Текущее время: Пт сен 18, 2026 03:59
 Заголовок сообщения: OpenSSH DES-3200 DGS-3620 DGS-3000
СообщениеДобавлено: Чт ноя 05, 2015 09:27
Здравствуйте.
Есть коммутатор
Device Type : DES-3200-28 Fast Ethernet Switch
Boot PROM Version : Build 4.00.002
Firmware Version : Build 4.39.B015
Hardware Version : C1
SSH Status : Enabled (TCP 22)
После очередного обновления пакета OpenSSH на компьютере (до версии 7.1) стало невозможно подключиться к вышеприведённому коммутатору:
user@localhost ~ $ ssh -v admin@172.16.1.2
OpenSSH_7.1p1-hpn14v9, OpenSSL 1.0.2d 9 Jul 2015
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Connecting to 172.16.1.2 [172.16.1.2].
debug1: Connection established.
debug1: identity file /home/alex/.ssh/id_rsa type 1
debug1: key_load_public: No such file or directory
debug1: identity file /home/alex/.ssh/id_rsa-cert type -1
debug1: identity file /home/alex/.ssh/id_dsa type -1
debug1: identity file /home/alex/.ssh/id_dsa-cert type -1
debug1: identity file /home/alex/.ssh/id_ecdsa type -1
debug1: identity file /home/alex/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/alex/.ssh/id_ed25519 type -1
debug1: identity file /home/alex/.ssh/id_ed25519-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_7.1p1-hpn14v9
debug1: Remote protocol version 2.0, remote software version DLINK Corp. SSH server ver 1.00.000
debug1: no match: DLINK Corp. SSH server ver 1.00.000
debug1: Authenticating to 172.16.1.2 as 'admin'
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: AUTH STATE IS 0
debug1: REQUESTED ENC.NAME is 'aes128-cbc'
debug1: kex: server->client aes128-cbc hmac-sha1 none
debug1: kex: client->server aes128-cbc hmac-sha1 none
Unable to negotiate with 172.16.1.2: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1
DES-3200-28:admin#show config current_config include "ssh"
Command: show config current_config include "ssh"
config ssh algorithm 3DES enable
config ssh algorithm AES128 enable
config ssh algorithm AES192 enable
config ssh algorithm AES256 enable
config ssh algorithm arcfour enable
config ssh algorithm blowfish enable
config ssh algorithm cast128 enable
config ssh algorithm twofish128 enable
config ssh algorithm twofish192 enable
config ssh algorithm twofish256 enable
config ssh algorithm MD5 enable
config ssh algorithm SHA1 enable
config ssh algorithm RSA enable
config ssh algorithm DSA enable
config ssh authmode password enable
config ssh authmode publickey enable
config ssh authmode hostbased enable
config ssh server maxsession 8
config ssh server contimeout 600
config ssh server authfail 2
config ssh server rekey never
config ssh server port 22
config ssh user admin authmode password
config ssh publickey bypass_login_screen state disable
enable ssh
config authen application ssh login default
config authen application ssh enable default
Расследование показало, что начиная с версии 7.0 openssh была отключена поддержка по умолчанию алгоритма обмена ключами diffie-hellman-group1-sha1 длиной менее 1024-bit. http://www.openssh.com/txt/release-7.0
Пока ещё, с помощью дополнительного ключа в командной строке "-oKexAlgorithms=+diffie-hellman-group1-sha1" , можно осуществить подключение к коммутатору, но это неудобно и неизвестно сколько ещё будет сохранена эта возможность. http://www.openssh.com/legacy.html
Планируется ли в будущих прошивках коммутаторов, перечисленных в заголовке темы, изменить текущую ситуацию?
 Заголовок сообщения: Re: OpenSSH DES-3200 DGS-3620 DGS-3000
СообщениеДобавлено: Чт ноя 05, 2015 15:07
Таких планов нет.
СообщениеДобавлено: Пт ноя 06, 2015 07:27
Так надо запросить расширение функционала пока эти коммутаторы не EOL. Смягчение требований безопасности от разработчиков OpenSSH ждать не приходится, а это пожалуй самый популярный пакет такого толка. Коммутаторы эти могут прослужить достаточно долго, но использовать костыли для управления ими в дальнейшем не хочется.
СообщениеДобавлено: Пт ноя 06, 2015 10:55
Постараемся запросить.
СообщениеДобавлено: Сб ноя 07, 2015 13:29
да, есть такая печаль. использовать https с недавних пор уже тоже невозможно, только в устаревших браузерах
СообщениеДобавлено: Пн ноя 09, 2015 10:42
Запросите пожалуйста.
И, если не сложно, держите нас в курсе.
СообщениеДобавлено: Пн ноя 09, 2015 12:02
Присоединяюсь к запросу.
СообщениеДобавлено: Ср ноя 11, 2015 12:13
К сожалению, по результатам переписки могу порекомендовать лишь использовать описанный выше workaround.
В случае, если у кого-то действительно большой парк устройств и реализация алгоритмов жизненно необходима - по каждой отдельной линейке можете пообщаться с ближайшим региональным представительством на предмет feature request.
