Текущее время: Чт сен 10, 2026 16:06
Начать новую тему Ответить на тему  [ Сообщений: 1490 ]  На страницу Пред.  1 ... 25, 26, 27, 28, 29, 30, 31 ... 100  След.
СообщениеДобавлено: Сб дек 07, 2013 12:19
только Traffic control(Flow Control - это имеете ввиду?) выключен
вот конфиг с рабочего свича.
# DES-1210-28/ME Fast Ethernet Switch Configuration
# Firmware: Build 6.02.B036
# Copyright(C) 2010 D-Link Corporation. All rights reserved.
command-start
# Basic
config syslogintimeout 5
config sysgroupinterval 0
enable web 80
enable clipaging
config command_prompt default
config serial_port baud_rate 9600
config serial_port auto_logout 10_minutes
# Gratuitous Arp
config gratuitous_arp send ipif_status_up disable
config gratuitous_arp send dup_ip_detected disable
config gratuitous_arp learning disable
config gratuitous_arp send periodically interval 0
# Arp Aging Time
config arp_aging time 5
# FDB Aging Time
config fdb aging_time 300
# Telnet Setting
enable telnet 23
# Vlan
disable asymmetric_vlan
config vlan vlanid 1 delete 1-28
config vlan vlanid 1 advertisement disable
create vlan "admin" tag 110
config vlan vlanid 110 delete 1-28
config vlan vlanid 110 add tagged 25-28
config vlan vlanid 110 advertisement disable
create vlan "64.0" tag 301
config vlan vlanid 301 delete 1-28
config vlan vlanid 301 add tagged 25-28
config vlan vlanid 301 add untagged 1-24
config vlan vlanid 301 advertisement disable
enable management vlan
config management vlan "admin"
enable pvid auto_assign
# Multicast Filter
config multicast filter 1-28 filter
# IMPBv2
config address_binding ip_mac ports 1-24 arp_inspection strict ip_inspection enable state enable allow_zeroip enable forward_dhcppkt enable
config address_binding ip_mac ports 25-28 arp_inspection disable ip_inspection disable state disable allow_zeroip disable forward_dhcppkt enable
enable address_binding dhcp_snoop ports 1-24
config address_binding dhcp_snoop max_entry ports 1-28 limit no_limit
config address_binding dhcp_snoop max_entry ports 1-28 limit no_limit IPv6
disable address_binding dhcp_snoop ports 25-28
create address_binding ip_mac ipaddress 192.168.64.14 mac_address 90-2b-34-5d-5e-55 port 5
config filter dhcp_server illegal_server_log_suppress_duration 5min
# IP
config ipif System ipaddress 192.168.57.21/255.255.255.0
create iproute default 192.168.57.254 1
config ipif System dhcp_option12 state disable
config ipif System dhcp_option12 hostname DES-1210-28/ME
config ipif System dhcpv6_client disable
config ipv6 nd ns ipif System retrans_time 1
disable ipif_ipv6_link_local_auto System
config ipif System ipv6 state enable
disable autoconfig
config autoconfig timeout 50
# STP
enable stp
config stp version rstp
config stp priority 32768 instance_id 0
config stp txholdcount 6 maxage 20 hellotime 2 forwarddelay 15
config stp fbpdu enable
config stp ports 1-24 externalcost 2000000 edge true restricted_tcn true restricted_role true p2p auto state disable priority 128 fbpdu disable
config stp ports 25-26 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state enable priority 128 fbpdu enable
config stp ports 27 externalcost auto edge auto restricted_tcn true restricted_role false p2p auto state enable priority 128 fbpdu enable
config stp ports 28 externalcost auto edge auto restricted_tcn false restricted_role false p2p auto state enable priority 128 fbpdu enable
config stp mst_config_id name C0-A0-BB-60-F2-49 revision_level 0
# traffic segmentation
config traffic_segmentation 1-28 forward_list 1-28
# LLDP
disable lldp
config lldp message_tx_hold_multiplier 4
config lldp message_tx_interval 30
config lldp reinit_delay 2
config lldp tx_delay 2
config lldp ports 1-28 mgt_addr ipv4 192.168.57.21 disable
config lldp ports 1-28 admin_status tx_and_rx
config lldp ports 1-28 notification disable
config lldp ports 1-28 basic_tlvs all disable
config lldp ports 1-28 dot1_tlv_pvid disable
config lldp ports 1-28 dot1_tlv_vlan_name vlanid 1-4094 disable
config lldp ports 1-28 dot1_tlv_protocol_identity eapol disable
