Текущее время: Ср окт 07, 2026 04:12
Начать новую тему Ответить на тему  [ Сообщений: 981 ]  На страницу Пред.  1 ... 48, 49, 50, 51, 52, 53, 54 ... 66  След.
 Заголовок сообщения: Re: DVG-7111S вопросы
СообщениеДобавлено: Пн дек 01, 2014 16:03
Palv писал(а):
первый был набрано номер 3500 второй 3502
12:42:08 *** SLMON start to log ***
12:45:19 [2467645] Receive Cmd=1100, ParaLen=5, Para=[Login]
12:45:19 [2467645] Login RU_1.00 == Ver(1.02.38.93.2577 2012/08/29 01:10:21) PId(281.DLink.RU.Pocket.ProfileProv.DhcpOpt195.l2tp.DualAccess.NoPrefix.drtp) Drv(
12:45:19 0.10.60.1) Hw(TSO) == 0.6.8
12:45:26 [2467715] 0: Fxs Pickup
12:45:26 [2467715] 0: ==4:GetDtmf
12:45:32 [2467783] 0: DTMF Timeout #1
12:45:32 [2467783] 0: End Input Default Route [1]
12:45:32 [2467783] 0: Line DialNum_New [500]
12:45:32 [2467783] 0: Call Proxy with [500]
12:45:32 [2467783] 0: ==7:Inviting
12:45:32 [2467783] 0: VoIP CallOut, Invite <sip:500@10.0.173.220;user=phone>
12:45:33 [2467784] 0: 3021=DIALING
12:45:33 [2467785] 0: 3021=PROCEEDING
12:45:33 [2467789] 0: 3021=DISCONNECT
12:45:33 [2467789] 0: Rtp Talk Stop
12:45:33 [2467789] 0: Release Active Dlg
12:45:33 [2467789] 0: ==15:PlayBusyTone
12:45:37 [2467827] 0: Fxs Hangup
12:45:37 [2467827] 0: ==3:Idle
12:45:37 [2467827] 0: SetFax(1)=0
12:46:42 [2468474] 0: 3021=REGISTER
12:46:42 [2468475] 0: 3021=REGISTER_AUTHN
12:46:42 [2468476] 0: 3021=REGISTERED
12:51:15 [2471206] 0: 3021=REGISTER
12:51:15 [2471207] 0: 3021=REGISTER_AUTHN
12:51:15 [2471208] 0: 3021=REGISTERED
12:53:00 [2472254] 0: Fxs Pickup
12:53:00 [2472254] 0: ==4:GetDtmf
12:53:10 [2472356] 0: DTMF Timeout #1
12:53:10 [2472356] 0: End Input Default Route [1]
12:53:10 [2472356] 0: Line DialNum_New [50]
12:53:10 [2472356] 0: Call Proxy with [50]
12:53:10 [2472356] 0: ==7:Inviting
12:53:10 [2472356] 0: VoIP CallOut, Invite <sip:50@10.0.173.220;user=phone>
12:53:10 [2472357] 0: 3021=DIALING
12:53:10 [2472358] 0: 3021=PROCEEDING
12:53:10 [2472362] 0: 3021=DISCONNECT
12:53:10 [2472362] 0: Rtp Talk Stop
12:53:10 [2472362] 0: Release Active Dlg
12:53:10 [2472362] 0: ==15:PlayBusyTone
12:53:12 [2472383] 0: Fxs Hangup
12:53:12 [2472383] 0: ==3:Idle
12:53:12 [2472383] 0: SetFax(1)=0
12:54:14 ========================================C:\1.txt========================================
Судя по логам, либо часть клавиш не срабатывает, либо не хватает уровня сигнала.
Попробуйте подрегулировать чувствительность определения DTMF в меню ADVANCED -> VOIP -> DTMF & PULSE -> DTMF Detection Sensitivity.
СообщениеДобавлено: Пн дек 01, 2014 16:48
Спасибо сработало.
СообщениеДобавлено: Вт дек 02, 2014 08:20
Подскажите, запись FXO Detected BTC (0) означает детектирование по первой строке таблицы, а BTC(4) - соответственно по пятой ?
СообщениеДобавлено: Вт дек 02, 2014 11:11
Да, правильно.
СообщениеДобавлено: Пт дек 05, 2014 11:37
Производитель корректирует прошивку и в ближайшее время она станет доступной для обновления.
так и не появилась прошивка на фтп :|
СообщениеДобавлено: Пн дек 08, 2014 00:44
Проблема с зависанием звонков.
Имеется два 7111, прошивка1.2.38.93_0.10.60, настроены для соединения двух аналоговых АТС по FXO портам в удаленных офисах, изначально были настроены в тестовой среде, использовались статические IP из одной подсети, FXO порты подсоединены к одной АТС (Мультиком МР200), работали без нареканий. После переноса в офисы, шлюзы были подключены к двум миниАТС, Panasonis TEM324 в одном офисе и Мультиком МР48 в другом, заменены IP адреса на соответствующие внутренние, сети в офисах соединены по VPN.
