Текущее время: Вс сен 06, 2026 21:53
 Заголовок сообщения: Проблема с загрузкой DGS-3100-48
СообщениеДобавлено: Вт фев 16, 2016 16:03
Приветствую администрацию и посетителей.
Проблема с DGS-3100-48
Уходит в SYSTEM RESET с разными кодами.
Тему viewtopic.php?f=2&t=83211&start=300 я осилил, но она (тема), судя по всему, давно заглохла, поэтому начал новую.
Это лог номер раз
------ Performing the Power-On Self Test (POST) ------
UART Channel Loopback Test........................PASS
Testing the System SDRAM..........................PASS
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
BOOT Software Version 1.0.0.04 Built  24-Oct-2007  18:51:36
Network Switch based on 88E6218 with ARM946E-S.
64MByte SDRAM. I-Cache 8 KB. D-Cache 8 KB. Cache Enabled.
Preparing to decompress...
 100%
Decompressing SW from image-1
 100%
OK
Running from RAM...
*** Running  SW  Ver. 2.00.47  Date  02-Mar-2008  Time  12:13:22 ***
HW version is 00.01.04
Base Mac address is: 00:21:91:f1:b3:fe
Dram size is  : 64M bytes
Dram first block size is  : 45056K bytes
Dram first PTR is  : 0x1400000
Flash size is: 16M
01-Jan-2000 01:01:07 %CDB-I-LOADCONFIG: Loading running configuration.
01-Jan-2000 01:01:07 %CDB-I-LOADCONFIG: Loading startup configuration.
Device configuration:
CPLD revision:  b.00
Slot 1 - DGS-3100-48 HW Rev. 11.0
-- Unit Standalone                --
Running eeprom code for 98DX269 Dev 0. Please wait...
Running eeprom code for 98DX269 Dev 1. Please wait...
Tapi Version: v1.3.3.1
Core Version: v1.3.3.1
01-Jan-2000 01:01:54 %INIT-I-InitCompleted: Initialization task is completed
01-Jan-2000 01:01:54 %SNMP-I-CDBITEMSNUM: Number of running configuration items
loaded: 23
01-Jan-2000 01:01:54 %SNMP-I-CDBITEMSNUM: Nu01-Jan-2000 01:01:54 %OS-F-MEMORY: O
SMEMG_alloc_type: Either Start or End Pool Magic is invalid
***** FATAL ERROR *****
Reporting Task: SNMP.
Software Version: 2.00.47 (date  02-Mar-2008 time  12:13:22)
0x144370
0x1419d4
0x4d5ba0
0x331ff8
0x335980
0x4d98b8
0x3058e4
0x2c9aec
0x2ca944
0x2ca99c
0x2e0be0
0x2e0d4c
0x2e52d0
0x31f524
0x2ee2b0
0x2f1d10
0x2f2308
0x459b28
*****************  SYSTEM RESET  *****************
Это лог номер два
01-Jan-2000 01:01:54 %SNMP-I-CDBITEMSNUM: Number of startup configuration items
loaded: 23
01-Jan-2000 01:01:54 %MNG_DIAG01-Jan-2000 01:01:55
HOSTP_flash_operation: fatal error during read operation!
%OS-F-BUFFER: OSBUFG_buf_alloc: Buffer pool magic is invalid
Reporting Task: IPAT.
При прошивке на Бут 1.01.04 и 1.01.05 выдает ошибку 1030000.
Вроде как есть промежуточный (переходной на более высокие версии прошивки) бут, но я его по фтпишникам не нашел.
Более высокие версии прошивки заливает, но не стартует с такими же симптомами
 Заголовок сообщения: Re: Проблема с загрузкой DGS-3100-48
СообщениеДобавлено: Вт фев 16, 2016 17:54
Обратитесь в СЦ.
СообщениеДобавлено: Ср фев 17, 2016 10:27
Мне до СЦ очень долго ехать придётся. Есть альтернативные способы решения проблемы? Например, отправка бута 1.01.01?
СообщениеДобавлено: Сб фев 20, 2016 12:01
У Вас коммутатор постоянно в ребуте? или все-таки загружается и есть возможность залить другую прошивку?
СообщениеДобавлено: Ср мар 02, 2016 12:26
Возможность залить прошивку, естественно, есть. В системное меню я захожу без проблем. Прошивки перепробовал все ДОСТУПНЫЕ. 2.00.47, 3.00.43, 3.50.23, 3.60.45.
СообщениеДобавлено: Вт мар 15, 2016 15:47
Насколько я понял, данная тема благополучно игнорируется сотрудниками ДЛинка?
