Текущее время: Пт окт 30, 2026 06:54
 Заголовок сообщения: Обрывы связи DVG-6004S и DVG-5008SG
СообщениеДобавлено: Вт дек 03, 2013 11:32
Добрый!
Часто происходят обрывы связи между DVG-6004S и DVG-5008SG.
Связка Asterisk + (АТС + DVG-6004S один офис) + DVG-5008SG другой офис - по IPSec
Почитал другие темы, выкладываю логи и настройки cpt/cadence, может там что-то интересное есть.
Куда смотреть, где копать?
5008SG
08:59:18 [12857154] Receive Cmd=1100, ParaLen=5, Para=[Login]
08:59:18 [12857154] Login == Ver(1.02.38.93.9988 2012/09/04 16:26:31) PId(360.DLink.MultiServer.NoPrefix.TR069.drtp) Drv(1.3.2.122) Hw(SP9440S) ==
14:27:16 [13053945] 5: ==4:GetDtmf
14:27:21 [13053996] 5: DTMF Timeout #1
14:27:21 [13053996] 5: End Input Default Route [1]
14:27:21 [13053996] 5: Line DialNum_New [*8]
14:27:21 [13053996] 5: Call Proxy with [*8]
14:27:21 [13053996] 5: ==7:Inviting
14:27:21 [13053996] 5: VoIP CallOut, Invite <sip:*8@192.168.10.20;user=phone>
14:27:21 [13053996] 5: 202=DIALING
14:27:21 [13053996] 5: 202=PROCEEDING
14:27:21 [13053996] 5: 202=CONNECTED
14:27:21 [13053996] 5: Peer=192.168.10.20#11060, PT=0, RecvOnly=0
14:27:21 [13053996] 5: to set 2833 pt, send=101, recv=101
14:27:21 [13053996] 5: RTP[1,1], Peer=192.168.10.20#11060, PT=0/2/1, local=192.168.0.17#0
14:27:21 [13053996] 5: SetTalkMode[1,1]
14:27:21 [13053996] 5: ==14:Talking
14:27:54 [13054331] 5: Get(9)
14:27:55 [13054332] 5: Get(*)
14:27:57 [13054357] 5: Get(2)
14:28:07 [13054461] 5: Get(5)
14:28:28 [13054662] 5: Get(8)
14:28:45 [13054838] 5: Fxs Flash #1
14:28:45 [13054838] 5: SetTalkMode[0,0]
14:28:45 [13054838] 5: 202=ONHOLDING
14:28:45 [13054838] 5: Substatus=4
14:28:45 [13054838] 5: 202=ONHELD
14:28:45 [13054838] 5: Rtp Talk Stop
14:28:45 [13054838] 5: RTP S=4233 R=4160 Lost=0
14:28:45 [13054838] 5: ==3:Idle
14:28:45 [13054838] 5: SetFax(0)=0
14:28:45 [13054839] 5: ==4:GetDtmf
14:28:47 [13054859] 5: 202=DISCONNECT
14:28:47 [13054859] 5: Release Hold Dlg #1
14:28:51 [13054892] 5: DTMF Timeout #1
14:28:51 [13054892] 5: End Input Default Route [1]
14:28:51 [13054892] 5: Line DialNum_New [*8]
14:28:51 [13054892] 5: Call Proxy with [*8]
14:28:51 [13054892] 5: ==7:Inviting
14:28:51 [13054892] 5: VoIP CallOut, Invite <sip:*8@192.168.10.20;user=phone>
14:28:51 [13054892] 5: 202=DIALING
14:28:51 [13054892] 5: 202=PROCEEDING
14:28:51 [13054892] 5: 202=CONNECTED
14:28:51 [13054892] 5: Peer=192.168.10.20#15840, PT=0, RecvOnly=0
14:28:51 [13054892] 5: to set 2833 pt, send=101, recv=101
14:28:51 [13054892] 5: RTP[1,1], Peer=192.168.10.20#15840, PT=0/2/1, local=192.168.0.17#0
14:28:51 [13054892] 5: SetTalkMode[1,1]
14:28:51 [13054892] 5: ==14:Talking
14:29:00 [13054991] 5: Get(2)
14:29:48 [13055465] 5: Get(5)
14:29:49 [13055476] 5: 202=DISCONNECT
14:29:49 [13055476] 5: Rtp Talk Stop
14:29:49 [13055476] 5: RTP S=2934 R=2880 Lost=0
14:29:49 [13055476] 5: Release Active Dlg
14:29:49 [13055476] 5: ==15:PlayBusyTone
14:29:53 [13055517] 5: Fxs Hangup
14:29:53 [13055517] 5: ==3:Idle
14:29:53 [13055517] 5: SetFax(0)=0
6004S
08:58:50 [820534] Receive Cmd=1100, ParaLen=5, Para=[Login]
08:58:50 [820534] Login == Ver(1.02.38.43.9367 2009/08/25 17:45:23) PId(242.DLink.NoPrefix.drtp.vlan) Drv(0.9.5.1.1928) Hw(SA7O4) == 0.6.7-1
14:28:25 [029847] 0: Fxo Ringing
14:28:25 [029848] 0: RingTime(65) First Stop
14:28:29 [029891] 0: RingTime(500) Second Ring
14:28:31 [029912] 0: ### Fxo Get Fsk CallerId [121,], Len=3
