Текущее время: Вт сен 15, 2026 16:56
Начать новую тему Ответить на тему  [ Сообщений: 593 ]  На страницу Пред.  1 ... 24, 25, 26, 27, 28, 29, 30 ... 40  След.
СообщениеДобавлено: Чт ноя 21, 2013 16:08
Alexey Vitko писал(а):
Уменьшение MTU не помогает? У меня на pptp 54.7/53.7 мбит/с.
Не пробовал.
Вот недавно опять оборвалась связь с маршрутизатором, вот лог:
Jan  1 00:00:13 resident: init lan
Jan  1 00:00:13 resident: start ipoe
Jan  1 00:00:13 start_ip: begin (br0 -> br0)
Jan  1 00:00:13 resident: start ipoe (v718800224) on br0
Jan  1 00:00:13 update_ipfilters: error in params
Jan  1 00:00:14 resident: init wan
Jan  1 00:00:14 kernel: cmd=4
Jan  1 00:00:14 kernel: ag7240_ring_free Freeing at 0x81aba000
Jan  1 00:00:14 kernel: ag7240_ring_free Freeing at 0x81877000
Jan  1 00:00:15 kernel: ag7240_ring_alloc Allocated 1280 at 0x81b4b000
Jan  1 00:00:15 kernel: ag7240_ring_alloc Allocated 4032 at 0x81877000
Jan  1 00:00:15 kernel: Setting PHY...
Jan  1 00:00:15 resident: start ipoe
Jan  1 00:00:15 start_ip: begin (wan1 -> wan1_1)
Jan  1 00:00:15 resident: start ipoe (v717877316) on wan1
Jan  1 00:00:15 telnet-start: begin...
Jan  1 00:00:15 telnet-start: running on 23 port
Jan  1 00:00:15 telnet-start: succes!
Jan  1 00:00:15 printserver-start: begin...
Jan  1 00:00:15 printserver-start: success!
Jan  1 00:00:15 start_sysusers: init ...
Jan  1 00:00:15 start_sysusers: conf not NULL ...
Jan  1 00:00:15 kernel: cmd=2
Jan  1 00:00:15 kernel: cmd=10
Jan  1 00:00:15 kernel: GPIO resident_pid=747
Jan  1 00:00:15 resident: record = action:up;iface:br0;contag:0;ipaddr:192.168.0.1;netmask:255.255.255.0;dns1:;dns2:;
Jan  1 00:00:15 resident: phys_iface br0
Jan  1 00:00:15 test: ip_type = (null)
Jan  1 00:00:15 resident: resident_ipoe_handler - Set default type: ipv4
Jan  1 00:00:15 resident: resident_ipoe_handler - 1
Jan  1 00:00:15 resident: resident_ipoe_handler - 3, name: br0
Jan  1 00:00:15 resident: resident_ipoe_handler - l2:br0, l3:br0, tun:, ip_type:0
Jan  1 00:00:15 resident: resident_ipoe_handler - ipv4
Jan  1 00:00:15 resident: start ip_is_up on iface br0
Jan  1 00:00:15 resident: ip_is_up for link br0
Jan  1 00:00:15 kernel: Port Status c000004
Jan  1 00:00:15 kernel: hcc_params addr 0xbb000108 val 0x6 hcs_params addr 0xbb000104 val 0x10011
Jan  1 00:00:15 resident: start dhcp+dns on br0
Jan  1 00:00:15 FIND_GW: gwif false
Jan  1 00:00:15 FIND_GW: iface wan1
Jan  1 00:00:15 UPNP: ppp0
Jan  1 00:00:15 kernel: 2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (ar7240_ohci)block sizes: ed 64 td 64
Jan  1 00:00:15 kernel: AG7240: enet unit:1 phy:0 is up...Mii 100Mbps full duplex
Jan  1 00:00:15 kernel: AG7240: done cfg2 0x7215 ifctl 0x0 miictrl
Jan  1 00:00:15 dnsmasq[861]: vendor id = "dhcpcd-5.2.10"
Jan  1 00:00:15 triggerPingRespond: OK
Jan  1 00:00:15 resident: record = action:up;iface:wan1;contag:1;ipaddr:10.0.184.24;netmask:255.255.255.0;gateway:10.0.184.1;dns1:87.224.197.1;
Jan  1 00:00:15 resident: phys_iface wan1
Jan  1 00:00:15 resident: resident_ipoe_handler - 2
Jan  1 00:00:15 resident: resident_ipoe_handler - 3, name: wan1_1
Jan  1 00:00:15 resident: resident_ipoe_handler - l2:wan1, l3:wan1_1, tun:wan1_2, ip_type:0
Jan  1 00:00:15 resident: start ip_is_up on iface wan1_1
Jan  1 00:00:15 resident: ip_is_up for link wan1_1
Jan  1 00:00:15 set_dhcp_routes: set routes for iface wan1
Jan  1 00:00:15 kernel: cmd=3
Jan  1 00:00:15 resident: update dns
Jan  1 00:00:15 resident: update rip
Jan  1 00:00:16 resident: update igmpx
Jan  1 00:00:16 resident: stop igmpx