config lldp ports 1-28 dot1_tlv_protocol_identity lacp disable
config lldp ports 1-28 dot1_tlv_protocol_identity gvrp disable
config lldp ports 1-28 dot1_tlv_protocol_identity stp disable
config lldp ports 1-28 dot3_tlvs all disable
# QoS
config scheduling_mechanism strict
config scheduling 0 weight 1
config scheduling 1 weight 2
config scheduling 2 weight 4
config scheduling 3 weight 8
config 802.1p default_priority 1-28 0
config 802.1p user_priority 0 1
config 802.1p user_priority 1 0
config 802.1p user_priority 2 0
config 802.1p user_priority 3 1
config 802.1p user_priority 4 2
config 802.1p user_priority 5 2
config 802.1p user_priority 6 3
config 802.1p user_priority 7 3
config dscp_mapping dscp_value 0 class 0
config dscp_mapping dscp_value 1 class 0
config dscp_mapping dscp_value 2 class 0
config dscp_mapping dscp_value 3 class 0
config dscp_mapping dscp_value 4 class 0
config dscp_mapping dscp_value 5 class 0
config dscp_mapping dscp_value 6 class 0
config dscp_mapping dscp_value 7 class 0
config dscp_mapping dscp_value 8 class 0
config dscp_mapping dscp_value 9 class 0
config dscp_mapping dscp_value 10 class 0
config dscp_mapping dscp_value 11 class 0
config dscp_mapping dscp_value 12 class 0
config dscp_mapping dscp_value 13 class 0
config dscp_mapping dscp_value 14 class 0
config dscp_mapping dscp_value 15 class 0
config dscp_mapping dscp_value 16 class 0
config dscp_mapping dscp_value 17 class 0
config dscp_mapping dscp_value 18 class 0
config dscp_mapping dscp_value 19 class 0
config dscp_mapping dscp_value 20 class 0
config dscp_mapping dscp_value 21 class 0
config dscp_mapping dscp_value 22 class 0
config dscp_mapping dscp_value 23 class 0
config dscp_mapping dscp_value 24 class 0
config dscp_mapping dscp_value 25 class 0
config dscp_mapping dscp_value 26 class 0
config dscp_mapping dscp_value 27 class 0
config dscp_mapping dscp_value 28 class 0
config dscp_mapping dscp_value 29 class 0
config dscp_mapping dscp_value 30 class 0
config dscp_mapping dscp_value 31 class 0
config dscp_mapping dscp_value 32 class 0
config dscp_mapping dscp_value 33 class 0
config dscp_mapping dscp_value 34 class 0
config dscp_mapping dscp_value 35 class 0
config dscp_mapping dscp_value 36 class 0
config dscp_mapping dscp_value 37 class 0
config dscp_mapping dscp_value 38 class 0
config dscp_mapping dscp_value 39 class 0
config dscp_mapping dscp_value 40 class 0
config dscp_mapping dscp_value 41 class 0
config dscp_mapping dscp_value 42 class 0
config dscp_mapping dscp_value 43 class 0
config dscp_mapping dscp_value 44 class 0
config dscp_mapping dscp_value 45 class 0
config dscp_mapping dscp_value 46 class 0
config dscp_mapping dscp_value 47 class 0
config dscp_mapping dscp_value 48 class 0
config dscp_mapping dscp_value 49 class 0
config dscp_mapping dscp_value 50 class 0
config dscp_mapping dscp_value 51 class 0
config dscp_mapping dscp_value 52 class 0
config dscp_mapping dscp_value 53 class 0
config dscp_mapping dscp_value 54 class 0
config dscp_mapping dscp_value 55 class 0
config dscp_mapping dscp_value 56 class 0
config dscp_mapping dscp_value 57 class 0
config dscp_mapping dscp_value 58 class 0
config dscp_mapping dscp_value 59 class 0
config dscp_mapping dscp_value 60 class 0
config dscp_mapping dscp_value 61 class 0
config dscp_mapping dscp_value 62 class 0
config dscp_mapping dscp_value 63 class 0
config cos mapping port 1-28 none
config cos mapping port 1-28 802.1p
config cos mapping port 1-28 dscp
config cos tos value 0 class 0
config cos tos value 1 class 0
config cos tos value 2 class 0
config cos tos value 3 class 0
config cos tos value 4 class 0
config cos tos value 5 class 0
config cos tos value 6 class 0
config cos tos value 7 class 0
config dscp mode
config bandwidth_control 1-28 rx_rate no_limit tx_rate no_limit
# FDB (forwarding data base)
enable auto learning
create fdb 64.0 90-2B-34-5D-5E-55 port 5
create fdb ism-1 90-2B-34-5D-5E-55 port 5
# Syslog
disable syslog
config log_save_timing on_demand
# ACL
# SNMP
enable snmp
create snmp user ReadOnly ReadOnly v1
