDP","557","NOTIFY * HTTP/1.1 "
"1224","46.317453000","192.168.0.170","239.255.255.250","SSDP","486","NOTIFY * HTTP/1.1 "
"1225","46.317658000","192.168.0.170","239.255.255.250","SSDP","477","NOTIFY * HTTP/1.1 "
"1226","46.317862000","192.168.0.170","239.255.255.250","SSDP","543","NOTIFY * HTTP/1.1 "
"1227","46.318067000","192.168.0.170","239.255.255.250","SSDP","541","NOTIFY * HTTP/1.1 "
"1452","49.317009000","192.168.0.170","239.255.255.250","SSDP","541","NOTIFY * HTTP/1.1 "
"1453","49.317209000","192.168.0.170","239.255.255.250","SSDP","486","NOTIFY * HTTP/1.1 "
"1454","49.317412000","192.168.0.170","239.255.255.250","SSDP","543","NOTIFY * HTTP/1.1 "
"1455","49.317617000","192.168.0.170","239.255.255.250","SSDP","529","NOTIFY * HTTP/1.1 "
"1456","49.317821000","192.168.0.170","239.255.255.250","SSDP","477","NOTIFY * HTTP/1.1 "
"1457","49.318025000","192.168.0.170","239.255.255.250","SSDP","557","NOTIFY * HTTP/1.1 "
"1707","52.853454000","192.168.0.45","224.0.0.251","MDNS","403","Standard query response 0x0000 PTR, cache flush avm-mxo2.local TXT, cache flush PTR _nvstream._tcp.local PTR AVM-MXO2._nvstream._tcp.local A, cache flush 192.168.0.45 SRV, cache flush 0 0 47989 avm-mxo2.local"
"2359","71.645313000","192.168.0.107","239.255.255.250","SSDP","202","M-SEARCH * HTTP/1.1 "
"2360","71.645516000","192.168.0.107","239.255.255.250","SSDP","202","M-SEARCH * HTTP/1.1 "
"3025","90.136682000","192.168.0.177","224.0.0.1","IGMPv3","60","Membership Query, general"
"3059","92.845150000","192.168.0.2","224.0.0.22","IGMPv3","62","Membership Report / Join group 231.0.0.1 for any sources / Join group 239.255.255.250 for any sources"
"4197","123.076517000","192.168.0.107","239.255.255.250","SSDP","202","M-SEARCH * HTTP/1.1 "
"4198","123.076716000","192.168.0.107","239.255.255.250","SSDP","202","M-SEARCH * HTTP/1.1 "
"4733","133.273666000","192.168.0.181","224.0.0.252","LLMNR","62","Standard query 0x0250 A W8"
"4734","133.274059000","192.168.0.181","224.0.0.252","LLMNR","62","Standard query 0x5cc2 AAAA W8"
"4736","133.684940000","192.168.0.181","224.0.0.252","LLMNR","62","Standard query 0x0250 A W8"
"4737","133.685146000","192.168.0.181","224.0.0.252","LLMNR","62","Standard query 0x5cc2 AAAA W8"
"4750","134.154831000","192.168.0.180","224.0.0.252","LLMNR","62","Standard query 0x293f A W8"
"4751","134.155252000","192.168.0.180","224.0.0.252","LLMNR","62","Standard query 0xa407 AAAA W8"
"4752","134.566634000","192.168.0.180","224.0.0.252","LLMNR","62","Standard query 0x293f A W8"
"4753","134.566832000","192.168.0.180","224.0.0.252","LLMNR","62","Standard query 0xa407 AAAA W8"
"5372","174.778435000","192.168.0.107","239.255.255.250","SSDP","202","M-SEARCH * HTTP/1.1 "
"5373","174.778632000","192.168.0.107","239.255.255.250","SSDP","202","M-SEARCH * HTTP/1.1 "
"5667","182.209051000","192.168.0.170","224.0.0.252","LLMNR","66","Standard query 0xa134 A isatap"
"5669","182.315173000","192.168.0.170","224.0.0.252","LLMNR","66","Standard query 0xa134 A isatap"
"6185","204.751029000","192.168.0.107","224.0.0.251","MDNS","75","Standard query 0x0000 A retracker.local, ""QM"" question"
"6321","205.752576000","192.168.0.107","224.0.0.251","MDNS","75","Standard query 0x0000 A retracker.local, ""QM"" question"
"6598","207.753929000","192.168.0.107","224.0.0.251","MDNS","75","Standard query 0x0000 A retracker.local, ""QM"" question"
"6829","211.755347000","192.168.0.107","224.0.0.251","MDNS","75","Standard query 0x0000 A retracker.local, ""QM"" question"
"6897","216.592910000","192.168.0.57","224.0.0.252","LLMNR","66","Standard query 0x4752 A isatap"
"6899","216.692100000","192.168.0.57","224.0.0.252","LLMNR","66","Standard query 0x4752 A isatap"
"7153","219.817647000","192.168.0.229","224.0.0.1","IGMPv3","60","Membership Query, general"
"7181","222.343999000","192.168.0.2","224.0.0.22","IGMPv3","62","Membership Report / Join group 231.0.0.1 for any sources / Join group 239.255.255.250 for any sources"
"7503","229.145229000","192.168.0.107","239.255.255.250","SSDP","202","M-SEARCH * HTTP/1.1 "
"7504","229.145433000","192.168.0.107","239.255.255.250","SSDP","202","M-SEARCH * HTTP/1.1 "
192.168.0.177 - это DVG-7022s
192.168.0.229 - это DGS-3120-48TC
Подключаю DVG-7022s в сеть, затем выключаю.
СообщениеДобавлено: Ср апр 13, 2016 11:33
Не решаемая проблема?
Сейчас этот форум просматривают: Google [Bot] и гости: 8
