Текущее время: Пт июн 26, 2026 00:30
Начать новую тему Ответить на тему  [ Сообщений: 1490 ]  На страницу Пред.  1 ... 62, 63, 64, 65, 66, 67, 68 ... 100  След.
СообщениеДобавлено: Ср янв 21, 2015 20:37
Еще на 6.07.B035
----    Back trace    -------------------------------------------------------
Execution path:
No.1 -> ISS.exe(VlanFdbTableCmp+0x1c) [0xc643f8]
No.2 -> ISS.exe [0xd698b8]
----    Back trace end    ---------------------------------------------------
И еще:
Execution path:
No.1 -> ISS.exe [0xd818cc]
No.2 -> ISS.exe [0xd817dc]
No.3 -> ISS.exe(RBTreeAdd+0x64) [0xd81ac0]
No.4 -> ISS.exe(MmCreateBufferEntry+0xbc) [0xd4f644]
No.5 -> ISS.exe(MmPerformBufferEntry+0xbc) [0xd4f984]
No.6 -> ISS.exe(CRU_BUF_Allocate_MsgBufChain+0x134) [0xd578fc]
No.7 -> ISS.exe(CfaDuplicateCruBuffer+0x78) [0x6919b8]
No.8 -> ISS.exe(CfaIwfEnetProcessRxFrame+0x9d8) [0x693800]
No.9 -> ISS.exe(CfaGddProcessRecvInterruptEvent+0x1a4) [0x6b33b0]
No.10 -> ISS.exe(CfaMain+0xbc8) [0x6a2aa8]
No.11 -> ISS.exe [0xd61544]
No.12 -> /lib/libpthread.so.0 [0x2aba6d2c]
No.13 -> /lib/libc.so.6 [0x2ae17af0]
Последний произошел вообще массово, как будто в управляющем vlan'е пролетел "пакет смерти". Затронул разные прошивки:
6.07.B029
Execution path:
No.1 -> ISS.exe(RBTreeGetFirst+0x50) [0xd7c358]
No.2 -> ISS.exe(RBTreeGetFirst+0x30) [0xd7c338]
No.3 -> ISS.exe(MmDuplicateBufferEntry+0x70) [0xd4a7c0]
No.4 -> ISS.exe(MmPropagateBufferEntry+0x8c) [0xd4b004]
No.5 -> ISS.exe(CfaDuplicateCruBuffer+0x168) [0x68f598]
No.6 -> ISS.exe(CfaIwfEnetProcessRxFrame+0x9b8) [0x6912d0]
No.7 -> ISS.exe(CfaGddProcessRecvInterruptEvent+0x1a4) [0x6b0c40]
No.8 -> ISS.exe(CfaMain+0xbc8) [0x6a0338]
No.9 -> ISS.exe [0xd5ca94]
No.10 -> /lib/libpthread.so.0 [0x2aba6d2c]
No.11 -> /lib/libc.so.6 [0x2ae17af0]
6.07.B012
Execution path:
No.1 -> ISS.exe [0xd6fde8]
No.2 -> ISS.exe [0xd707ec]
No.3 -> ISS.exe(RBTreeRemove+0x78) [0xd70b2c]
No.4 -> ISS.exe(MmRemoveBufferEntry+0xb8) [0xd3e4c8]
No.5 -> ISS.exe(MmLiberateBufferEntry+0x74) [0xd3e9a8]
No.6 -> ISS.exe(CRU_BUF_Release_MsgBufChain+0x1c8) [0xd46704]
No.7 -> ISS.exe(arp_input+0x1b4) [0x76948c]
No.8 -> ISS.exe(ARP_Process_Pkt_Arrival_Event+0x25c) [0x764fa8]
No.9 -> ISS.exe(ArpTaskMain+0x1bc) [0x7687a0]
No.10 -> ISS.exe [0xd50404]
No.11 -> /lib/libpthread.so.0 [0x2aba6d2c]
No.12 -> /lib/libc.so.6 [0x2ae17af0]
СообщениеДобавлено: Чт янв 22, 2015 09:23
Возникла проблема с обновлением прошивки через TFTP.