create snmp user ReadOnly ReadOnly v2c
create snmp user ReadWrite ReadWrite v1
create snmp user ReadWrite ReadWrite v2c
create snmp group ReadOnly v1 read_view ReadWrite notify_view ReadWrite
create snmp group ReadOnly v2c read_view ReadWrite notify_view ReadWrite
create snmp group ReadWrite v1 read_view ReadWrite write_view ReadWrite notify_view ReadWrite
create snmp group ReadWrite v2c read_view ReadWrite write_view ReadWrite notify_view ReadWrite
create snmp view ReadWrite 1 1 view_type included
create snmp community public ReadOnly
create snmp community private ReadWrite
config snmp engineID 4445532d313231302d3238c0a0bb60f249
disable snmp authenticate traps
config snmp coldstart_traps disable
config snmp warmstart_traps disable
disable snmp linkchange_traps
config snmp linkchange_traps ports 1-28 disable
disable snmp rstpport_state_change traps
disable snmp firmware_upgrade_state traps
disable snmp port_security_violation traps
disable snmp IMPB_violation traps
disable snmp LBD traps
disable snmp DHCP_screening traps
disable snmp duplicate_IP_detected traps
# IPv6 Neighbor_cache
# port security
config port_security 1-28 admin_state disable max_learning_addr 0 lock_address_mode DeleteOnTimeout
# MAC address table notification
disable mac_notification
config mac_notification interval 1
config mac_notification historysize 1
config mac_notification ports 1-28 disable
# SNTP
config time 03jan2012 16:31:43
config sntp primary 0.0.0.0 secondary 0.0.0.0 poll-interval 30
disable sntp
config time_zone operator + hour 0 minute 0
config dst disable
# DHCP_RELAY
enable dhcp_relay
config dhcp_relay hops 16
config dhcp_relay time 0
config dhcp_relay port 1-28 state disable
config dhcp_relay port 1-24 state enable
config dhcp_relay vlan vlanid 1,110 state enable
config dhcp_relay vlan vlanid 301 state enable
config dhcp_relay add ipif System 192.168.56.100
config dhcp_relay option_82 state enable
config dhcp_relay option_82 check disable
config dhcp_relay option_82 policy keep
config dhcp_relay option_82 remote_id user_define 192.168.57.21
disable dhcp_local_relay
disable dhcpv6_relay
config dhcpv6_relay hop_count 4
config dhcpv6_relay option_37 state enable
config dhcpv6_relay option_37 check enable
config dhcpv6_relay option_37 remote_id default
config dhcpv6_relay option_38 ports 1-28 state disable subscriber_id default
# GVRP
disable gvrp
config gvrp 1-24 pvid 301
config gvrp 1-28 state disable
config gvrp 1-28 ingress_checking enable
config gvrp 1-28 acceptable_frame All_Frames
config gvrp 25-28 pvid 1
config gvrp timer join_timer 200
config gvrp timer leave_timer 600
config gvrp timer leave-all_timer 10000
# Loopback Detection
enable loopdetect
config loopdetect mode portbase
config loopdetect interval_time 2
config loopdetect lbd_recover_time 60
config loopdetect ports 1 state enable
config loopdetect ports 2 state enable
config loopdetect ports 3 state enable
config loopdetect ports 4 state enable
config loopdetect ports 5 state enable
config loopdetect ports 6 state enable
config loopdetect ports 7 state enable
config loopdetect ports 8 state enable
config loopdetect ports 9 state enable
config loopdetect ports 10 state enable
config loopdetect ports 11 state enable
config loopdetect ports 12 state enable
config loopdetect ports 13 state enable
config loopdetect ports 14 state enable
config loopdetect ports 15 state enable
config loopdetect ports 16 state enable
config loopdetect ports 17 state enable
config loopdetect ports 18 state enable
config loopdetect ports 19 state enable
config loopdetect ports 20 state enable
config loopdetect ports 21 state enable
config loopdetect ports 22 state enable
config loopdetect ports 23 state enable
config loopdetect ports 24 state enable
# BPDU Attack Protection
disable bpdu_protection
config bpdu_protection recovery_timer 60
config bpdu_protection ports 1-28 state disable mode shutdown
config bpdu_protection trap none
config bpdu_protection log none
# SMTP
disable smtp
config smtp server 0.0.0.0 server_port 25
