Текущее время: Вт май 12, 2026 12:30
 Заголовок сообщения: DES-3200 fw 1.86.B006
СообщениеДобавлено: Чт окт 08, 2015 12:25
Device Type        : DES-3200-10 Fast Ethernet Switch
Boot PROM Version  : Build 1.00.B004
Firmware Version   : Build 1.86.B006
Hardware Version   : A1
1. Показывает нули во всех счетчиках, кроме "TOTAL"
DES-3200-10:5#show cpu port type dhcp
Command: show cpu port type dhcp
Type                PPS        Total       Drop
DHCP                0          204         0
 Discover           -          0           -
 Offer              -          0           -
 Request            -          0           -
 Decline            -          0           -
 ACK                -          0           -
 NAK                -          0           -
 Release            -          0           -
 Inform             -          0           -
2. Не отображается различие между режимами ACL и IP Inspection Only
DES-3200-10:5#config address_binding ip_mac ports 6 mode ip_inspection_only
Command: config address_binding ip_mac ports 6 mode ip_inspection_only
Warning! All enabled ACL mode ports will be changed to strict mode.
Success.
DES-3200-10:5#show address_binding ip_mac all
Command: show address_binding ip_mac all
M(Mode) - D:DHCP, P:DHCP-PD, S:Static ACL - A:Active I:Inactive
IP Address                              MAC Address       M  ACL Ports
Total Entries : 0
DES-3200-10:5#show address_binding ports
Command: show address_binding ports
Port  IPv4      IPv6      Mode  Zero IP    DHCP Packet  Stop Learning
      State     State                                   Threshold/Mode
1     Disabled  Disabled  ARP   Not Allow  Forward      500    /Normal
2     Disabled  Disabled  ARP   Not Allow  Forward      500    /Normal
3     Disabled  Disabled  ARP   Not Allow  Forward      500    /Normal
4     Disabled  Disabled  ARP   Not Allow  Forward      500    /Normal
5     Disabled  Disabled  ARP   Not Allow  Forward      500    /Normal
6     Strict    Disabled  ACL   Allow      Forward      1      /Normal
7     Disabled  Disabled  ARP   Not Allow  Forward      500    /Normal
8     Disabled  Disabled  ARP   Not Allow  Forward      500    /Normal
9     Disabled  Disabled  ARP   Not Allow  Forward      500    /Normal
10    Disabled  Disabled  ARP   Not Allow  Forward      500    /Normal
DES-3200-10:5#config address_binding ip_mac ports 6 mode acl
Command: config address_binding ip_mac ports 6 mode acl
Success.
DES-3200-10:5#
 Заголовок сообщения: Re: DES-3200 fw 1.86.B006
СообщениеДобавлено: Пн окт 12, 2015 09:16
UP
СообщениеДобавлено: Пн окт 12, 2015 14:59
Пришлите пожалуйста полный конфиг коммутатора мне на почту.
СообщениеДобавлено: Пт окт 30, 2015 16:05
Таже проблема на 3200-26 rev a
Firmware Version : Build 1.85.B008
Не показывает какой именно DHCP пакет прошел но суммарно счетчик их считает.
DES-3200-26:5#show cpu port type dhcp
Type PPS Total Drop
DHCP 0 2741436 0
Discover - 0 -
Offer - 0 -
Request - 0 -
Decline - 0 -
ACK - 0 -
NAK - 0 -
Release - 0 -
Inform - 0 -
СообщениеДобавлено: Вт ноя 03, 2015 10:42
Обновил до 1.86.B007
Проблема со счетчиками "show cpu port type dhcp" осталась.
Что выслать на почту, чтобы сотрудники длинка смогли воспроизвести проблему ?
Конфиг, фотографию свича, отпечатки пальцев ?
По прежнему в выводе команды "show address_binding ports" нет различия между "mode acl" и "mode ip_inspection_only"
СообщениеДобавлено: Вт ноя 03, 2015 10:56
СообщениеДобавлено: Вт ноя 03, 2015 11:11
Отправил в PM
СообщениеДобавлено: Вт ноя 03, 2015 11:28
В почту, пожалуйста.
Именно в почту, отдельным текстовым файлом выгруженный с коммутатора по tftp конфиг.
СообщениеДобавлено: Вт ноя 03, 2015 16:54
Я выслал на почту
СообщениеДобавлено: Ср ноя 04, 2015 18:43
Я уже высылал на PM, на почту. Ответа никакого.
СообщениеДобавлено: Чт ноя 05, 2015 10:07
Сегодня проверю проблему на стенде и отвечу Вам на почту.
СообщениеДобавлено: Ср ноя 25, 2015 12:08
Аналогичную проблему наблюдаю на DES-3200-18 hw c1 fw 4.39.B015
DES-3200-18:admin#show cpu port type dhcp
Type                PPS        Total       Drop
DHCP                0          43442       0
 Discover           -          0           -
 Offer              -          0           -
 Request            -          0           -
 Decline            -          0           -
 ACK                -          0           -
 NAK                -          0           -
 Release            -          0           -
 Inform             -          0           -
СообщениеДобавлено: Чт ноя 26, 2015 10:38
Type                PPS        Total       Drop
DHCP                0          43442       0
 Discover           -          0           -
 Offer              -          0           -
 Request            -          0           -
 Decline            -          0           -
 ACK                -          0           -
 NAK                -          0           -
 Release            -          0           -
 Inform             -          0           -
На ревизии А проблема решена?
СообщениеДобавлено: Чт ноя 26, 2015 10:56
Type                PPS        Total       Drop
DHCP                0          43442       0
 Discover           -          0           -
 Offer              -          0           -
 Request            -          0           -
 Decline            -          0           -
 ACK                -          0           -
 NAK                -          0           -
 Release            -          0           -
 Inform             -          0           -
На прошивке 1.86.B007 проблема не решена.
СообщениеДобавлено: Чт ноя 26, 2015 12:47
Type                PPS        Total       Drop
DHCP                0          43442       0
 Discover           -          0           -
 Offer              -          0           -
 Request            -          0           -
 Decline            -          0           -
 ACK                -          0           -
 NAK                -          0           -
 Release            -          0           -
 Inform             -          0           -
24.11.2015 я высылал Вам на почту прошивку с исправлением.
Сейчас этот форум просматривают: Google [Bot] и гости: 25
