Текущее время: Ср июн 24, 2026 09:18
 Заголовок сообщения: QoS на 3200-28 С1
СообщениеДобавлено: Ср апр 29, 2015 11:29
Добрый день!
Правильно ли я настроил QoS для IP-TV ? в магистральный порт трафик приходит с DSCP=56
config scheduling_mechanism ports 1-28 strict
config scheduling ports 1-28 0 strict
config scheduling ports 1-28 1 strict
config scheduling ports 1-28 2 strict
config scheduling ports 1-28 3 strict
config scheduling ports 1-28 4 strict
config scheduling ports 1-28 5 strict
config scheduling ports 1-28 6 strict
config scheduling ports 1-28 7 strict
config dscp trust 25-28 state enable
config 802.1p map all 1p_color 0-7 to green
config dscp map all dscp_color 0-63 to green
config dscp map all dscp_dscp 0 to 0
config dscp map all dscp_dscp 1 to 1
config dscp map all dscp_dscp 2 to 2
config dscp map all dscp_dscp 3 to 3
config dscp map all dscp_dscp 4 to 4
config dscp map all dscp_dscp 5 to 5
config dscp map all dscp_dscp 6 to 6
config dscp map all dscp_dscp 7 to 7
config dscp map all dscp_dscp 8 to 8
config dscp map all dscp_dscp 9 to 9
config dscp map all dscp_dscp 10 to 10
config dscp map all dscp_dscp 11 to 11
config dscp map all dscp_dscp 12 to 12
config dscp map all dscp_dscp 13 to 13
config dscp map all dscp_dscp 14 to 14
config dscp map all dscp_dscp 15 to 15
config dscp map all dscp_dscp 16 to 16
config dscp map all dscp_dscp 17 to 17
config dscp map all dscp_dscp 18 to 18
config dscp map all dscp_dscp 19 to 19
config dscp map all dscp_dscp 20 to 20
config dscp map all dscp_dscp 21 to 21
config dscp map all dscp_dscp 22 to 22
config dscp map all dscp_dscp 23 to 23
config dscp map all dscp_dscp 24 to 24
config dscp map all dscp_dscp 25 to 25
config dscp map all dscp_dscp 28 to 28
config dscp map all dscp_dscp 27 to 27
config dscp map all dscp_dscp 29 to 29
config dscp map all dscp_dscp 30 to 30
config dscp map all dscp_dscp 31 to 31
config dscp map all dscp_dscp 32 to 32
config dscp map all dscp_dscp 33 to 33
config dscp map all dscp_dscp 34 to 34
config dscp map all dscp_dscp 35 to 35
config dscp map all dscp_dscp 36 to 36
config dscp map all dscp_dscp 37 to 37
config dscp map all dscp_dscp 38 to 38
config dscp map all dscp_dscp 39 to 39
config dscp map all dscp_dscp 40 to 40
config dscp map all dscp_dscp 41 to 41
config dscp map all dscp_dscp 42 to 42
config dscp map all dscp_dscp 43 to 43
config dscp map all dscp_dscp 44 to 44
config dscp map all dscp_dscp 45 to 45
config dscp map all dscp_dscp 46 to 46
config dscp map all dscp_dscp 47 to 47
config dscp map all dscp_dscp 48 to 48
config dscp map all dscp_dscp 49 to 49
config dscp map all dscp_dscp 50 to 50
config dscp map all dscp_dscp 51 to 51
config dscp map all dscp_dscp 52 to 52
config dscp map all dscp_dscp 53 to 53
config dscp map all dscp_dscp 54 to 54
config dscp map all dscp_dscp 55 to 55
config dscp map all dscp_dscp 56 to 56
config dscp map all dscp_dscp 57 to 57
config dscp map all dscp_dscp 58 to 58
config dscp map all dscp_dscp 59 to 59
config dscp map all dscp_dscp 60 to 60
config dscp map all dscp_dscp 61 to 61
config dscp map all dscp_dscp 62 to 62
config dscp map all dscp_dscp 63 to 63
config dscp map all dscp_priority 0-7 to 0
config dscp map all dscp_priority 8-15 to 1
config dscp map all dscp_priority 16-23 to 2
config dscp map all dscp_priority 24-31 to 3
config dscp map all dscp_priority 32-39 to 4
config dscp map all dscp_priority 40-47 to 5
config dscp map all dscp_priority 48-55 to 6
config dscp map all dscp_priority 56-63 to 7
и команда - dscp trust 25-28 state enable - нужна только на магистральные порты или на клиентскаие порты ? какокй смысл этой команды?