# traffic control
config traffic trap none
config traffic control 1-28 broadcast disable multicast disable unicast disable action drop
# RMON
disable rmon
# ISM vlan
enable igmp_snooping multicast_vlan
create igmp_snooping multicast_vlan "ism-1" 555
config igmp_snooping multicast_vlan "ism-1" add member_port 1-24
config igmp_snooping multicast_vlan "ism-1" add source_port 25-28
config igmp_snooping multicast_vlan "ism-1" state enable
config igmp_snooping multicast_vlan "ism-1" replace_source_ip 192.168.102.23
config mld_snooping multicast_vlan "ism-1" replace_source_ipv6 none
config igmp_snooping multicast_vlan_group "ism-1" add ipv4_range 239.10.10.1 239.10.10.254
# IGMP snooping
config igmp_snooping all router_timeout 125
config igmp_snooping all host_timeout 260
config igmp_snooping all leave_timer 1
config igmp_snooping querier vlanid 1 state disable robustness_variable 2
config igmp_snooping querier vlanid 1 state disable query_interval 125
config igmp_snooping querier vlanid 1 state disable max_response_time 10
config igmp_snooping data_driven_learning max_learned_entry 256
disable igmp_snooping forward_mcrouter_only
config igmp_snooping vlan_name "default" state disable fast_leave disable
config igmp_snooping data_driven_learning vlan_name "default" state disable
config igmp_snooping data_driven_learning vlan_name "default" aged_out disable
config igmp_snooping querier vlan_name "default" state disable querier_version 2 last_member_query_interval 1
config igmp_snooping vlan_name "admin" state disable fast_leave disable
config igmp_snooping data_driven_learning vlan_name "admin" state disable
config igmp_snooping data_driven_learning vlan_name "admin" aged_out disable
config igmp_snooping querier vlan_name "admin" state disable querier_version 2 last_member_query_interval 1
config igmp_snooping vlan_name "64.0" state disable fast_leave disable
config igmp_snooping data_driven_learning vlan_name "64.0" state disable
config igmp_snooping data_driven_learning vlan_name "64.0" aged_out disable
config igmp_snooping querier vlan_name "64.0" state disable querier_version 2 last_member_query_interval 1
config igmp_snooping vlan_name "ism-1" state enable fast_leave enable
config igmp_snooping data_driven_learning vlan_name "ism-1" state enable
config igmp_snooping data_driven_learning vlan_name "ism-1" aged_out disable
config igmp_snooping querier vlan_name "ism-1" state disable querier_version 2 last_member_query_interval 1
config router_ports_forbidden vlan_name "ism-1" add 1-24
config igmp access_authentication ports 1-28 state disable
# MLD Snooping
disable mld_snooping
config mld_snooping all router_timeout 125
config mld_snooping all host_timeout 260
config mld_snooping all leave_timer 1
config mld_snooping querier all robustness_variable 2
config mld_snooping querier all query_interval 125
config mld_snooping querier all max_response_time 10
config mld_snooping data_driven_learning max_learned_entry 256
config mld_snooping vlan_name "default" state disable fast_done disable
config mld_snooping data_driven_learning vlan_name "default" state disable
config mld_snooping querier vlan_name "default" state disable
config mld_snooping vlan_name "admin" state disable fast_done disable
config mld_snooping data_driven_learning vlan_name "admin" state disable
config mld_snooping querier vlan_name "admin" state disable
config mld_snooping vlan_name "64.0" state disable fast_done disable
config mld_snooping data_driven_learning vlan_name "64.0" state disable
config mld_snooping querier vlan_name "64.0" state disable
config mld_snooping vlan_name "ism-1" state disable fast_done disable
config mld_snooping data_driven_learning vlan_name "ism-1" state disable
config mld_snooping querier vlan_name "ism-1" state disable
# 8021X
disable 802.1x
config 802.1x auth_mode port_based
config 802.1x auth_protocol local
config 802.1x feap enable
config 802.1x capability ports 1-28 none
config 802.1x auth_parameter ports 1-28 port_control force_auth
