Текущее время: Сб авг 29, 2026 21:48
 Заголовок сообщения: DGS-1100-06/ME ISM VLAN
СообщениеДобавлено: Ср апр 16, 2014 13:08
Имеется коммутатор:
# show switch
Command: show switch
Device Type                       : DGS-1100-06/ME
MAC Address                       : 9C-D6-43-86-F5-D9
IP Address                        : 10.25.19.48 (Manual)
VLAN Name                         : Managment
Subnet Mask                       : 255.255.255.0
Default Gateway                   :10.25.19.1
System Boot Version               : 1.00.000
System Protocol Version           : 2.001.004
System Firmware Version           : 1.00.B060
System Hardware Version           : A1
IGMP Snooping                     : Enabled
802.1X Status                     : Disabled
Telnet                            : Enabled (TCP 23)
Web                               : Disabled (TCP 80)
RMON                              : Disabled
Syslog Global State               : Enabled
SSL                               : Disabled
CLI Paging                        : Enabled
Password Encryption State         : Enabled
Планируется установка его на доступ.
Схема примерно такая:
Vlan на абонентов - 533
multicast vlan 899 (ISM vlan) - 899
На коммуттаоре включаю igmp_snooping
# IGMP snooping
enable igmp_snooping
config igmp_snooping all router_timeout 125
config igmp_snooping all host_timeout 260
config igmp_snooping all leave_timer 1
config igmp_snooping querier vlanid 1 state disable robustness_variable 2
config igmp_snooping querier vlanid 1 state disable query_interval 125
config igmp_snooping querier vlanid 1 state disable max_response_time 10
disable igmp_snooping forward_mcrouter_only
config igmp_snooping vlan_name "default" state disable fast_leave disable
config igmp_snooping querier vlan_name "default" state disable querier_version 2 last_member_query_interval 1
config igmp_snooping vlan_name "Managment" state disable fast_leave disable
config igmp_snooping querier vlan_name "Managment" state disable querier_version 2 last_member_query_interval 1
config igmp_snooping vlan_name "Customers" state disable fast_leave disable
config igmp_snooping querier vlan_name "Customers" state disable querier_version 2 last_member_query_interval 1
config igmp_snooping vlan_name "IPTV" state enable fast_leave disable
config igmp_snooping querier vlan_name "IPTV" state disable querier_version 2 last_member_query_interval 1
config igmp access_authentication ports 1-6 state disable
А так же настраиваю ism vlan
# ISM vlan
enable igmp_snooping multicast_vlan
create igmp_snooping multicast_vlan "IPTV" 890
config igmp_snooping multicast_vlan "IPTV" add member_port 1-4
config igmp_snooping multicast_vlan "IPTV" add source_port 5-6
config igmp_snooping multicast_vlan "IPTV" state enable
config igmp_snooping multicast_vlan "IPTV" replace_source_ip none
config mld_snooping multicast_vlan "IPTV" replace_source_ipv6 none
порты 1-4 - customers
порты 5-6 - Uplink
на коммуттаторе имеются след vlan:
#sh vlan
Command: show vlan
VID                : 1         VLAN NAME      : default
VLAN Type          : Static
Member Ports       :
Untagged Ports     :
VID                : 111       VLAN NAME      : Managment
VLAN Type          : Static
Member Ports       : 5-6
Untagged Ports     :
VID                : 533       VLAN NAME      : Customers
VLAN Type          : Static
Member Ports       : 1-6
Untagged Ports     : 1-4
# show port_vlan pvid
Command: show port_vlan pvid
 Port     PVID
  01       533
  02       533
  03       533
  04       533
  05         1
  06         1
На выходе получаю igmp запросы в пользовательском vlan, а не в ism (multicast) "IPTV" 899.
Как настроить так, чтоб работал ism vlan, и запросы на группы, от пользователей, я получал в ism (multicast) "IPTV" 899.
P.s. на DGS-3120-24 Всё работает отлично.
К тому же этот коммутатор шлёт запросы на все порты, не только на "uplink", а так же и на "customer", хотя igmp filtering включен, и в ism vlan указаны порты "приёмники" и "источники".
# show multicast filter port_mode
Command: show multicast filter port_mode
 Port      Multicast Filtering Mode
    1    Filtering Unregistered Groups
    2    Filtering Unregistered Groups
    3    Filtering Unregistered Groups
    4    Filtering Unregistered Groups
    5    Forward Unregistered Groups
    6    Forward Unregistered Groups
 Заголовок сообщения: Re: DGS-1100-06/ME ISM VLAN
СообщениеДобавлено: Ср апр 16, 2014 13:09
config igmp_snooping multicast_vlan_group IPTV add ipv4_range 239.X.X.X 239.X.X.X
create mcast_filter_profile ipv4 profile_id 1 profile_name IPTV_ALL
config mcast_filter_profile profile_id 1 add 239.X.X.X 239.X.X.X
config limited_multicast_addr ports 1-6 ipv4 add profile_id 1
СообщениеДобавлено: Ср апр 16, 2014 13:14
Блин. Ведь и правда же. Группы кто будет указывать. :)
Alexey Mishenko
Большое спасибо. Заработало.
Сейчас этот форум просматривают: Baidu [Spider], Google [Bot] и гости: 13