Jan  1 00:00:16 iface: this is wan1
Jan  1 00:00:16 resident: igmpx wan1
Jan  1 00:00:16 resident: update igmpx compiled
Jan  1 00:00:16 resident: update ntpclient
Jan  1 00:00:16 update_ntpclient: server string: ntpd -t -p pool.ntp.org&
Jan  1 06:00:16 start_pppd: tunnel: ifaces/wan1/services/wan1_1/tunnels/wan1_2/
Jan  1 06:00:16 resident: start pppd on wan1_2
Jan  1 06:00:16 resident: stop pppd on wan1_2
Jan  1 06:00:16 kernel: cmd=4
Jan  1 06:00:16 resident: set lock on wan1_2, with "/var/lock/wan1_2.lock"
Jan  1 06:00:16 resident: stopped link(contype:pptp, iface:wan1_2)
Jan  1 06:00:16 start_pppd: get_subnet_class
Jan  1 06:00:16 start_pppd: get_subnet_class  close
Jan  1 06:00:16 start_pppd: check_subnets
Jan  1 06:00:16 start_pppd:  ip1=10.0.0.1 ip2=10.0.184.1 class=1
Jan  1 06:00:16 start_pppd: check_subnets close
Jan  1 06:00:19 triggerPingRespond: OK
Jan  1 06:00:22 resident_phy_link_handler: record = phy:0;status:1
Jan  1 06:00:22 resident_phy_link_handler: phy - 0, status - 1
Jan  1 06:00:23 dnsmasq[913]: vendor id = "MSFT 5.0"
Jan  1 06:00:37 resident_ppp_handler: record = action:trouble;iface:ppp0;status:5;link:wan1_2;
Jan  1 06:00:37 resident: resident_ipoe_handler - Set default type: ipv4
Jan  1 06:00:37 resident: resident_ppp_handler - l2:wan1, l3:wan1_1, tun:wan1_2
Jan  1 06:00:43 resident_ppp_handler: record = action:trouble;iface:ppp0;status:16;link:wan1_2;
Jan  1 06:00:43 resident: resident_ipoe_handler - Set default type: ipv4
Jan  1 06:00:43 resident_ppp_handler: record = action:down;iface:ppp0;status:16;link:wan1_2;
Jan  1 06:00:43 resident: resident_ppp_handler - l2:wan1, l3:wan1_1, tun:wan1_2
Jan  1 06:00:43 ppp_handler: ppp state 1
Jan  1 06:00:43 ppp_handler: Restart pppd
Jan  1 06:00:43 start_pppd: tunnel: ifaces/wan1/services/wan1_1/tunnels/wan1_2/
Jan  1 06:00:43 resident: start pppd on wan1_2
Jan  1 06:00:43 resident: stop pppd on wan1_2
Jan  1 06:00:43 kernel: cmd=4
Jan  1 06:00:43 resident: set lock on wan1_2, with "/var/lock/wan1_2.lock"
Jan  1 06:00:43 resident: stopped link(contype:pptp, iface:wan1_2)
Jan  1 06:00:43 start_pppd: get_subnet_class
Jan  1 06:00:43 start_pppd: get_subnet_class  close
Jan  1 06:00:43 start_pppd: check_subnets
Jan  1 06:00:43 start_pppd:  ip1=10.0.0.1 ip2=10.0.184.1 class=1
Jan  1 06:00:43 start_pppd: check_subnets close
Jan  1 06:00:46 resident_ppp_handler: record = action:up;iface:ppp0;link:wan1_2;ipaddr:188.73.149.28;netmask:255.255.255.255;gateway:172.30.0.1;dns1:87.224.197.1;dns2:87.224.213.1;
Jan  1 06:00:46 resident: resident_ipoe_handler - Set default type: ipv4
Jan  1 06:00:46 resident: resident_ppp_handler - l2:wan1, l3:wan1_1, tun:wan1_2
Jan  1 06:00:46 kernel: cmd=3
Jan  1 06:00:47 resident: update dns
Jan  1 06:00:47 resident: update rip
Jan  1 06:00:47 resident: update ntpclient
Jan  1 06:00:47 update_ntpclient: server string: ntpd -t -p pool.ntp.org&
Jan  1 06:00:47 triggerPingRespond: OK
Jan  1 06:00:50 dnsmasq[963]: vendor id = "MSFT 5.0"
Jan  1 06:01:00 kernel: Priletela cmd=0x89f3
Jan  1 06:01:03 kernel: Priletela cmd=0x89f3
https://phateev.ru
СообщениеДобавлено: Чт ноя 21, 2013 18:01
А почему бы прошивку 2.0.2 не выложить на ftp? :?:
СообщениеДобавлено: Чт ноя 21, 2013 18:21
Спид-тест показал нормальную скорость для тарифа "от 55" - 57,5/57,6
http://www.speedtest.net/my-result/3116096492
В целом, прошивка стабильнее ветки 1.4.
Из минусов:
- NatLoopback так и не починили. (Поделитесь информацией, как правила IPTABLES сохранить в роутере, что бы каждый раз не возюкаться с ними.)