config 802.1x auth_parameter ports 1-28 direction both quiet_period 60 tx_period 30 supp_timeout 30 server_timeout 30 max_req 2 reauth_period 3600 enable_reauth disable
# port mirroring
# trusted host
disable trusted_host
# SSL
disable ssl ciphersuite RSA-NULL-MD5 RSA-NULL-SHA1 RSA-DES-SHA1 RSA-3DES-SHA1 DH-RSA-DES-SHA1 DH-RSA-3DES-SHA1 RSA-EXP1024-DES-SHA1
# SSH
disable ssh
config ssh server authfail 2
config ssh server rekey 60min
config ssh server maxsession 1
config ssh server contimeout 120
config ssh authmode password disable
config ssh authmode publickey disable
config ssh authmode hostbased disable
config ssh algorithm 3DES enable
config ssh algorithm MD5 enable
config ssh algorithm SHA1 enable
config ssh algorithm RSA disable
# access authentication control
disable authen_policy
config authen parameter response_timeout 30
config authen parameter attempt 3
create authen server_group tacacs+
create authen server_group radius
create authen_login method_list_name default
config authen_login default method local
create authen_enable method_list_name default
config authen_enable default method none
config authen application console login method_list_name default
config authen application telnet login method_list_name default
config authen application ssh login method_list_name default
config authen application http login method_list_name default
config authen application console enable method_list_name default
config authen application telnet enable method_list_name default
config authen application ssh enable method_list_name default
config authen application http enable method_list_name default
# PPPoE
config pppoe circuit_id_insertion state disable
config pppoe circuit_id_insertion ports 1-28 circuit_id ip state disable
# safeguard_engine
config safeguard_engine state enable
disable command logging
# Discover Trap setting
# QinQ
disable qinq
config qinq ports 1-28 role uni outer_tpid 0x8100 trust_cvid disable vlan_translation disable
disable vlan_trunk
# Ethernet OAM
config ethernet_oam ports 1-28 state disable mode active remote_loopback stop received_remote_loopback ignore
config ethernet_oam ports 1-28 critical_link_event dying_gasp notify_state enable
config ethernet_oam ports 1-28 critical_link_event critical_event notify_state enable
config ethernet_oam ports 1-28 link_monitor error_symbol threshold 1 window 1000 notify_state enable
config ethernet_oam ports 1-28 link_monitor error_frame threshold 1 window 1000 notify_state enable
config ethernet_oam ports 1-28 link_monitor error_frame_seconds threshold 1 window 60000 notify_state enable
config ethernet_oam ports 1-24 link_monitor error_frame_period threshold 1 window 148810 notify_state enable
config ethernet_oam ports 25-28 link_monitor error_frame_period threshold 1 window 1488100 notify_state enable
# DULD
config duld ports 1-28 state disable mode normal discovery_time 5
# port
config ports 1-24 medium_type copper speed auto state enable flow_control disable MDI/MDIX auto learning disable description ""
config ports 25-26 medium_type copper speed auto state enable flow_control disable MDI/MDIX auto learning enable description ""
config ports 25-28 medium_type fiber speed auto state enable flow_control disable learning enable description ""
# LACP
config link_aggregation state disable
config link_aggregation algorithm mac_source
config lacp port_priority 1-28 128 timeout long
config lacp_ports 1-28 mode active
# Limited IP Multicast
create mcast_filter_profile ipv4 profile_id 1 profile_name system
create mcast_filter_profile ipv4 profile_id 2 profile_name 1
config mcast_filter_profile profile_id 1 add 224.0.0.1 224.0.0.2
config mcast_filter_profile profile_id 2 add 239.10.10.1 239.10.10.254
config limited_multicast_addr ports 1-24 ipv4 add profile_id 1
config limited_multicast_addr ports 1-24 ipv4 add profile_id 2
config limited_multicast_addr ports 1-28 ipv4 access permit
config limited_multicast_addr ports 1-28 ipv6 access permit
config max_mcast_group ports 1-28 ipv4 max_group 256
config max_mcast_group ports 1-28 ipv6 max_group 256
