Текущее время: Вт сен 29, 2026 06:03
 Заголовок сообщения: DES 1210-28 ME B2 ISM vlan
СообщениеДобавлено: Чт фев 11, 2016 08:28
коммутатор:
Device Type                       : DES-1210-28/ME
MAC Address                       : CC-B2-55-BF-0D-DE
IP Address                        : 10.0.0.5 (Manual)
VLAN Name                         : default
Subnet Mask                       : 255.255.255.0
Default Gateway                   : 10.0.0.1
System Boot Version               : 1.00.012
System Protocol Version           : 2.001.004
System Firmware Version           : 6.09.B009
System Hardware Version           : B2
System Serial Number              : QBM51C5003375
конфиг
# Multicast Filter
config multicast filter 1-24 filter
# ISM vlan
enable igmp_snooping multicast_vlan
create igmp_snooping multicast_vlan "iptv_abons" 51
config igmp_snooping multicast_vlan "iptv_abons" add member_port 1-24
config igmp_snooping multicast_vlan "iptv_abons" add tag_member_port 26-28
config igmp_snooping multicast_vlan "iptv_abons" add source_port 25
config igmp_snooping multicast_vlan "iptv_abons" state enable
config igmp_snooping multicast_vlan "iptv_abons" replace_source_ip 10.0.0.5
config mld_snooping multicast_vlan "iptv_abons" replace_source_ipv6 none
config igmp_snooping multicast_vlan "iptv_abons" remap_priority none
config igmp_snooping multicast_vlan "iptv_abons" source_port_dynamical_learn state disable
config igmp_snooping multicast_vlan_group "iptv_abons" add ipv4_range 226.100.10.1 226.100.10.254
config igmp_snooping multicast_vlan_group "iptv_abons" add ipv4_range 226.100.11.1 226.100.11.254
config igmp_snooping multicast_vlan_group "iptv_abons" add ipv4_range 233.12.144.1 233.12.144.254
config igmp_snooping multicast_vlan_group "iptv_abons" add ipv4_range 239.0.0.1 239.0.0.254
# IGMP snooping
config igmp_snooping vlanid 3,333 state disable fast_leave disable report_suppression enable
config igmp_snooping vlanid 51 state enable fast_leave disable report_suppression enable
config igmp_snooping data_driven_learning vlanid 3,51,333 state disable
config igmp_snooping data_driven_learning vlanid 3,51,333 aged_out disable
config igmp_snooping querier vlanid 3,51,333 state disable querier_version 2 last_member_query_interval 1 max_response_time 10 query_interval 125 robustness_variable 2
config router_ports vlan_name "iptv_abons" add 25
проблема в следующем:
к примеру:
имеется пул каналов мультикаста 226.100.10.1 -254.
абонент не может войти в некоторые группы из этого пула, на 3200-28 C1 все отрабатывает отлично.
обновление до 6.09.009 не помогло =(
 Заголовок сообщения: Re: DES 1210-28 ME B2 ISM vlan
СообщениеДобавлено: Чт фев 11, 2016 12:24
есть идеи ?
СообщениеДобавлено: Чт фев 11, 2016 12:58
Здравствуйте!
Попробуйте привязать список "iptv_abons" к клиентским портам, и поставьте permit.
DES-3028, DES-3526, DES-3200_28 C1/A1/B1, DES-3200_26 C1, DGS-3627G, DGS-3420-26SC A2, DGS-3420-28TC A1, DGS-3620-28SC A1-EI, DGS-3200-24 A1
