Текущее время: Пн окт 05, 2026 10:03
Начать новую тему Ответить на тему  [ Сообщений: 485 ]  На страницу Пред.  1 ... 18, 19, 20, 21, 22, 23, 24 ... 33  След.
СообщениеДобавлено: Вс фев 21, 2016 13:43
Регулярно отваливается интернет.После разборок с провайдером выяснилось, отваливается Wi-Fi 2.4 Ggz.
На момент пропадания в логах присутствуют: "kernel: BIT(11) of 0xd2c = 1, 0xd2c = 0xcc97b975" или "BIT(11) of 0xd2c = 1, 0xd2c = 0xcc979975" что это значит?
Вот последний кусок, пока писал опять че-то насыпалось:
Feb 21 12:03:28 kernel: wlan1: A wireless client is associated - D0:DF:9A:FC:A4:E5
Feb 21 12:03:28 kernel: BIT(11) of 0xd2c = 1, 0xd2c = 0xcc979975
Feb 21 12:03:28 kernel: wlan1: WPA2-AES PSK authentication in progress...
Feb 21 12:03:28 kernel: wlan1: Open and authenticated
Feb 21 12:54:47 kernel: wlan1: A wireless client is disassociated - D0:DF:9A:FC:A4:E5
Feb 21 13:10:00 kernel: wlan0: A wireless client is associated - FC:64:BA:66:64:CF
Feb 21 13:10:00 kernel: BIT(11) of 0xd2c = 1, 0xd2c = 0xcc97b975
Feb 21 13:10:00 kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 21 13:10:00 kernel: wlan0: Open and authenticated
Feb 21 13:18:11 kernel: wlan1: A wireless client is associated - FC:64:BA:66:64:CF
Feb 21 13:18:11 kernel: BIT(11) of 0xd2c = 1, 0xd2c = 0xcc979975
Feb 21 13:18:11 kernel: wlan0: A STA is deleted by application program - FC:64:BA:66:64:CF
Feb 21 13:18:11 kernel: wlan1: WPA2-AES PSK authentication in progress...
Feb 21 13:18:11 kernel: wlan0: A wireless client is associated - FC:64:BA:66:64:CF
Feb 21 13:18:11 kernel: BIT(11) of 0xd2c = 1, 0xd2c = 0xcc97b975
Feb 21 13:18:11 kernel: wlan1: A STA is deleted by application program - FC:64:BA:66:64:CF
Feb 21 13:18:11 kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 21 13:18:11 kernel: wlan0: Open and authenticated
Feb 21 13:19:27 kernel: -------> Set MIB from /etc/Wireless/RTL8192CD.dat
Feb 21 13:19:29 kernel: <------- Set MIB from /etc/Wireless/RTL8192CD.dat Success
Feb 21 13:19:29 kernel: [PHY_ConfigMACWithParaFile][MACPHY_REG]
Feb 21 13:19:29 kernel: **********************************
Feb 21 13:19:29 kernel: ** NOTE!! RTL8192D INTERNAL PA! **
Feb 21 13:19:29 kernel: [phy_RF6052_Config_ParaFile][radio_a_intPA]
Feb 21 13:19:29 kernel: [phy_RF6052_Config_ParaFile][radio_b_intPA]
Feb 21 13:19:29 kernel: ===> Load_92D_Firmware
Feb 21 13:19:29 kernel: Firmware check 48004(0)
Feb 21 13:19:29 kernel: [Load_92D_Firmware][rtl8192dfw_n]
Feb 21 13:19:29 kernel: <=== Load_92D_Firmware
Feb 21 13:19:37 kernel: ===== dlink minChan=36=====
Feb 21 13:20:01 kernel: wlan0: A wireless client is associated - FC:64:BA:66:64:CF
Feb 21 13:20:01 kernel: BIT(11) of 0xd2c = 1, 0xd2c = 0xcc97b975
Feb 21 13:20:01 kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 21 13:20:01 kernel: wlan0: Open and authenticated
DIR-825/A/D1 Версия ПО: 20141211_1612_DIR_825_2.5.31_sdk-master
СообщениеДобавлено: Пн фев 22, 2016 17:31
Ноут/комп? Может помочь обновление драйвера адаптера, кстати. Мучался тоже поначалу. Можно еще перепрошить роутер ещё разок. Тут прошивка со своей особой атмосферой =)
СообщениеДобавлено: Вт фев 23, 2016 04:34
Те же самые проблемы с DIR-825/AC. Заводская прошивка разрывает соединение стабильно каждый 1-2 часа, иногда подряд разрыв за разрывом. Подключены 3 разных ПК патчкордами - везде разрыв. Помогает только перезагрузка роутера.