# DoS Prevention
config dos_prevention dos_type land_attack action drop state disable
config dos_prevention dos_type blat_attack action drop state disable
config dos_prevention dos_type smurf_attack action drop state disable
config dos_prevention dos_type tcp_null_scan action drop state disable
config dos_prevention dos_type tcp_xmascan action drop state disable
config dos_prevention dos_type tcp_synfin action drop state disable
config dos_prevention dos_type tcp_syn_srcport_less_1024 action drop state enable
disable dos_prevention trap_log
# Flood FDB
disable flood_fdb
command-end
СообщениеДобавлено: Пн дек 09, 2013 11:12
Traffic control. Вот часть вашего конфига:
# traffic control
Вот у меня:
# traffic control
config traffic trap both
config traffic control 1-27 broadcast enable multicast enable unicast disable action shutdown threshold 64 time_interval 5 countdown 5
config traffic control 28 broadcast disable multicast disable unicast disable action drop
Unicast выключен, так как на этом коммутаторе он нерабочий.
Пока не могу сказать точно, но похоже на то, что чем больше портов с линками, тем больше он тормозит.
СообщениеДобавлено: Вт дек 10, 2013 13:38
На 6.03.B006 все также нерабочий Traffic Control.
viewtopic.php?f=2&t=153885&start=360#p885403
Теперь когда на FTP выложили документацию, можно точно сказать, что функция должна блокировать неизвестный unicast, а она срабатывает на любой unicast.
Purpose To configure broadcast / multicast / unknown unicast traffic control.
СообщениеДобавлено: Вт дек 10, 2013 15:41
poofeg писал(а):
Проблема с Traffic control. Ложные срабатывания.
как я понимаю traffic control unicast должен срабатывать только тогда, когда идет неизвестный unicast, а тут известней некуда.
Я отпишу об этом в ШК.
СообщениеДобавлено: Ср дек 11, 2013 08:41
У всех так понимаю не работает loopback detection? На 1228 все было замечетельно
DES-1210-28/ME:5# enable loopdetect
Command: enable loopdetect
Success.
DES-1210-28/ME:5# config loopdetect mode portbase
Command: config loopdetect mode portbase
Success.
DES-1210-28/ME:5# config loopdetect interval_time 1
Command: config loopdetect interval_time 1
Success.
DES-1210-28/ME:5# config loopdetect lbd_recover_time 60
Command: config loopdetect lbd_recover_time 60
Success.
DES-1210-28/ME:5# config loopdetect ports 1-24 state enable
Command: config loopdetect ports 1-24 state enable
Cannot enable STP and LBD on the same port. Please revise it.
Failure!
DES-1210-28/ME:5# sh sw
Command: show switch
Device Type                       : DES-1210-28/ME
MAC Address                       : 90-94-E4-5C-AB-6A
IP Address                        : 10.90.90.90 (Manual)
VLAN Name                         : default
Subnet Mask                       : 255.0.0.0
Default Gateway                   : 0.0.0.0
System Boot Version               : 1.00.003
System Protocol Version           : 2.001.004
System Firmware Version           : 6.03.B007
System Hardware Version           : B2
System Serial Number              : QBM51C7001939
System Name                       :
System Location                   :
System up time                    : 0 days, 0 hrs, 5 min, 1 secs
System Contact                    :
System Time                       : 01/01/2012 00:04:28
STP                               : Disabled
GVRP                              : Disabled
IGMP Snooping                     : Disabled
VLAN Trunk                        : Disabled
802.1X Status                     : Disabled
Telnet                            : Enabled (TCP 23)
Web                               : Enabled (TCP 80)
RMON                              : Disabled
SSH                               : Disabled
Syslog Global State               : Disabled
SSL                               : Disabled
CLI Paging                        : Enabled
Password Encryption State         : Disabled
Зачем заявили эту фичу если она неработает?
СообщениеДобавлено: Ср дек 11, 2013 08:49
Работает, написано же, что LBD и STP на одном порту нельзя, а STP на всех портах по умолчанию включен.