При звонке соединение устанавливается, при разговоре не сбрасывает, но после того как положишь трубку, соединение между шлюзами не сбрасывается, индикатор Line горит, в статусе шлюза показывает voip соединение, при повторном звонке на шлюз идет сигнал занято, выдергивание патч кордов как из телефонного так и Wan портов не помогает, лечится только перезагрузкой.
Пробовал установить параметр сброса лини по незанятости и в зависимости от уровня сигнала и по времени (voip - line ) не помогает.
СPT/cadence стоит в режиме обучения я так понимаю проблема где-то здесь.
http://s019.radikal.ru/i631/1412/89/762c6bd5925e.jpg
http://i008.radikal.ru/1412/19/3d369192cec3.jpg
Просьба помочь.
Да вот логи
Исходящий звонок
<142> C8BE1925445E-sip: 0: Idle 192.168.1.55 05/12 16:21:30.856
<142> C8BE1925445E-sip: 1: Idle 192.168.1.55 05/12 16:21:30.858
<142> C8BE1925445E-sip: 1: WaitAnswerDeviceOk 192.168.1.55 05/12 16:22:18.565
<142> C8BE1925445E-sip: 1: Dial 702 192.168.1.55 05/12 16:22:18.565
<142> C8BE1925445E-sip: 1: Inviting 192.168.1.55 05/12 16:22:18.581
<142> C8BE1925445E-sip: 1: Connected As Caller 192.168.1.55 05/12 16:22:19.798
<142> C8BE1925445E-sip: 1: Talking 1 92.168.1.55 05/12 16:22:19.860
<134> C8BE1925445E-gw: (001200) Something Changed! 192.168.1.55 05/12 16:23:23.386
<134> C8BE1925445E-gw: (001200) <Save> 192.168.1.55 05/12 16:23:23.389
<134> C8BE1925445E-gw: (001245) Save Settings OK 192.168.1.55 05/12 16:23:31.037
<134> C8BE1925445E-gw: (001246) <End SIP> 192.168.1.55 05/12 16:23:31.137
<134> C8BE1925445E-gw: (001249) GwMsgCmd=1() 192.168.1.55 05/12 16:23:31.422
<134> C8BE1925445E-gw: (001249) <Restart> 192.168.1.55 05/12 16:23:31.429
Входящий звонок
<133> C8BE1925445E-gw: Reboot 192.168.1.55 05/12 16:23:31.432
<142> C8BE1925445E-sip: 0: Idle 192.168.1.55 05/12 16:23:53.367
<142> C8BE1925445E-sip: 1: Idle 192.168.1.55 05/12 16:23:53.370
<142> C8BE1925445E-sip: 702 CallIn 192.168.1.55 05/12 16:29:07.385
<142> C8BE1925445E-sip: 1: TrunkDialOut 192.168.1.55 05/12 16:29:07.385
<142> C8BE1925445E-sip: 1: PSTN Dial 192.168.1.55 05/12 16:29:07.463
<142> C8BE1925445E-sip: 1: VoipAnswering 192.168.1.55 05/12 16:29:07.603
<142> C8BE1925445E-sip: 1: Connected As Callee 192.168.1.55 05/12 16:29:07.743
<142> C8BE1925445E-sip: 1: Talking 192.168.1.55 05/12 16:29:07.743
СообщениеДобавлено: Ср дек 10, 2014 10:49
какие параметры задавать для шлюза чтобы ходить не через стандартный порт
провайдер выдал следующие данный
1) Domain/proxe - sip.yarnet.ru
2) Порт - 5066
3) Account/Caller ID - xxxxxxx
с ходу настроить не смог, через софтовую программу хожу используеться zoiper со следующими настройками
Domain - sip.yarnet.ru:5066
User name - ххххххххх
Caller id - xxxxxxx
в настройках сети установлено использование STUN сервера
Transport UDP
rport - signaling
Stun server - sip.yarnet.ru
Port - 5066
Refresh - 30
Все бегает...
СообщениеДобавлено: Чт дек 11, 2014 10:18
какие либо есть настройки по громкости слышимости ?
на line местной телефонии слышимость хуже
СообщениеДобавлено: Пн дек 15, 2014 11:33
2) Порт - 5066
Caller id - xxxxxxx
Transport UDP
rport - signaling
Port - 5066
Refresh - 30
Все бегает...
Попробуйте настроить как на рисунках.
1. - Настройка сервера SIP
2. - Настройка STUN, но надо уточнить порт сервера STUN, несколько странно, что они одинаковые... Нужен ли он вообще вам?
yarnet_1.jpg [ 165.4 KiB | Просмотров: 9187 ]
yarnet_2.jpg [ 139.85 KiB | Просмотров: 9187 ]
СообщениеДобавлено: Пн дек 15, 2014 11:40
Используйте меню ADVANCED - VoIP - Line и параметр Listening Volume.