14:28:32 [029912] 0: FxoHookOff
14:28:32 [029912] 0: SetInputGain(1)
14:28:32 [029912] 0: SetFxoHookOff()=0, CallerId=121
14:28:32 [029912] 0: ==17:WaitAnswerDeviceOk
14:28:32 [029912] 0: PlayFile(/opt/voc/eEntPhone.pcm)=0
14:28:32 [029912] 0: ==4:GetDtmf
14:28:38 [029976] 0: DTMF Timeout #1
14:28:38 [029976] 0: End Input Default Route [0]
14:28:38 [029976] 0: Line DialNum_New [201]
14:28:38 [029976] 0: Call Proxy with [201]
14:28:38 [029976] 0: ==7:Inviting
14:28:38 [029976] 0: VoIP CallOut, Invite <sip:201@192.168.10.20;user=phone>
14:28:38 [029977] 0: 1300=DIALING
14:28:38 [029980] 0: 1300=PROCEEDING
14:28:38 [029981] 0: 1300=RINGBACK
14:28:38 [029981] 0: ==8:RingBack
14:28:51 [030104] 0: 1300=CONNECTED
14:28:51 [030104] 0: Peer=192.168.10.20:11946, PT=0, RecvOnly=0
14:28:51 [030104] 0: RtpApiTalk[1,1], Peer=192.168.10.20:11946, PT=0, FC=2, NewOOB=1
14:28:51 [030104] 0: ==14:Talking
14:29:48 [030675] 0: Play(5)
14:29:49 [030685] 0: Fxo Detected BTC(0)
14:29:49 [030685] 0: Bye at Talking
14:29:49 [030686] 0: ==15:PlayBusyTone
14:29:49 [030686] DSP_ch0_check=0
14:29:49 [030686] 0: FxoHookOn
14:29:49 [030686] 0: ==3:Idle
14:29:49 [030686] 0: SetInputGain(4)
14:29:49 [030686] 0: SetFax(0)=0
14:29:49 [030687] 0: 1300=DISCONNECT
14:29:49 [030687] 0: Release Old Dlg #2
6004S.png [ 42.48 KiB | Просмотров: 5326 ]
5008SG.png [ 30.55 KiB | Просмотров: 5326 ]
 Заголовок сообщения: Re: Обрывы связи DVG-6004S и DVG-5008SG
СообщениеДобавлено: Чт дек 05, 2013 09:52
У меня та же проблема.
В связке DVG-6004S и DVG-5004S. Тоже канал по VPN IPSEC организован. Обрывы идут через разные промежутки времени, случайным образом.
Прошивка на обоих шлюзах 1.02.38.93
СообщениеДобавлено: Чт дек 05, 2013 10:20
Обнклите профили BTC кроме 3
СообщениеДобавлено: Чт дек 05, 2013 11:08
А по-русски можно для непонятливых :roll:
СообщениеДобавлено: Пт дек 06, 2013 17:38
Присоединяюсь к теме.
Присутствует та же проблема с обрывами в связке 6008S - 5008SG. соединены через лок. сеть.
Не работает так же переадресация вызова (Flash).
Но успешно работет уже более 1,5 лет другая пара 6008S- 5008S.
Заметил разницу лишь в наличии режима "авто" в "Enable Hook Flash Event" в старом 5008S шлюзе.
В новом либо Disable или же RFC или SIP.
СообщениеДобавлено: Пн дек 09, 2013 10:36
Решилась проблема. Перепрошил 6004 на 1.0.2.38.43. С офф сайта данную прошивку не скачать, только с Ftp сервера D-Link.
СообщениеДобавлено: Пн дек 09, 2013 15:17
Свою аналогичную беду, описал здесь viewtopic.php?f=5&t=64923&p=889428#p889428
Должно быть Enable Hook Flash Event - SIP-INFO
СообщениеДобавлено: Вт дек 10, 2013 15:50
Спасибо, заработало, отключил все профили BTC, кроме одного, во всех остальных - 0 оставил.
Разрывы прекратились, flash заработал.
С режимом авто было удобнее)) зря его убрали.
Спасибо!
СообщениеДобавлено: Ср дек 11, 2013 08:09
Разрывы прекратились, ...
Какая версия прошивки у Вас на 6008?
СообщениеДобавлено: Чт дек 12, 2013 12:34
DVG-6008S_1.02.38.95.7z - новую с фтп взял, оба комплекта работают, пользователи сбоев пока не наблюдают.
СообщениеДобавлено: Пн дек 16, 2013 08:24
Поставил указанную прошивку. Ситуация несколько получше, но все равно описанные мной ранее симптомы сохраняются, с тем лишь отличием, что длительность сеанса связи до обрыва стала больше (исходя из наблюдений за логами) ...
Сейчас этот форум просматривают: Google [Bot] и гости: 11
cron