DES-1210-28/ME:5# config stp ports 1-27 state disable
Command: config stp ports 1-27 state disable
Success.
Success.
Success.
DES-1210-28/ME:5# config loopdetect ports 1-27 state enable
Command: config loopdetect ports 1-27 state enable
Success.
DES-1210-28/ME:5# config loopdetect interval_time 2 lbd_recover_time 60
Command: config loopdetect interval_time 2 lbd_recover_time 60
Success.
Success.
СообщениеДобавлено: Ср дек 11, 2013 08:54
Спасибо! вот глупость, stp ведь глобально отключен, значит настройки stp на портах должны игнорироватся. Проверил работает, еще раз спасибо
СообщениеДобавлено: Ср дек 11, 2013 09:50
poofeg
unicast traffic control пофиксят в 20х числах
СообщениеДобавлено: Ср дек 11, 2013 11:04
starchik писал(а):
baton.R писал(а):
poofeg писал(а):
На B036 удивляет загрузка на CPU, трафика меньше 10 мбит/c проходит:
CLI очень неотзывчива.
Полностью поддерживаю...
интересно что у вас такое грузит проц???
на 36 выше 55 даже не поднимается.
Опытным путем выяснил, что похоже грузит его ISM + Limited multicast. До их включения было около 35%, в пиках 50-60%. После включения вечерами под 100% держится.
create mcast_filter_profile ipv4 profile_id 1 profile_name iptv
config mcast_filter_profile profile_id 1 add 225.1.1.0 225.1.1.255
config limited_multicast_addr ports 1-28 ipv4 add profile_id 1
create igmp_snooping multicast_vlan iptv-1 3001
config igmp_snooping multicast_vlan iptv-1 add member_port 1-27
config igmp_snooping multicast_vlan iptv-1 add source_port 28
config igmp_snooping multicast_vlan iptv-1 state enable
config igmp_snooping multicast_vlan_group iptv-1 add ipv4_range 225.1.1.0 225.1.1.255
config igmp_snooping vlan_name iptv-1 state enable fast_leave enable
СообщениеДобавлено: Ср дек 11, 2013 12:14
Вопрос по LBD и STP. Глобально включается только что-то одно, либо LBD либо STP. Правда прошивка стоит 6.00.B043. Решается ли данная проблема в свежих прошивках?
СообщениеДобавлено: Ср дек 11, 2013 13:41
Глобально включатся и то и другое, это на портах одновременно их нельзя включить.
СообщениеДобавлено: Ср дек 11, 2013 22:28
сколько подписок в пике?
СообщениеДобавлено: Чт дек 12, 2013 13:20
config loopdetect disable
# STP
enable stp
config stp priority 16384 instance_id 0
config stp ports 1 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 2 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 3 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 4 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 5 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 6 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 7 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 8 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 9 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 10 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 11 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 12 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 13 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 14 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 15 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 16 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 17 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 18 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 19 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 20 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 21 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 22 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 23 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 24 externalcost 2000000 edge auto restricted_tcn false restricted_role false p2p auto state disable priority 128 fbpdu enable
config stp ports 25 externalcost auto edge auto restricted_tcn false restricted_role false p2p auto state enable priority 128 fbpdu enable
config stp ports 26 externalcost auto edge auto restricted_tcn false restricted_role false p2p auto state enable priority 128 fbpdu enable
config stp ports 27 externalcost auto edge auto restricted_tcn false restricted_role false p2p auto state enable priority 128 fbpdu enable
config stp mst_config_id name 28:10:7b:b8:0a:60 revision_level 0
При попытке включить LBD выдает сообщение: LBD can not enable in STP-enabled mode.!!
Что я делаю не так? Прошивка еще раз повторюсь старая 6.00.B043, прошивать удаленно не рискую.
СообщениеДобавлено: Пт дек 13, 2013 11:58
всем привет.
столкнулся с проблемой iptv
настраиваю ISM VLAN Settings прописываю Group List с которым будем работать.
Настраиваю IP Multecast Profile Settings.
Выставляю Limited Multicast Range Settings на порт.
IPTV работает.
Убираю - работает весь список каналов.
Ставлю на порт пустой range - работает весь список канало.
Ставлю range - с определенным диапазоном - снова работает весь список каналов.