Пробовал обновить прошивку, скачал последнюю от сюда: http://dlink.ru/ru/products/5/1993_d.html - не получилось, пишет что некорректная прошивка, нигде замену с фиксом не нашел. Может у вас есть?
Я не специалист, точную причину так и не выяснил. Узнал только, что это распространенная проблема для этой модели. Причина точно не в кабеле, не в провайдере и не в пк. Грешу на DHCP, но там все настройки автоматические стоят и роутер сам получает все данные.
Что пишет в логах не пойму, да и пользоваться ими неудобно, не понятно в каких логах должны фиксироваться подобные разрывы.
Jan  1 00:00:07 miniupnpd[1063]: could not open lease file: /tmp/upnp.leases
Jan  1 00:00:11 dms_reset_uptime[1083]: enter key eth1_3
Jan  1 00:00:11 dms_reset_uptime[1083]: unable to remove file /tmp/stat.eth1_3
Помогите, если кто знает что с этим делать. Спасибо.
СообщениеДобавлено: Вт фев 23, 2016 11:11
fantezer, вам сюда - viewtopic.php?f=3&t=171128
DIR-825/A/D1A 3.0.0
СообщениеДобавлено: Вт фев 23, 2016 13:57
Спасибо, а я искал, не нашел.
СообщениеДобавлено: Вт фев 23, 2016 22:33
Pappett писал(а):
Странно, но вышеуказанную версию прошивки при обновлении он-лайн DIR825/A просто не видит, а когда скачиваешь и пытаешься ему подсунуть - ругается, что неверный файл прошивки.
"Вышеуказанную" - это какую конкретно? Вы отписались в двух темах по разным роутерам, уточните сначала свою модель.
DIR-825/A/D1A 3.0.0
СообщениеДобавлено: Чт фев 25, 2016 17:45
Вот папка с прошивками для вашего роутера - http://ftp.dlink.ru/pub/Router/DIR-825/Firmware/RevD/
Это в том случае, если вы определились и у вас роутер DIR-825/A/D1A, а не DIR-825AC/E1/A.
-Полезные настройки
-FAQ по разделу
-FAQ по роутерам на сайте
Наша почта: support@dlink.ru
СообщениеДобавлено: Чт фев 25, 2016 17:47
Да, все верно, спасибо. Значит, свежее нет, ясно.
DIR-825AC/G1 // MacOS 10.12.5
СообщениеДобавлено: Пт фев 26, 2016 12:20
Pappett, всё-таки проверьте ещё раз, что у вас именно DIR-825A, не DIR-815A и не DIR-825
DIR-825/A/D1A 3.0.0
СообщениеДобавлено: Пт мар 04, 2016 14:43
Я понимаю, что не в тему тут сейчас напишу немного. Но при стоимости роутера, вместо того, чтобы его сбагривать, найти точку доступа и через нее раздавать вифи. Но с AP дела не имел. Лишь однажды во времена dir-100 приделывал к нему нетгировский рутер (который не умел l2tp) такой же старый и раздавал вифи. Как вариант тем, у кого беда исключительно с вифи. Для себя я не знаю, что с роутером делать, т.к. мне бы VPN-сервер. Завел на системе пока с патчем от наших, чтобы больше 1 входящего подключения было. Но вот с точкой идея что-то прямо засела в голове. Какие нормальные по вменяемой цене есть, которые с нашим длинком будут нормально пахать? Любая, по идее должна же.
СообщениеДобавлено: Сб мар 05, 2016 15:36
Ну да, именно он.
СообщениеДобавлено: Сб апр 09, 2016 18:39
Ну как дела с прошивкой? VPN будут чинить? Я еще раз опишу проблему: жена работает иногда из дома по удаленке. У компании VPN сетка и после подключения к ней можно подключиться к компу по удалёнке. И на 38 прошивке не получалось подрубиться по VPN. На 31 все в порядке. Ну и вайфай, собственно. Или проще купить точку доступа, подключить к роутеру и раздавать беспровод через точку? И не ждать исправлений после 31 прошивки.
СообщениеДобавлено: Вс апр 10, 2016 03:48
wifi я исправил новым блоком питания на 12 вольт 2 ампера.
вообщем то теперь роутер полностью устраивает и сигнал стал по лучше, а самое главное теперь нет потерь пакетов по wi fi.
СообщениеДобавлено: Пт апр 22, 2016 12:20
О_о чей подошёл? Может реально в БП дело
СообщениеДобавлено: Пт апр 22, 2016 14:58
XIMERA, у вас в комплекте какой БП шел?
-Полезные настройки
-FAQ по разделу
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 80