 Заголовок сообщения: Re: QoS на 3200-28 С1
СообщениеДобавлено: Сб май 02, 2015 20:00
Вроде верно. Но лучше проверить. Проверяется просто - качать торрент и смотреть TV.
Команда нужна только на магистральных портах.
Смысл в том, что при определении CoS в теге пакета будет ли использоваться map DSCP -> CoS.
Т.е. пакет, который пришел с DSCP 56 попадет в выходую очередь с priority 7.
Еще, по идее, если DSCP trust отключен, то DSCP в пакете должен сбрасываться на 0, но не думаю, что на всех коммутаторах DLINK это так. Во всяком случае - на DGS3620 это не работает.
На клиентских портах лучше убивать DSCP, чтобы приоритезацией не могли пользоваться те, кому это не положено.
Я обращался с вопросом, почему не работает сброс при DSCP trust disable, мне ответили, что этим никто не пользуется и порекомендовали пользовать ACL :).
И все же, планируется ли пофиксить данную функцию? Или может я не совсем правильно понимаю работу DSCP trust в концепции DLINK?
СообщениеДобавлено: Вт май 12, 2015 15:13
судя по докам, выключенный dscp trust просто переключает на использование приоритета 802.1p - вроде ничего он сбрасывать не должен
Это текст, который можно добавлять к размещаемым вами сообщениям. Длина его ограничена 255 символами.
СообщениеДобавлено: Ср июн 03, 2015 16:30
Напишу в этой теме. Разбираюсь с приоритетами и появились кое-какие вопросы.
В документации есть строчка про dscp trust:
This command is used to configure the state of DSCP trust per port. When DSCP is not trusted, 802.1p is trusted.
Также, согласно документации, серия C1 имеет 7 очередей. Правильно ли я понимаю, что пакет отправляется в соответствую очередь:
1. В случае наличия метки 802.1p - на основе наличия этой метки.
2. В случае отсутствия метки 802.1p - на основе 802.1p default_priority для каждого порта.
3. В случае включения dscp trust - согласно dscp map .. dscp_priority (при этом метка 802.1p игнорируется). По умолчанию есть такие настройки:
Command: show dscp map 25 dscp_priority
DSCP to 802.1p Priority Mapping:
Port 25
DSCP 0-7 is mapped to 0
DSCP 8-15 is mapped to 1
DSCP 16-23 is mapped to 2
DSCP 24-31 is mapped to 3
DSCP 32-39 is mapped to 4
DSCP 40-47 is mapped to 5
DSCP 48-55 is mapped to 6
DSCP 56-63 is mapped to 7
Верны ли приведенные выше предположения?
Сделал вот такое правило:
config access_profile profile_id 7 add access_id auto_assign ip destination_ip 239.1.8.0 port 25 permit priority 6 replace_priority replace_dscp_with 48
Верно ли то, что правило является избыточным, если включен dscp trust и трафик уже идет с метками dscp?
При этом, если метки нет, то трафик будет вручную отправлен в 6-ю очередь и будет назначена новая метка?
СообщениеДобавлено: Пт июн 05, 2015 14:24
2 xcme: Да, все именно так как Вы и написали. В случае использования DSCP Trust уже нет необходимости в отдельных правилах ACL.
СообщениеДобавлено: Вс июн 07, 2015 11:46
Денис, спасибо за разъяснения!
СообщениеДобавлено: Вт июн 09, 2015 17:38
Не за что.