# ISM vlan
create igmp_snooping multicast_vlan "iptv" 101
config igmp_snooping multicast_vlan "iptv" add member_port 23
config igmp_snooping multicast_vlan "iptv" add source_port 25-28
config igmp_snooping multicast_vlan "iptv" state enable
config igmp_snooping multicast_vlan "iptv" replace_source_ip none
config mld_snooping multicast_vlan "iptv" replace_source_ipv6 none
config igmp_snooping multicast_vlan_group "iptv" add ipv4_range 224.1.0.0 239.255.255.255
create mcast_filter_profile ipv4 profile_id 1 profile_name 1
create mcast_filter_profile ipv4 profile_id 10 profile_name 10
create mcast_filter_profile ipv4 profile_id 11 profile_name 11
create mcast_filter_profile ipv4 profile_id 12 profile_name 12
create mcast_filter_profile ipv4 profile_id 20 profile_name 20
config mcast_filter_profile profile_id 10 add 238.1.1.1 238.1.1.254
config mcast_filter_profile profile_id 11 add 233.191.133.3 233.191.133.8
config mcast_filter_profile profile_id 11 add 233.191.133.15 233.191.133.15
config mcast_filter_profile profile_id 11 add 233.191.133.17 233.191.133.17
config mcast_filter_profile profile_id 11 add 233.191.133.66 233.191.133.66
config mcast_filter_profile profile_id 11 add 233.191.133.69 233.191.133.74
config mcast_filter_profile profile_id 11 add 238.1.1.1 238.1.2.254
config mcast_filter_profile profile_id 11 add 239.10.0.3 239.10.0.8
config mcast_filter_profile profile_id 11 add 239.10.0.17 239.10.0.17
config mcast_filter_profile profile_id 11 add 239.10.0.66 239.10.0.66
config mcast_filter_profile profile_id 11 add 239.10.0.69 239.10.0.74
config mcast_filter_profile profile_id 12 add 233.191.133.0 233.191.133.255
config mcast_filter_profile profile_id 12 add 238.1.1.1 238.1.3.254
config mcast_filter_profile profile_id 12 add 239.0.0.0 239.0.0.255
config mcast_filter_profile profile_id 12 add 239.10.0.0 239.10.0.255
config mcast_filter_profile profile_id 20 add 224.1.0.0 239.255.255.255
config limited_multicast_addr ports 1-24 ipv6 access deny
config limited_multicast_addr ports 25-28 ipv6 access permit
# IGMP snooping
config igmp_snooping vlan_name "default" state disable fast_leave disable report_suppression enable
config igmp_snooping querier vlan_name "default" state disable querier_version 2 last_member_query_interval 1 max_response_time 10 query_interval 125 robustness_variable 2
config igmp_snooping vlan_name "control" state disable fast_leave disable report_suppression enable
config igmp_snooping data_driven_learning vlan_name "control" state disable
config igmp_snooping data_driven_learning vlan_name "control" aged_out disable
config igmp_snooping querier vlan_name "control" state disable querier_version 2 last_member_query_interval 1 max_response_time 10 query_interval 125 robustness_variable 2
config igmp_snooping vlan_name "iptv" state enable fast_leave disable report_suppression enable
config igmp_snooping data_driven_learning vlan_name "iptv" state disable
config igmp_snooping data_driven_learning vlan_name "iptv" aged_out disable
config igmp_snooping querier vlan_name "iptv" state disable querier_version 2 last_member_query_interval 1 max_response_time 10 query_interval 125 robustness_variable 2
config router_ports vlan_name "iptv" add 25-28
config igmp_snooping vlan_name "admin" state disable fast_leave disable report_suppression enable
config igmp_snooping querier vlan_name "admin" state disable querier_version 2 last_member_query_interval 1 max_response_time 10 query_interval 125 robustness_variable 2
Может кто подскажет в чем закралась ошибка?
СообщениеДобавлено: Пн дек 16, 2013 18:02
узнал, вместо config multicast filter 1-28 forward должно быть config multicast filter 1-28 filter
но проблема осталась, если на порту нет ренджа, или есть пустой - работает весь список из Group List в ISM.
просто на 3200 можно создать запрещающий рендж, а тут нет такой возможности.
Сейчас этот форум просматривают: Google [Bot] и гости: 45