Есть коммутаторы прошивкой:
DES-1210-28/ME:5# sh sw
Command: show switch
System name :
System Contact :
System Location :
System up time : 27 days, 19 hrs, 28 min, 51 secs
System Time : 29/01/2011 11:00:16
System hardware version : B2
System firmware version : 6.00.018
System boot version : 1.00.003
System Protocol version : 2.001.004
System serial number : QBM51D8000522
MAC Address : D8-FE-E3-32-E8-C4
STP : Disabled
SNMP Status : Enabled
Port Mirroring : Disabled
802.1X Status : Disabled
Storm Control : Disabled
802.1Q Management VLAN : Disabled
Safeguard Engine : Enabled
IGMP Snooping : Disabled
При попытке обновления ПО получаем:
DES-1210-28/ME:5# download firmware 10.12.35.147 soft/DES-1210-28-B2-6-07-B004.hex
Command: download firmware 10.12.35.147 soft/DES-1210-28-B2-6-07-B004.hex
Device will reboot after firmware upgraded successfully
% Image Updated Failed [INTERNAL ERROR]
При этом через WEB обновляется нормально. Как исправить данную ситуацию?
Настройки сбрасывал, перезагружал по несколько раз - ничего не помогает.
В логах:
27 Jan 29 11:01:11 2011:MSR-4:Firmware upgrade unsuccessful!
26 Jan 29 11:01:11 2011:MSR-4:Illegal file causes firmware upgrade failure.
P.S.: аналогичные коммутаторы в другом городе обновляются нормально.
СообщениеДобавлено: Чт янв 22, 2015 19:04
__IF__ писал(а):
В 6.07.B035 перестало работать сохранение через snmp.
Было ранее 1.3.6.1.4.1.171.10.75.15.2.1.10.0 i 1
Что сейчас?
1.3.6.1.4.1.171.10.75.15.2.1.10.0 i 3
СообщениеДобавлено: Пт янв 23, 2015 08:26
"Нельзя просто так взять и не поменять oid-ы в новой прошивке" (ц)
Но я по другому поводу:
show switch
System Firmware Version           : 6.07.B035
create access_profile ethernet vlan profile_id 1
config access_profile profile_id 1 add access_id auto_assign ethernet vlan 3971 port 1-28 permit
config access_profile profile_id 1 delete access_id 1
Execution path:
No.1 -> ISS.exe(mmi_action_procedure+0xca80) [0x732988]
No.2 -> ISS.exe(mmi_action_procedure+0xc314) [0x73221c]
No.3 -> ISS.exe(CliExecuteCommand+0x6e0) [0x758dc0]
No.4 -> ISS.exe(CliProcessCommand+0x28c) [0x7430a4]
No.5 -> ISS.exe(CliMainProcess+0x320) [0x744be4]
No.6 -> ISS.exe(CliTelnetTaskStart+0x94) [0x75bbac]
No.7 -> ISS.exe [0xd61544]
No.8 -> /lib/libpthread.so.0 [0x2aba6d2c]
No.9 -> /lib/libc.so.6 [0x2ae17af0]
СообщениеДобавлено: Пт янв 23, 2015 10:31
poofeg
Artem Kolpakov писал(а):
poofeg
после каких манипуляций это все?
По одному stack trace увы, проблему не исправят.
lexius
Обновите прошивку и если будет повторятся - нужен полный конфиг, т.к. на В039 не подтверждается.
СообщениеДобавлено: Пт янв 23, 2015 11:49
System Firmware Version : 6.07.B039
На портах 27-28 выставляешь 100Мбит, пишет что всё равно AUTO.
DES-1210-28/ME:5# config ports 28 medium_type fiber speed 100_full
Command: config ports 28 medium_type fiber speed 100_full
Success.
DES-1210-28/ME:5# sh ports 28
Command: show ports 28
Port  State/     Settings                 Connection               Address
Type  MDI        Speed/Duplex/FlowCtrl    Speed/Duplex/FlowCtrl    Learning
28    Enabled    Auto/Disabled            100M/Full/Disabled       Enabled
      N/A
На комбинированных линк не поднимает:
DES-1210-28/ME:5# sh ports 25
Command: show ports 25
25(C) Enabled    Auto/Disabled            Link Down                Enabled
      Auto
25(F) Enabled    Auto/Disabled            Link Down                Enabled
      N/A
DES-1210-28/ME:5# config ports 25 medium_type fiber speed 100_full
Command: config ports 25 medium_type fiber speed 100_full
Success.
