Текущее время: Чт авг 13, 2026 00:18
 Заголовок сообщения: Потери при включенном impb DES-3200 C1
СообщениеДобавлено: Вт окт 29, 2013 14:18
Здравствуйте! Есть проблема.
Периодически обращаются клиенты с потерями. Довольно жесткими потерями - до 50%, проблема почти всегда наблюдается вечером. Включен impb со следующими настройками:
config address_binding dhcp_snoop max_entry ports 1 limit no_limit
config address_binding ip_mac ports 1 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 2 limit no_limit
config address_binding ip_mac ports 2 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 3 limit no_limit
config address_binding ip_mac ports 3 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 4 limit no_limit
config address_binding ip_mac ports 4 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 5 limit no_limit
config address_binding ip_mac ports 5 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 6 limit no_limit
config address_binding ip_mac ports 6 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 7 limit no_limit
config address_binding ip_mac ports 7 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 8 limit no_limit
config address_binding ip_mac ports 8 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 9 limit no_limit
config address_binding ip_mac ports 9 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 10 limit no_limit
config address_binding ip_mac ports 10 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 11 limit no_limit
config address_binding ip_mac ports 11 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 12 limit no_limit
config address_binding ip_mac ports 12 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 13 limit no_limit
config address_binding ip_mac ports 13 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 14 limit no_limit
config address_binding ip_mac ports 14 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 15 limit no_limit
config address_binding ip_mac ports 15 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 16 limit no_limit
config address_binding ip_mac ports 16 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 17 limit no_limit
config address_binding ip_mac ports 17 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 18 limit no_limit
config address_binding ip_mac ports 18 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 19 limit no_limit
config address_binding ip_mac ports 19 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 20 limit no_limit
config address_binding ip_mac ports 20 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 21 limit no_limit
config address_binding ip_mac ports 21 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 22 limit no_limit
config address_binding ip_mac ports 22 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 23 limit no_limit
config address_binding ip_mac ports 23 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 24 limit no_limit
config address_binding ip_mac ports 24 stop_learning_threshold 5
config address_binding dhcp_snoop max_entry ports 25 limit no_limit
config address_binding dhcp_snoop max_entry ports 26 limit no_limit
config address_binding ip_mac ports 1-24 protocol ipv4
config address_binding ip_mac ports 1-4,6-24 arp_inspection loose
config address_binding ip_mac ports 1-24 allow_zeroip enable
enable address_binding dhcp_snoop
enable address_binding trap_log
disable address_binding dhcp_snoop ipv6
disable address_binding nd_snoop
config address_binding dhcp_snoop max_entry ports 1-26 limit no_limit ipv6
config address_binding nd_snoop ports 1-26 max_entry no_limit
Если выключить arp_inspection на порту - все отлично, потерь нет, работает идеально. Потери наблюдаются в режимах strict и loose. ip_inspection отключено. При потерях, как правило, на порту увеличивается счетчик дропов. Что делать, что проверить? Кто-то сталкивался с такой проблемой?
Пакеты теряются пачками по 10-15, иногда больше. При этом mac-адрес в fdb остается в состоянии forward. Проблема наблюдается только на ревизии C1, которую, похоже, создавали в аду. Прошивку хуже, чем под эту ревизию, даже намеренно тяжело сделать.
Пока что решаем проблемы у клиентов банальным отключением address_binding. Наблюдается на версиях прошивок:
4.34.B013
4.35.B016
4.36.B005
На 4.33, насколько помню, не наблюдалось такого, но могу ошибаться. Мог бы проверить, но пока что не хочется экспериментировать на клиентах.
 Заголовок сообщения: Re: Потери при включенном impb DES-3200 C1
СообщениеДобавлено: Пн дек 16, 2013 11:42
UP. Кто-нибудь еще сталкивался с подобной проблемой?
СообщениеДобавлено: Пн дек 16, 2013 20:14
Что-то такое наблюдали. После перешли на 4.36. Теперь вопрос требует уточнения. Понаблюдаю - отпишусь.
СообщениеДобавлено: Чт янв 16, 2014 13:54
Да, тоже возникают похожие проблемы. Иногда потери, иногда просто пропадает рандомно интернет. В логах свитча чисто. Помагает отключение IPMPB. В преобладающем большинстве случаев это происходит там, где более одной привязки (тоесть более одного абонента на порт). Так и не нашел общей зависимости, и как повторить этот баг.
Не важно веришь ли ты в бога, важно верит ли он в тебя...
СообщениеДобавлено: Ср янв 29, 2014 16:23
UP. Хочется внятных комментариев представителей D-Link.
СообщениеДобавлено: Вт июл 15, 2014 12:26
UP!!!!!
D-Link user:
DES-3526, fw ver. 6.00.B58 / DES-3200-28 A1/B1, fw ver. 1.80.B006
DGS-3312SR / DGS-3612 / DES-1226G / DMC-810SC / DIR-100 / DIR-620 / DIB-120
СообщениеДобавлено: Вт июл 15, 2014 13:25
Сотня девайсин Ц серии, прошива 4.36.B009
disable address_binding roaming
config address_binding dhcp_snoop max_entry ports 1-24 limit 2
config address_binding ip_mac ports 1-$max_client_port arp_inspection strict ip_inspection disable allow_zeroip enable forward_dhcppkt enable stop_learning_threshold 50
Ни днем, ни ночью, ни в ЧНН, описанных ТС дропов не наблюдается.
СообщениеДобавлено: Ср июл 16, 2014 04:20
в моем случае обрывы при одновременно включенном arp и ip inspection
D-Link user:
СообщениеДобавлено: Ср июл 16, 2014 12:25
и IMPB у вас в ACL моде?
СообщениеДобавлено: Чт июл 17, 2014 04:07
А на С1 нет ACL mode. На них эту роль на сколько я понимаю выполняет ip_inspection.
СообщениеДобавлено: Чт июл 17, 2014 05:35
на С1 нет понятия режим ARP/ACL
там есть arp_inspection и ip_inspection
так вот при включении обоих режимов наблюдаются жесткие потери пакетов... связь рвется...
D-Link user:
СообщениеДобавлено: Чт июл 17, 2014 12:41
как это нет?
viewtopic.php?f=2&t=166290
СообщениеДобавлено: Пт июл 18, 2014 09:05
Угу и включается это так:
config address_binding ip_mac ports 1 ip_inspection enable
Почему то тут нет упоминания acl. В старой ревизии было так:
config address_binding ip_mac ports 1 mode acl
Понятно что это одно и тоже, я по крайней мере так думаю :)
atx написал, что ip_inspection включен, по этому следом спрашивать включен ли ACL ...
По этому я это и написал.
СообщениеДобавлено: Ср июл 30, 2014 11:36
vcvitaly
Логи включены?
СообщениеДобавлено: Чт июл 31, 2014 06:29
В моем случае включены.
Сейчас этот форум просматривают: Google [Bot] и гости: 13
