Текущее время: Пт авг 21, 2026 21:45
 Заголовок сообщения: 1210-28/ME/B2 Dying Gasp
СообщениеДобавлено: Ср ноя 11, 2015 15:56
Просьба подсказать как настроить dying gasp.
Схема такая:
DGS-3120-24SC-A1 Build 3.10.B028 port 1:6 <-> port 25 DES-1210-28/ME/B2 6.07.B086
Настройки/статус/статистика на DES-1210-28:
DES-1210-28/ME:5# show ethernet_oam ports 25 configuration
Command: show ethernet_oam ports 25 configuration
Port 25
OAM : Enabled
Mode : Active
Dying Gasp : Enabled
Critical Event : Enabled
Remote Loopback OAMPDU : Processed
Symbol Error
Notify State : Enabled
Window : 1000 milliseconds
Threshold : 1 Errored Symbol
Frame Error
Threshold : 1 Errored Frame
Frame Period Error
Window : 1488100 Frames
Frame Seconds Error
Window : 60000 milliseconds
Threshold : 1 Errored Seconds
DES-1210-28/ME:5# show ethernet_oam ports 25 status
Command: show ethernet_oam ports 25 status
Port 25
Local Client
OAM : Enabled
Mode : Active
Max OAMPDU : 1518 Bytes
Remote Loopback : Support
Unidirection : Not Supported
Link Monitoring : Support
Variable Request : Support
PDU Revision : 0
Operation Status : Operational
Loopback Status : No Loopback
Remote Client
Mode : Active
MAC Address : 84:c9:b2:ac:89:a6
Vendor (OUI) : 00:05:5d
Variable Request : Not Supported
PDU Revision : 0
DES-1210-28/ME:5# show ethernet_oam ports 25 statistics
Command: show ethernet_oam ports 25 statistics
Port 25
Information OAMPDU Tx : 41
Information OAMPDU Rx : 35
Unique Event Notification OAMPDU Tx : 0
Unique Event Notification OAMPDU Rx : 0
Duplicate Event Notification OAMPDU Tx: 0
Duplicate Event Notification OAMPDU Rx: 0
Loopback Control OAMPDU Tx : 0
Loopback Control OAMPDU Rx : 0
Variable Request OAMPDU Tx : 0
Variable Request OAMPDU Rx : 0
Variable Response OAMPDU Tx : 0
Variable Response OAMPDU Rx : 0
Organization Specific OAMPDUs Tx : 0
Organization Specific OAMPDUs Rx : 0
Unsupported OAMPDU Tx : 0
Unsupported OAMPDU Rx : 0
Frames Lost Due To OAM : 0
Настройки/статус/статистика на DGS-3120-24SC:
DGS-3120-24SC:admin#show ethernet_oam ports 1:6 configuration
Command: show ethernet_oam ports 1:6 configuration
Port 1:6
OAM : Enabled
Mode : Active
Remote Loopback OAMPDU : Not Processed
Symbol Error
Threshold : 1 Error Symbol
Frame Error
Threshold : 1 Error Frame
Frame Period Error
Frame Seconds Error
Threshold : 1 Error Seconds
DGS-3120-24SC:admin#show ethernet_oam ports 1:6 statistics
Command: show ethernet_oam ports 1:6 statistics
Port 1:6
Information OAMPDU TX : 686
Information OAMPDU RX : 671
Unique Event Notification OAMPDU TX : 0
Unique Event Notification OAMPDU RX : 0
Duplicate Event Notification OAMPDU TX: 0
Duplicate Event Notification OAMPDU RX: 0
Loopback Control OAMPDU TX : 0
Loopback Control OAMPDU RX : 0
Variable Request OAMPDU TX : 0
Variable Request OAMPDU RX : 0
Variable Response OAMPDU TX : 0
Variable Response OAMPDU RX : 0
Organization Specific OAMPDUs TX : 0
Organization Specific OAMPDUs RX : 0
Unsupported OAMPDU TX : 0
Unsupported OAMPDU RX : 0
DGS-3120-24SC:admin#show ethernet_oam ports 1:6 status
Command: show ethernet_oam ports 1:6 status
Port 1:6
Local Client
OAM : Enabled
Mode : Active
Remote Loopback : Supported
Link Monitoring : Supported
PDU Revision : 0
Remote Client
Mode : Active
MAC Address : F8-E9-03-DD-6D-59
Vendor (OUI) : 00055d
Variable Request : Supported
PDU Revision : 0
Vendor Info : 0
Дергаем питание на 1210
На 3120 в обычный лог ничего, кроме падения порта не прилетает. В show ethernet_oam ports 1:6 event_log всё по 0
Пробовали подключать по меди и по оптике.
 Заголовок сообщения: Re: 1210-28/ME/B2 Dying Gasp
СообщениеДобавлено: Пн ноя 16, 2015 16:00
Какой командой настраиваете dying gasp на 1210?
Пример команды: config ethernet_oam ports 28 state enable mode active remote_loopback stop received_remote_loopback ignore
СообщениеДобавлено: Вт ноя 17, 2015 10:32
# Ethernet OAM
config ethernet_oam ports 1-24 state disable mode active remote_loopback stop received_remote_loopback ignore
config ethernet_oam ports 1-28 critical_link_event dying_gasp notify_state enable
config ethernet_oam ports 1-28 critical_link_event critical_event notify_state enable
config ethernet_oam ports 25-28 state enable mode active remote_loopback stop received_remote_loopback process
config ethernet_oam ports 1-28 link_monitor error_symbol threshold 1 window 1000 notify_state enable
config ethernet_oam ports 1-28 link_monitor error_frame threshold 1 window 1000 notify_state enable
config ethernet_oam ports 1-28 link_monitor error_frame_seconds threshold 1 window 60000 notify_state enable
config ethernet_oam ports 1-24 link_monitor error_frame_period threshold 1 window 148810 notify_state enable
config ethernet_oam ports 25-28 link_monitor error_frame_period threshold 1 window 1488100 notify_state enable