      Auto
25(F) Enabled    100M/Full/Disabled       Link Down                Enabled
      N/A
log
Command: show log
Index Time Log Text
10 Jan 1 00:40:53:CLI-6:Successful login through console port( User: anonym
ous )
9 Jan 1 00:10:49:LinkStatus-6:Port 25 100 GBIC module detected.
8 Jan 1 00:10:44:LinkStatus-6:Port 25 100 GBIC module detected.
7 Jan 1 00:10:41:LinkStatus-6:Port 25 100 GBIC module detected.
6 Jan 1 00:10:32:LinkStatus-6:port 28 link down
5 Jan 1 00:05:17:CLI-6:Successful login through console port( User: anonym
ous )
4 Jan 1 00:00:12:SYSTEM-2:System started up
3 Jan 1 00:00:07:LinkStatus-6:Port 28 link up, 100Mbps FULL duplex
2 Jan 1 00:00:06:LinkStatus-6:Port 28 100 GBIC module detected.
1 Jan 1 00:00:06:SYSTEM-6:Configuration saved to flash
Модули 1Гбит, OptiCin
СообщениеДобавлено: Пт янв 23, 2015 17:26
На портах 25-26 не стартуют SFP 100mbit. Если вставить одну SFP100 в 25/26 а вторую в 27/28 и соединить патчкордом, то засвечивается только 27/28. С SFP 1Gbit вроде ок.
СообщениеДобавлено: Пн янв 26, 2015 10:54
Действительно, на новой не воспроизвелось.
СообщениеДобавлено: Пн янв 26, 2015 11:04
pvl
xneo
Кейс по проблемам с 100Mbit sfp уже есть, фикс будет в ближайшее время
СообщениеДобавлено: Вт янв 27, 2015 14:22
есть ли мануал по ACL PCF для данной модели? прошивка В039
СообщениеДобавлено: Ср янв 28, 2015 08:27
А можно сюда по DES-1210-28/ME/A1 ? Подходящих тем не нашел, а новую как-то тупо создавать.
Если верить этой теме viewtopic.php?f=2&t=153010 , то это именно Me A1, хотя никаких упомнинаний о пренадлежности к ME в нём вообще нет
DES-1210-28:5# sh swi
System name : DES-1210-28_133
System Contact :
System Location : N5
System up time : 5 days, 15 hrs, 54 min, 32 secs
System Time : 28/01/2015 08:18:59
System hardware version : A1
System firmware version : 5.10.B046
System boot version : 1.00.005
System serial number : F3XZ1AA000XXX
MAC Address : 5C-D9-98-47-XXXX
STP : Disabled
Storm Control : Enabled
Вот как такой отличать от не ME из cli, если не знать про то что 5 версия прошивки может быть только на ME?
СообщениеДобавлено: Ср янв 28, 2015 13:02
Добрый день. Возникла проблема с одним экземпляром.
  Boot Procedure
  Please wait, loading Runtime image ........................  20 %read: 0x4e600c23, calculated: 0x58b4849c
  File System Inspection Failure
Please input the password :
Без отправки в сервис возможно решить?
СообщениеДобавлено: Ср янв 28, 2015 13:52
При попытке обновление софта с 6.03.B006
switch:5# download firmware *.*.*.* DES-1210-28-B2-6-05-B040.hex
Command: download firmware *.*.*.* DES-1210-28-B2-6-05-B040.hex
% Image Updated Failed [No Memory Left]
После ребута свича обновление проходит нормально.
Аптайм свича 53 дня. Из общей массы свичей такое встречаю редко.
СообщениеДобавлено: Ср янв 28, 2015 15:54
pvl
xneo
poofeg
Проблему с 100Mbit SFP поправили - смотрите на B042
coo1.zer0
Подключитесь по консоли, при перезагрузке через Shift+6 попрбуйте сбросить настройки. Не поможет - в сервис
PavelGloba
По версии прошивки.
spirt
Мануалы тут http://ftp.dlink.ru/pub/Switch/DES-1210 ... scription/
СообщениеДобавлено: Ср янв 28, 2015 16:23
Да, похоже работает. Проверил в портах 25-28, подключили SFP WDM OptiCin 1Gbit, на другом конце волокна оптический конвертер 100Мбит.
Линк проверили на портах 25, 26, 27 и 28.
Линк поднялся автоматически на 100Мбит, ничего на коммутаторе не прописывали.
Сейчас этот форум просматривают: Baidu [Spider] и гости: 29
cron
