DVG-7111S зарегистрирован на FreePBX.
Он регистрируется на 15 секунд потом обрывается и через секунд 30 снова регистрируется, все постоянно и по кругу.
Лог с DVG-7111S
10-24-2014 15:40:12 Local2.Info 192.168.7.242 7062B87173E0-sip: SipLineRegStatus=0030444
10-24-2014 15:40:12 Local0.Emerg 192.168.7.242 7062B87173E0-sip: Reg Fail [560]
10-24-2014 15:39:52 Local2.Info 192.168.7.242 7062B87173E0-sip: SipLineRegStatus=0020444
10-24-2014 15:39:52 Local0.Notice 192.168.7.242 7062B87173E0-sip: Registered [560]
10-24-2014 15:39:14 Local2.Info 192.168.7.242 7062B87173E0-sip: SipLineRegStatus=0030444
10-24-2014 15:39:14 Local0.Emerg 192.168.7.242 7062B87173E0-sip: Reg Fail [560]
10-24-2014 15:38:53 Local2.Info 192.168.7.242 7062B87173E0-sip: SipLineRegStatus=0020444
10-24-2014 15:38:53 Local0.Notice 192.168.7.242 7062B87173E0-sip: Registered [560]
10-24-2014 15:38:19 Local1.Info 192.168.7.242 7062B87173E0-sip: 1: Idle
10-24-2014 15:38:15 Local1.Info 192.168.7.242 7062B87173E0-sip: 1: PlayBusyTone
10-24-2014 15:38:15 Local2.Info 192.168.7.242 7062B87173E0-sip: SipLineRegStatus=0030444
10-24-2014 15:38:15 Local0.Emerg 192.168.7.242 7062B87173E0-sip: Reg Fail [560]
10-24-2014 15:38:03 Local1.Info 192.168.7.242 7062B87173E0-sip: 1: GetDtmf
10-24-2014 15:38:03 Local1.Info 192.168.7.242 7062B87173E0-sip: 1: WaitAnswerDeviceOk
10-24-2014 15:37:54 Local2.Info 192.168.7.242 7062B87173E0-sip: SipLineRegStatus=0020444
10-24-2014 15:37:54 Local0.Notice 192.168.7.242 7062B87173E0-sip: Registered [560]
10-24-2014 15:37:19 Local2.Info 192.168.7.242 7062B87173E0-sip: SipLineRegStatus=0030444
10-24-2014 15:37:19 Local0.Emerg 192.168.7.242 7062B87173E0-sip: Reg Fail [560]
10-24-2014 15:36:55 Local2.Info 192.168.7.242 7062B87173E0-sip: SipLineRegStatus=0020444
10-24-2014 15:36:55 Local0.Notice 192.168.7.242 7062B87173E0-sip: Registered [560]
10-24-2014 15:36:17 Local2.Info 192.168.7.242 7062B87173E0-sip: SipLineRegStatus=0030444
10-24-2014 15:36:17 Local0.Emerg 192.168.7.242 7062B87173E0-sip: Reg Fail [560]
10-24-2014 15:35:56 Local2.Info 192.168.7.242 7062B87173E0-sip: SipLineRegStatus=0020444
10-24-2014 15:35:56 Local0.Notice 192.168.7.242 7062B87173E0-sip: Registered [560]
10-24-2014 15:35:18 Local2.Info 192.168.7.242 7062B87173E0-sip: SipLineRegStatus=0030444
10-24-2014 15:35:18 Local0.Emerg 192.168.7.242 7062B87173E0-sip: Reg Fail [560]
10-24-2014 15:34:57 Local2.Info 192.168.7.242 7062B87173E0-sip: SipLineRegStatus=0020444
10-24-2014 15:34:57 Local0.Notice 192.168.7.242 7062B87173E0-sip: Registered [560]
10-24-2014 15:34:19 Local2.Info 192.168.7.242 7062B87173E0-sip: SipLineRegStatus=0030444
10-24-2014 15:34:19 Local0.Emerg 192.168.7.242 7062B87173E0-sip: Reg Fail [560]
10-24-2014 15:33:59 Local0.Info 192.168.7.242 7062B87173E0-NCS: NCS: NTP time sync scheduled as 1440 minutes after to resync
10-24-2014 15:33:58 Local2.Info 192.168.7.242 7062B87173E0-sip: SipLineRegStatus=0020444
10-24-2014 15:33:58 Local0.Notice 192.168.7.242 7062B87173E0-sip: Registered [560]
10-24-2014 15:33:58 Local1.Info 192.168.7.242 7062B87173E0-sip: 1: Connect
10-24-2014 15:33:58 Local1.Info 192.168.7.242 7062B87173E0-sip: 1: Idle
10-24-2014 15:33:58 Local1.Info 192.168.7.242 7062B87173E0-sip: 0: Idle
10-24-2014 15:33:57 Local0.Info 192.168.7.242 7062B87173E0-NCS: NCS: SIPG started on DATA
10-24-2014 15:33:56 Local0.Info 192.168.7.242 7062B87173E0-NCS: NCS: IGMP service started
10-24-2014 15:33:56 Local0.Info 192.168.7.242 7062B87173E0-NCS: NCS: NTP time sync scheduled as 10 minutes after to retry
Со стороны * видно что он регистрируется, во время обрыва вызовы приходят на DVG
И еще такой момент, если набирать с DVG номер, то идут короткие гудки одновременно с потерей регистрации.
Не понимаю, почему не работает набор.
Настройки DVG
1.GIF [ 73.72 KiB | Просмотров: 2375 ]
Пытаюсь перепрошится на старую прошивку. но не выходит тоже самое что и тут
http://forum.dlink.ru/viewtopic.php?f=5&t=166856
