Текущее время: Вт ноя 10, 2026 09:14
Начать новую тему Ответить на тему  [ Сообщений: 21 ]  На страницу Пред.  1, 2
 Заголовок сообщения: Re: DIR 320
СообщениеДобавлено: Пн июл 13, 2015 22:19
At least cause WiFi works at half duplex. 54Mbit/s is a channel speed but real can be much lower. Ideally 27Mbit/s but interference, distance, maintenance traffic etc affect it that is why 24-25Mbit/s "G" is a quite good result.
СообщениеДобавлено: Ср июл 15, 2015 00:05
Is not any chance from router settings to speed up?
СообщениеДобавлено: Ср июл 15, 2015 08:50
No chance. 50Mbit/s can be achieved on 802.11n not G. You need new router and perhaps new WiFi adapter (if your support only B/G)
СообщениеДобавлено: Чт июл 16, 2015 21:32
Mihail821
Thank you very much for help!
Don't you also know any solution for the problem I've posted in the first post?
As СергейП said, the only solution is to reset settings and then configure all settings manually (not from backup/restore) and that process is too hard for me, because configuration is too complicated.
I've updated dlink dir-320 router to Firmware Version : 1.22.
Now I've the problem of changing the administrator username and password. None of them is able to be changed.
Username field is not shown and when I trying to change password, it returns "Nothing Changed"
СообщениеДобавлено: Пт июл 17, 2015 11:15
It`s only solution to make factory reset (traditionally for D-Link after upgrading FW make factory reset). I know about few opensource firmwares where is no need to do it (Padavan firmwares and Wive-NG-RTNL by sfstudio) except very rare situation and you can use old config after reset. Also I know special utilities to make config migration easier (for example in Merlin firmware you also sometimes need to reset router but you can easilly use old config and even restore JFFS partition with all your certificates, scripts etc by using special script). So you have to write down all setting and make reset and I also suppose more good firmware for your router is Vampik edition of firmware maked by "Enthusiasts" and Openwrt (if you plan to use some new 3G/4G modem).
СообщениеДобавлено: Вт июл 21, 2015 21:51
When I've made FW update, it made no config reset and all settings were maintained. But now I can't change admin password, because in 1.00 version I had changed default username and in 1.22 version that change is not possible and it always should be "admin".
Is not any script to force password change the router? From firebug, for example. Or is not possible to correct *.bin configuration file and change password here?