СообщениеДобавлено: Пн дек 15, 2014 11:44
Просьба помочь.
Да вот логи
Исходящий звонок
Входящий звонок
Логи slmon со шлюзов, что показывают? NAT используется?
СообщениеДобавлено: Вт дек 23, 2014 10:44
Джентельмены, а кто-нить будь настраивал два DVG-7111S в режиме точка-точка?
Требуется вынести несколько местных телефонов в удаленные офисы.
СообщениеДобавлено: Вт дек 23, 2014 13:53
2) Порт - 5066
Caller id - xxxxxxx
Transport UDP
rport - signaling
Port - 5066
Refresh - 30
Все бегает...
не помогло. приложил скан портов когда шлюз пытается с провайдером sip.
сегодня логи попробую получить с шлюза.
ФГІЎ  о q E;™TTн H H   E 8О @†K]ћг.е¶ВКК $*h  vГn¶·yшЯ°d«Р±   E;™T‰ H H   E 8ј] @—э]ћг.е¶ВКК $|G  ®єIЩэ(i™йTX=њW   E;™Tшѕ H H   E 8™ж @єt]ћг.е¶ВКК $XЖ  њqЎaйdК°2й®b   E;™TЯ H H   E 8я @?\]ћг.е¶ВКК $н  ®©u=фjВ®‡6Y1"   F;™T(Ѓ H H   E 8^Ф @х†]ћг.е¶ВКК $eц  ¦!q:˜ЃvbGАoЬµm   G;™TH к к   E ЪЗl @ЉL]ћг.е¶ВККЖhяREGISTER sip:sip.yarnet.ru:5066;transport=UDP SIP/2.0
Via: SIP/2.0/UDP 192.168.1.4:5066;branch=z9hG4bK-d8754z-14663d8931204245-1---d8754z-;rport
Max-Forwards: 70
Contact: <sip:593195@192.168.1.4:5066;rinstance=b292c0da18558e28;transport=UDP>
To: "593195"<sip:593195@sip.yarnet.ru:5066;transport=UDP>
From: "593195"<sip:593195@sip.yarnet.ru:5066;transport=UDP>;tag=1c1bed69
Call-ID: MzBmODFlYTI5NGVmOWIyNzI4MmI4MjZjMzBiMWYyOWE.
CSeq: 1 REGISTER
Expires: 60
Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, MESSAGE, OPTIONS, INFO, SUBSCRIBE
Supported: replaces, norefersub, extended-refer, timer, X-cisco-serviceuri
User-Agent: Zoiper r21367
Allow-Events: presence, kpml
Content-Length: 0
G;™Tyr Ж Ж   E ¶ @ ?Э.е¶В]ћгККўpSIP/2.0 423 Interval Too Brief
Via: SIP/2.0/UDP 192.168.1.4:5066;rport=5066;received=93.158.227.20;branch=z9hG4bK-d8754z-14663d8931204245-1---d8754z-
From: "593195" <sip:593195@sip.yarnet.ru>;tag=1c1bed69
To: "593195" <sip:593195@sip.yarnet.ru>;tag=z9hG4bK-d8754z-14663d8931204245-1---d8754z-
CSeq: 1 REGISTER
Min-Expires: 100
Content-Length: 0
G;™TtЩ л л   E Ы~s @УD]ћг.е¶ВККЗи:REGISTER sip:sip.yarnet.ru:5066;transport=UDP SIP/2.0
Via: SIP/2.0/UDP 192.168.1.4:5066;branch=z9hG4bK-d8754z-00474dbfece109b0-1---d8754z-;rport
Max-Forwards: 70
CSeq: 2 REGISTER
Expires: 100
Content-Length: 0
G;™TЁr
G G   E 7 @ ?\.е¶В]ћгКК#ЂxSIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 192.168.1.4:5066;rport=5066;received=93.158.227.20;branch=z9hG4bK-d8754z-00474dbfece109b0-1---d8754z-
To: "593195" <sip:593195@sip.yarnet.ru>;tag=z9hG4bK-d8754z-00474dbfece109b0-1---d8754z-
CSeq: 2 REGISTER
User-Agent: Eltex ECSS-10 with SIP.pa.2.14.0.58
WWW-Authenticate: Digest realm="yarnet.domain",nonce="66d714f962a364ef576c5b28a0a7f893",algorithm=MD5
Content-Length: 0
Комментарий к файлу: zoiper с планшета соединяеться с провайдером sip
capture-PPPoE0-Dec 23 12-52-02 zoiper.zip [2.49 KiB]
capture-PPPoE0-Dec 23 13-35-44.zip [860 байт]
СообщениеДобавлено: Ср дек 24, 2014 11:46
Выложите дамп трафика именно при регистрации шлюза
СообщениеДобавлено: Ср дек 24, 2014 11:49
Данный вопрос достаточно подробно рассмотрен в F.A.Q. http://dlink.ru/ru/faq/95/
cron
