Текущее время: Вт ноя 10, 2026 11:03
 Заголовок сообщения: DSR и IPSec
СообщениеДобавлено: Чт мар 20, 2014 11:32
Что за странные ошибки при подключении?
Sat Jan 01 00:09:27 2011 (GMT +0400): [DSR-250] [IKE] INFO: Sending Informational Exchange: notify payload[10381]
Sat Jan 01 00:09:06 2011 (GMT +0400): [DSR-250] [IKE] INFO: Sending Informational Exchange: notify payload[10381]
Sat Jan 01 00:08:31 2011 (GMT +0400): [DSR-250] [IKE] INFO: Sending Informational Exchange: notify payload[10381]
Sat Jan 01 00:08:21 2011 (GMT +0400): [DSR-250] [IKE] INFO: Sending Informational Exchange: notify payload[10381]
Sat Jan 01 00:08:11 2011 (GMT +0400): [DSR-250] [IKE] INFO: Sending Informational Exchange: notify payload[10381]
Sat Jan 01 00:08:01 2011 (GMT +0400): [DSR-250] [IKE] INFO: Sending Informational Exchange: notify payload[10381]
Sat Jan 01 00:07:51 2011 (GMT +0400): [DSR-250] [IKE] INFO: Sending Informational Exchange: notify payload[10381]
Sat Jan 01 00:07:41 2011 (GMT +0400): [DSR-250] [IKE] INFO: Sending Informational Exchange: notify payload[10381]
Sat Jan 01 00:05:56 2011 (GMT +0400): [DSR-250] [IKE] INFO: IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 10.10.2.145->XX.XX.XX.XX with spi=3274755544(0xc330cdd8)
Sat Jan 01 00:05:56 2011 (GMT +0400): [DSR-250] [IKE] INFO: IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel XX.XX.XX.XX->10.10.2.145 with spi=217966769(0xcfde8b1)
Sat Jan 01 00:05:56 2011 (GMT +0400): [DSR-250] [IKE] INFO: Adjusting peer's encmode 3(3)->Tunnel(1)
Sat Jan 01 00:05:56 2011 (GMT +0400): [DSR-250] [IKE] WARNING: attribute has been modified.
Sat Jan 01 00:05:56 2011 (GMT +0400): [DSR-250] [IKE] INFO: Adjusting encryption mode to use UDP encapsulation
Sat Jan 01 00:05:56 2011 (GMT +0400): [DSR-250] [IKE] INFO: Initiating new phase 2 negotiation: 10.10.2.145[0]<=>XX.XX.XX.XX[0]
Sat Jan 01 00:05:55 2011 (GMT +0400): [DSR-250] [IKE] INFO: Sending Informational Exchange: notify payload[608]
Sat Jan 01 00:05:55 2011 (GMT +0400): [DSR-250] [IKE] INFO: ISAKMP-SA established for 10.10.2.145[4500]-XX.XX.XX.XX[4500] with spi:ce69a1f509eee653:982a66dd4c3a364f
Sat Jan 01 00:05:53 2011 (GMT +0400): [DSR-250] [IKE] INFO: for debugging :: changing portsSat Jan 01 00:05:53 2011 (GMT +0400): [DSR-250] [IKE] INFO: port changed !!
Sat Jan 01 00:05:53 2011 (GMT +0400): [DSR-250] [IKE] INFO: NAT detected: ME
Sat Jan 01 00:05:53 2011 (GMT +0400): [DSR-250] [IKE] INFO: NAT-D payload matches for XX.XX.XX.XX4[500]
Sat Jan 01 00:05:53 2011 (GMT +0400): [DSR-250] [IKE] INFO: NAT-D payload does not match for 10.10.2.145[500]
Sat Jan 01 00:05:49 2011 (GMT +0400): [DSR-250] [IKE] INFO: For XX.XX.XX.XX[500], Selected NAT-T version: RFC 3947
Sat Jan 01 00:05:49 2011 (GMT +0400): [DSR-250] [IKE] INFO: Received Vendor ID: DPD
Sat Jan 01 00:05:49 2011 (GMT +0400): [DSR-250] [IKE] INFO: Received Vendor ID: RFC 3947
Sat Jan 01 00:05:49 2011 (GMT +0400): [DSR-250] [IKE] INFO: Received Vendor ID: draft-ietf-ipsra-isakmp-xauth-06.txt
Sat Jan 01 00:05:49 2011 (GMT +0400): [DSR-250] [IKE] INFO: [isakmp_ident.c:190]: XXX: setting vendorid: 9
Sat Jan 01 00:05:49 2011 (GMT +0400): [DSR-250] [IKE] INFO: [isakmp_ident.c:190]: XXX: setting vendorid: 8
Sat Jan 01 00:05:49 2011 (GMT +0400): [DSR-250] [IKE] INFO: [isakmp_ident.c:190]: XXX: setting vendorid: 4
Sat Jan 01 00:05:49 2011 (GMT +0400): [DSR-250] [IKE] INFO: [isakmp_ident.c:186]: XXX: NUMNATTVENDORIDS: 3
Sat Jan 01 00:05:49 2011 (GMT +0400): [DSR-250] [IKE] INFO: Beginning Identity Protection mode.
Sat Jan 01 00:05:49 2011 (GMT +0400): [DSR-250] [IKE] INFO: Initiating new phase 1 negotiation: 10.10.2.145[500]<=>XX.XX.XX.XX[500]
Sat Jan 01 00:05:49 2011 (GMT +0400): [DSR-250] [IKE] INFO: Configuration found for XX.XX.XX.XX.
