Текущее время: Пн авг 31, 2026 23:15
 Заголовок сообщения: dgs-3420-tc STP fail?
СообщениеДобавлено: Пн июн 01, 2015 21:10
Подскажите пожалуйста,
есть dgs-3420-tc две штуки
соеденены по 18-ми и 28-му порту.
от лог первого (root):
3920 2015-06-01 13:26:47 NOTI(5) Spanning Tree port status change (Instance:0,Port:2) Learning->Forwarding
3919 2015-06-01 13:26:47 NOTI(5) Spanning Tree port status change (Instance:0,Port:2) Discarding->Learning
3918 2015-06-01 13:26:47 INFO(6) Spanning Tree port role change (Instance:0, Port:2) DisabledPort->DesignatedPort
3906 2015-06-01 13:20:18 NOTI(5) Topology changed (Instance:0, Port:18,MAC:78-54-2E-C0-84-00)
3905 2015-06-01 13:20:16 NOTI(5) Topology changed (Instance:0, Port:18,MAC:78-54-2E-C0-84-00)
3898 2015-06-01 12:56:00 NOTI(5) Topology changed (Instance:0, Port:18,MAC:78-54-2E-C0-84-00)
3897 2015-06-01 12:55:58 NOTI(5) Topology changed (Instance:0, Port:18,MAC:78-54-2E-C0-84-00)
3896 2015-06-01 11:18:25 NOTI(5) Topology changed (Instance:0, Port:28,MAC:78-5
а вот второго:
1470 2015-06-01 13:19:58 NOTI(5) Topology changed (Instance:0, Port:2,MAC:78-54-2E-C0-84-00)
1469 2015-06-01 13:19:58 NOTI(5) Spanning Tree port status change (Instance:0,Port:2) Learning->Forwarding
1468 2015-06-01 13:19:58 NOTI(5) Spanning Tree port status change (Instance:0,Port:2) Discarding->Learning
1467 2015-06-01 13:19:58 INFO(6) Spanning Tree port role change (Instance:0, Port:2) DisabledPort->DesignatedPort
1450 2015-06-01 12:56:27 NOTI(5) Spanning Tree port status change (Instance:0,Port:28) Learning->Forwarding
1449 2015-06-01 12:56:12 NOTI(5) Spanning Tree port status change (Instance:0,Port:28) Discarding->Learning
1448 2015-06-01 12:55:57 NOTI(5) Topology changed (Instance:0, Port:18,MAC:78-54-2E-C0-84-00)
1447 2015-06-01 12:55:57 NOTI(5) Spanning Tree port status change (Instance:0,Port:18) Learning->Forwarding
1446 2015-06-01 12:55:57 NOTI(5) Spanning Tree port status change (Instance:0,Port:18) Discarding->Learning
1445 2015-06-01 12:55:57 NOTI(5) Spanning Tree port status change (Instance:0,Port:28) Forwarding->Discarding
1444 2015-06-01 12:55:57 INFO(6) Spanning Tree port role change (Instance:0, Port:28) RootPort->DesignatedPort
1443 2015-06-01 12:55:57 INFO(6) Spanning Tree port role change (Instance:0, Port:18) AlternatePort->RootPort
1442 2015-06-01 12:55:57 NOTI(5) New root port selected (Instance:0, Port:18)
1441 2015-06-01 11:18:24 NOTI(5) Topology changed (Instance:0, Port:2,MAC:00-24-01-ED-5C-F0)
1440 2015-06-01 11:18:22 NOTI(5) Topology changed (Instance:0, Port:2,MAC:00-24-01-ED-5C-F0)
я правильно понимаю, на втором коммутаторе 18-й порт так и не перешел в discarding, и что с 12:56:27 на втором коммутаторе форвардят и 18-й и 28-й порты. т.е. получилась петля в явном виде и stp ее не отработал.
 Заголовок сообщения: Re: dgs-3420-tc STP fail?
СообщениеДобавлено: Вт июн 02, 2015 10:39
Приведите пожалуйста настройки stp. Также посмотрите состояние указанных портов командой show stp ports
СообщениеДобавлено: Вт июн 02, 2015 11:10
Второй:
mo-dgs3420-10G-b:admin#sh stp
Command: show stp
STP Bridge Global Settings
STP Status : Enabled
STP Version : RSTP
Max Age : 20
Hello Time : 2
Forward Delay : 15
Max Hops : 20
TX Hold Count : 6
Forwarding BPDU : Enabled
New Root Trap : Enabled
Topology Change Trap : Enabled
NNI BPDU Address : dot1d
mo-dgs3420-10G-b:admin#sh stp po 18,28
Command: show stp ports 18,28
MSTP Port Information
Port Index : 18 , Hello Time: 2 /2 , Port STP : Enabled ,
External PathCost : Auto/20000 , Edge Port : False/No , P2P : Auto /Yes
Port RestrictedRole : False, Port RestrictedTCN : False
Port Forward BPDU : Enabled
MSTI Designated Bridge Internal PathCost Prio Status Role
0 0000/1C7EE5643000 20000 128 Discarding Alternate
Port Index : 28 , Hello Time: 2 /2 , Port STP : Enabled ,
External PathCost : Auto/2000 , Edge Port : False/No , P2P : Auto /Yes
0 0000/1C7EE5643000 2000 128 Forwarding Root
Первый:
mo-dgs3420-10G:admin#sh stp
Command: show stp
STP Version : RSTP
Max Age : 20
Hello Time : 2
Forward Delay : 15
Max Hops : 20
TX Hold Count : 6
mo-dgs3420-10G:admin#sh stp po 18,28
0 0000/1C7EE5643000 20000 128 Forwarding Designated
0 0000/1C7EE5643000 2000 128 Forwarding Designated
Заметил, что для 18-х портов был edge в auto. Поставил в false. это могло быть проблемой???
СообщениеДобавлено: Вт июн 02, 2015 11:11
сегодня решил прошиться на последнюю прошивку. это имеет смысл?
СообщениеДобавлено: Вт июн 02, 2015 11:16
Один из портов в состоянии Discarding, все правильно. В логах еще упоминается порт 2?
Да, мы всегда рекомендуем обновлять ПО до актуальных версий. Для DGS-3420 Series - это v1.76.B008.
СообщениеДобавлено: Вт июн 02, 2015 12:42
порт 2 - это уже "ручные действия". Один из lacp группы. думал в ней проблема - включал-выключал...
