Текущее время: Вт сен 29, 2026 19:14
 Заголовок сообщения: DGS-3100-48 Pause Frame
СообщениеДобавлено: Пн мар 02, 2015 11:32
Есть стык DGS-3100-48 (1:48) - Qtech 8300 (1/0/14) - <some cisco>
DGS-3100-48 Firmware Version : 3.60.28
При включенном flow control сыпятся pause frame в сторону кутака
sh interface ethernet 1/0/14
Interface brief:
Ethernet1/0/14 is up, line protocol is up
Ethernet1/0/14 is layer 2 port, alias name is Office, index is 14
Hardware is Gigabit-Combo, active is Copper, address is 00-1f-ce-4b-b6-c8
PVID is 1
MTU 10218 bytes, BW 1000000 Kbit
Time since last status change:1w-4d-6h-26m-20s (973580 seconds)
Encapsulation ARPA, Loopback not set
Force full-duplex, Force 1G
FlowControl is on, MDI type is auto
Transceiver info:
Statistics:
5 minute input rate 2255089 bits/sec, 1101 packets/sec
5 minute output rate 133391023 bits/sec, 16754 packets/sec
The last 5 second input rate 2019966 bits/sec, 812 packets/sec
The last 5 second output rate 120356292 bits/sec, 15485 packets/sec
Input packets statistics:
1531319004 input packets, 636762382102 bytes, 0 no buffer
1513407142 unicast packets, 12423041 multicast packets, 1480705 broadcast packets
0 input errors, 0 CRC, 0 frame alignment, 0 overrun, 0 ignored,
0 abort, 0 length error, 4008116 pause frame
Output packets statistics:
16684619721 output packets, 18292127112450 bytes, 0 underruns
3020618042 unicast packets, 429747035 multicast packets, 348522694 broadcast packets
0 output errors, 0 collisions, 0 late collisions, 830062 pause frame
На интерфейсе д-Линка
# sh ports 48
Port Port Settings Connection Address
State Speed/Duplex/FlowCtrl Speed/Duplex/FlowCtrl Learning
1:48 Enabled 1000M/Full/Enabled 1000M/Full/Enabled Enabled
Мультикаст сыпется во время роста pause frame
Если контроль потока выключить с обоих стороны - счетчик пауз не растет, мультикаст все равно сыпется.
Навесил правило
create access_profile profile_id 2 ip destination_ip_mask 240.0.0.0
config access_profile profile_id 2 add access_id 1 ip destination_ip 224.0.0.
0 replace_priority 4 ports 1:48 permit
Поменял тип очереди для 4-го приоритета
config scheduling_mechanism 1 round_robin
Подсыпает меньше, но все равно видно.
Когда ноутбук подключаю непосредственно в Qtech - картинка четкая, без рассыпаний.
Задавал на всякий случай жестко скорость на порту
config bandwidth_control 1:48 rx_rate 900000 tx_rate no_limit
Какая причина отправки пауз д-линком, если канал загружен в пике на 15%?
 Заголовок сообщения: Re: DGS-3100-48 Pause Frame
СообщениеДобавлено: Пн мар 02, 2015 19:33
В какую сторону льется мультик? Из длинка в кутек или наоборот?
Встречал отправку пауз длинком при загрузке клиентского 100-мбитного порта больше 90% мультиком. Причем пауза доходила ввех по аплинку (везде медь) до коммутатора, на котором мультик приходил по оптике, а все остальное по меди. Также начинало сыпаться, но дальше фрейм не уходил. выключение flow control ситуацию не меняло - счетчик просто медленнее накручивался
СообщениеДобавлено: Вт мар 03, 2015 03:54
ЛЬется из кутека в длинк, в этой стороне 1-2 клиента, загрузка мультикастом небольшая.
Т.е. перегрузка любого порта на коммутаторе или ниже может приводить к паузам?
Хотя судя по загрузке портов, этого так же не случается
# sh ut ports
Port TX/sec RX/sec Util
1:1 4640 0 0%
1:2 0 0 0%
1:3 6494632 575512 0%
1:4 13168 0 0%
1:5 0 0 0%
1:6 4432 0 0%
1:7 4472 1040 0%
1:8 14664 3328 0%
1:9 0 0 0%
1:10 18032280 19480 1%
1:11 0 0 0%
1:12 4416 0 0%
1:13 20088 5952 0%
1:14 45157488 9016 2%
1:15 4872 0 0%
1:16 47469144 1521192 2%
1:17 56088 6712 0%
1:18 0 0 0%
1:19 0 0 0%
1:20 6040 0 0%
1:21 8368 1808 0%
1:22 7120 0 0%
1:23 1493016 30087128 2%
1:24 6320 248 0%
1:25 5952 248 0%
1:26 0 0 0%
1:27 5904 0 0%
1:28 0 0 0%
1:29 5496 0 0%
1:30 322000 147696 0%
1:31 5272 0 0%
1:32 1936 240 0%
1:33 5168 0 0%
1:34 0 0 0%
1:35 5168 0 0%
1:36 735216 538144 0%
1:37 34384 422208 0%
1:38 0 0 0%
1:39 0 0 0%
1:40 7112 0 0%
1:41 5528 0 0%
1:42 80376 17080 0%
1:43 0 0 0%
1:44 2336 2152 0%
1:45 0 0 0%
1:46 0 0 0%
1:47 0 0 0%
1:48 1134936 105940808 5%
СообщениеДобавлено: Вт мар 03, 2015 05:09
А на кой вам на 1G порту flow control?
СообщениеДобавлено: Вт мар 03, 2015 09:38
Чтобы понять, откуда идет рассыпание мультикаста
СообщениеДобавлено: Вт мар 03, 2015 17:53
Попробуйте покрасить трафик как можно ближе к источнику
СообщениеДобавлено: Вт мар 03, 2015 17:57
Помоему где-то на наге читал что это проблема 3100, он плохо жует много мультикаста
А покажите настройки снупинга
СообщениеДобавлено: Ср мар 04, 2015 04:25
Он красится, это для надежности покрашен на входном интерфейсе чтобы показать наличие прокрашивания. Не на всех коммутаторах по пути не смог проверить, идет ли трафик покрашенным в нужной очереди.
И здесь контрольное прокрашивание, чтобы показать влияние round robin на рассыпание.
Последний раз редактировалось Hirurgus Ср мар 04, 2015 04:32, всего редактировалось 1 раз.
СообщениеДобавлено: Ср мар 04, 2015 04:31
Там мультикаста по влану 300 идет около 5-15 мбит в зависимости от выбранного канала, так что вряд ли это для него много мультикаста
create vlan IPTV tag 300
config vlan IPTV add tagged 1:(10,14,17,43,47-48)
config vlan IPTV add untagged 1:46 - порт куда ноутбуком вставал
config multicast filtering_mode 1:(1-9,11-13,15-29,31-42,44) filter_unregistered_groups
config traffic control 1:(1-44) state enable threshold 8192 storm_type dlf_multicast_broadcast
enable igmp_snooping
config igmp_snooping IPTV state enable
config router_port IPTV add 1:48
СообщениеДобавлено: Пт мар 06, 2015 10:02
Проблема актуальная, мультикаст сыпется, проходя через DGS-3100
Сейчас этот форум просматривают: Baidu [Spider] и гости: 86
