Здравствуйте!
Заметил, что когда в расписании включения/выключения DNS-345 на заданный день недели время выключения стоит
раньше времени включения, то расписание не работает. Например, если мне нужно каждый день выключать устройство в 00:15, а включать в 6:00, настраиваю расписание так:
01.jpg [ 132.27 KiB | Просмотров: 5809 ]
При этом устройство выключается в 00:15 и включается через несколько минут:
Sep 14 00:22:12 dlink-DNS-345 system_daemon: System is rebooted or power up successfully.
Sep 14 00:22:08 dlink-DNS-345 fan_control: Set Fan Speed To "STOP".
Sep 14 00:22:08 dlink-DNS-345 fan_control: Set Fan-Control Mode To "Auto(Off/Low/High)"
Sep 14 00:22:03 dlink-DNS-345 fan_control: Set Fan Speed To "High".
Sep 14 00:21:58 dlink-DNS-345 fan_control: Set Fan Speed To "LOW".
Sep 14 00:21:48 dlink-DNS-345 rtc: System Time Is Updated By RTC.
Sep 14 00:15:06 dlink-DNS-345 chk_io: System is shutting down.
Sep 12 01:05:28 dlink-DNS-345 fan_control: Set Fan Speed To "LOW".
Sep 12 00:20:19 dlink-DNS-345 fan_control: Set Fan Speed To "LOW".
Sep 12 00:18:17 dlink-DNS-345 system_daemon: System is rebooted or power up successfully.
Sep 12 00:18:15 dlink-DNS-345 fan_control: Set Fan Speed To "STOP".
Sep 12 00:18:15 dlink-DNS-345 fan_control: Set Fan-Control Mode To "Auto(Off/Low/High)"
Sep 12 00:18:11 dlink-DNS-345 fan_control: Set Fan Speed To "High".
Sep 12 00:18:05 dlink-DNS-345 fan_control: Set Fan Speed To "LOW".
Sep 12 00:17:55 dlink-DNS-345 rtc: System Time Is Updated By RTC.
Sep 12 00:15:07 dlink-DNS-345 chk_io: System is shutting down.
Sep 11 01:49:23 dlink-DNS-345 system_daemon: System is rebooted or power up successfully.
Sep 11 01:49:20 dlink-DNS-345 fan_control: Set Fan Speed To "STOP".
Sep 11 01:49:20 dlink-DNS-345 fan_control: Set Fan-Control Mode To "Auto(Off/Low/High)"
Sep 11 01:49:16 dlink-DNS-345 fan_control: Set Fan Speed To "High".
Sep 11 01:49:11 dlink-DNS-345 fan_control: Set Fan Speed To "LOW".
Sep 11 01:49:00 dlink-DNS-345 rtc: System Time Is Updated By RTC.
Sep 11 00:15:06 dlink-DNS-345 chk_io: System is shutting down.
Sep 11 00:04:46 dlink-DNS-345 fan_control: Set Fan Speed To "LOW".
Sep 10 00:17:07 dlink-DNS-345 fan_control: Fan2 Is Unable To Spin Or Fan2 Doesn't Exist.
Sep 10 00:17:07 dlink-DNS-345 fan_control: Fan1 Is Unable To Spin Or Fan1 Doesn't Exist.
Sep 10 00:17:04 dlink-DNS-345 fan_control: Set Fan Speed To "LOW".
Sep 10 00:16:04 dlink-DNS-345 system_daemon: System is rebooted or power up successfully.
Sep 10 00:16:00 dlink-DNS-345 fan_control: Set Fan Speed To "STOP".
Sep 10 00:16:00 dlink-DNS-345 fan_control: Set Fan-Control Mode To "Auto(Off/Low/High)"
Sep 10 00:15:55 dlink-DNS-345 fan_control: Set Fan Speed To "High".
Sep 10 00:15:50 dlink-DNS-345 fan_control: Set Fan Speed To "LOW".
Sep 10 00:15:40 dlink-DNS-345 rtc: System Time Is Updated By RTC.
Sep 10 00:13:34 dlink-DNS-345 chk_io: System is shutting down.
А вот если на заданный день недели время выключения стоит
позже времени включения, то расписание работает нормально. Например, если нужно каждый день включать в 6:00, а выключать устройство в 23:15, расписание будет такое:
02.jpg [ 136.52 KiB | Просмотров: 5809 ]
И это расписание будет работать!
Но, самое обидное, что мне нужно выключать NAS уже после 24-х часов каждый день, то есть я должен указывать время выключения
раньше времени включения. И такое расписание не работает.
Почему? Как настроить выключение, скажем на 01:00, а включение на 06:00?
Спасибо!
Информация об устройстве:
P/N: RNS345A2A...A2E
H/W: A2
F/W: 1.03 (FW_v1.03b06)
F/W OLED дисплея: 1.04
Дата выпуска программного обеспечения: 12/23/2013