Sat Jan 01 00:05:49 2011 (GMT +0400): [DSR-250] [IKE] INFO: Using IPsec SA configuration: 10.0.106.0/24<->0.0.0.0/0
Sat Jan 01 00:05:47 2011 (GMT +0400): [DSR-250] [IKE] ERROR: Phase 2 negotiation failed due to time up waiting for phase1. ESP XX.XX.XX.XX->10.10.2.145
Sat Jan 01 00:05:37 2011 (GMT +0400): [DSR-250] [IKE] ERROR: Phase 1 negotiation failed due to time up for XX.XX.XX.XX[4500]. 314d76fa9d2759b8:47fd20ec2aa1d8f9
Sat Jan 01 00:04:30 2011 (GMT +0400): [DSR-250] [IKE] INFO: Configuration found for XX.XX.XX.XX.
Sat Jan 01 00:04:30 2011 (GMT +0400): [DSR-250] [IKE] INFO: Using IPsec SA configuration: 10.0.106.0/24<->0.0.0.0/0
Sat Jan 01 00:04:28 2011 (GMT +0400): [DSR-250] [IKE] ERROR: Phase 2 negotiation failed due to time up waiting for phase1. ESP XX.XX.XX.XX->10.10.2.145
Sat Jan 01 00:03:47 2011 (GMT +0400): [DSR] [IKE] INFO: Configuration found for XX.XX.XX.XX.
Sat Jan 01 00:03:47 2011 (GMT +0400): [DSR] [IKE] INFO: Using IPsec SA configuration: 10.0.106.0/24<->0.0.0.0/0
Sat Jan 01 00:03:46 2011 (GMT +0400): [DSR] [IKE] ERROR: Phase 2 negotiation failed due to time up waiting for phase1. ESP XX.XX.XX.XX->10.10.2.145
Sat Jan 01 00:03:07 2011 (GMT +0000): [DSR] [IKE] INFO: for debugging :: changing ports
Sat Jan 01 00:03:07 2011 (GMT +0000): [DSR] [IKE] INFO: port changed !!
Sat Jan 01 00:03:07 2011 (GMT +0000): [DSR] [IKE] INFO: NAT detected: ME
Sat Jan 01 00:03:07 2011 (GMT +0000): [DSR] [IKE] INFO: NAT-D payload matches for XX.XX.XX.XX[500]
Sat Jan 01 00:03:07 2011 (GMT +0000): [DSR] [IKE] INFO: NAT-D payload does not match for 10.10.2.145[500]
Sat Jan 01 00:02:39 2011 (GMT +0000): [DSR] [IKE] INFO: For XX.XX.XX.XX[500], Selected NAT-T version: RFC 3947
Sat Jan 01 00:02:39 2011 (GMT +0000): [DSR] [IKE] INFO: Received Vendor ID: DPD
Sat Jan 01 00:02:39 2011 (GMT +0000): [DSR] [IKE] INFO: Received Vendor ID: RFC 3947
Sat Jan 01 00:02:39 2011 (GMT +0000): [DSR] [IKE] INFO: Received Vendor ID: draft-ietf-ipsra-isakmp-xauth-06.txt
Sat Jan 01 00:02:39 2011 (GMT +0000): [DSR] [IKE] INFO: [isakmp_ident.c:190]: XXX: setting vendorid: 9
Sat Jan 01 00:02:39 2011 (GMT +0000): [DSR] [IKE] INFO: [isakmp_ident.c:190]: XXX: setting vendorid: 8
Sat Jan 01 00:02:39 2011 (GMT +0000): [DSR] [IKE] INFO: [isakmp_ident.c:190]: XXX: setting vendorid: 4
Sat Jan 01 00:02:39 2011 (GMT +0000): [DSR] [IKE] INFO: [isakmp_ident.c:186]: XXX: NUMNATTVENDORIDS: 3
Sat Jan 01 00:02:39 2011 (GMT +0000): [DSR] [IKE] INFO: Beginning Identity Protection mode.
Sat Jan 01 00:02:39 2011 (GMT +0000): [DSR] [IKE] INFO: Initiating new phase 1 negotiation: 10.10.2.145[500]<=>XX.XX.XX.XX[500]
Sat Jan 01 00:02:39 2011 (GMT +0000): [DSR] [IKE] INFO: Configuration found for XX.XX.XX.XX.
Sat Jan 01 00:02:39 2011 (GMT +0000): [DSR] [IKE] INFO: Using IPsec SA configuration: 10.0.106.0/24<->0.0.0.0/0
Sat Jan 01 00:02:39 2011 (GMT +0000): [DSR] [IKE] INFO: Adding IKE configuration with identifier "XXX"
Sat Jan 01 00:02:39 2011 (GMT +0000): [DSR] [IKE] INFO: Adding IPSec configuration with identifier "XX"
Sat Jan 01 00:02:39 2011 (GMT +0000): [DSR] [IKE] ERROR: No policy found: 0.0.0.0/0[0] 10.0.106.0/24[0] proto=any dir=in
Sat Jan 01 00:02:39 2011 (GMT +0000): [DSR] [IKE] ERROR: No policy found: 10.0.106.0/24[0] 0.0.0.0/0[0] proto=any dir=out
Sat Jan 01 00:00:36 2011 (GMT +0000): [DSR-250] [IKE] INFO: IKE started
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 39