- Иногда сам перезагружаться начинает. Системы нет: может каждый день в одно и то же время, а может и неделю жить без сбоя.
- Обрывы связи по WIFI встречаются только на одном wifi-чипе (причем на всех планшетах, где этот чип стоит) на моем роутере. Приходится перезапускать на планшете wifi-службу. Эти же планшеты на DIR-320, DIR-320 NRU, DAP-1160 работают без вылетов. С другими Wifi-клиентами (смартфонами, нетбуком и продвинутым телефоном) проблем не замечал.
- Нет исходников прошивки, что не правомерно по GNU/GPL
- Нет в WebUI поддержки подключения дисков NTFS-3g, EXT3. (Мне это, правда, не актуально.)
Понятно, что если разработчики будут угождать всем сразу, то все в прошивку не влезет.
Дайте мануал, как ручками по telnet исправить и сохранить в памяти устройства нужные настройки.
PS: Кому нужно подключать NTFS-жесткие диски, могу дать команду.
СообщениеДобавлено: Пт ноя 22, 2013 10:09
был бы благодарен!
самим не вышло(
СообщениеДобавлено: Пт ноя 22, 2013 14:28
aucoin писал(а):
был бы благодарен!
самим не вышло(
1. Подключить диск.
2. Зайти по телнет на роутер, ввести логин и пароль как на админку web-интерфейса.
3. Выполнить команду (стандартную для Linux)
Для NTFS-диска с единственным разделом.
mkdir /tmp/mnt/usb1_1
modprobe fuse
mount.ntfs-3g -o rw,umask=0,locale=ru_RU.UTF-8 /dev/sda1 /tmp/mnt/usb1_1
Действовать будет до перезагрузки аппарата.
Из глюков замечено, что до перезагрузки аппарата вставить другой носитель не удастся.
Диск с Ext3 разделом роутер подключил сам.
Так что прогресс в функционале прошивки, так сказать, на лицо.
СообщениеДобавлено: Пт ноя 22, 2013 14:52
хм..проделал..только ничего не поменялось - как увидеть диск-то?)
в веб-морде долго думает..потом пишет - USB device - NO
СообщениеДобавлено: Пт ноя 22, 2013 14:57
Nov 22 15:49:12 ntfs-3g[1181]: Version 2010.1.16 integrated FUSE 27
Nov 22 15:49:12 ntfs-3g[1181]: Mounted /dev/sda1 (Read-Write, label "FreeAgent Drive", NTFS 3.1)
Nov 22 15:49:12 ntfs-3g[1181]: Cmdline options: rw,umask=0,locale=ru_RU.UTF-8
Nov 22 15:49:12 ntfs-3g[1181]: Mount options: rw,silent,allow_other,nonempty,default_permissions,relatime,fsname=/dev/sda1
Nov 22 15:49:12 ntfs-3g[1181]: Global ownership and permissions enforced
СообщениеДобавлено: Пт ноя 22, 2013 16:51
Welcome to
     _______          ___     __  ____   _  _   ___
    |  ___  \        |   |   |__||    \ | || | /  /
    | |   | ||  ___  |   |__  __ |     \| || |/  /
    | |___| || |___| |      ||  || |\     ||     \
    |_______/        |______||__||_| \____||_|\___\
                     = Building Networks for People =
BusyBox v1.19.2 (2013-09-19 10:31:06 MSK) built-in shell (ash)
Enter 'help' for a list of built-in commands.
$ mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro)
proc on /proc type proc (rw,nodiratime)
sysfs on /sys type sysfs (rw)
ramfs on /tmp type ramfs (rw,noatime)
devpts on /dev/pts type devpts (rw)
usbfs on /proc/bus/usb type usbfs (rw)
$ mkdir /tmp/mnt/usb1_1
$ modprobe fuse
$ mount.ntfs-3g -o rw,umask=0,locale=ru_RU.UTF-8 /dev/sda1 /tmp/mnt/usb1_1
WARNING: Deficient Linux kernel detected. Some driver features are
         not available (swap file on NTFS, boot from NTFS by LILO), and
         unmount is not safe unless it's made sure the ntfs-3g process
         naturally terminates after calling 'umount'. If you wish this
         message to disappear then you should upgrade to at least kernel
         version 2.6.20, or request help from your distribution to fix
         the kernel problem. The below web page has more information:
         http://ntfs-3g.org/support.html#fuse26
$ mount
/dev/sda1 on /tmp/mnt/usb1_1 type fuse (rw,user_id=0,group_id=0,default_permissions,allow_other)
$ exit
После этого он становится доступным в файловом обозревателе WebUI.
В логах роутера
Jan  1 00:00:27 kernel: usb 1-1: new high speed USB device using ar7240-ehci and address 2
Jan  1 00:00:27 kernel: ehci-9130: hub_port_reset
Jan  1 00:00:27 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Jan  1 00:00:32 kernel:   Vendor: JetFlash  Model: Transcend 4GB     Rev: 8.07
Jan  1 00:00:32 kernel:   Type:   Direct-Access                      ANSI SCSI revision: 02
Jan  1 00:00:32 kernel: SCSI device sda: 7843840 512-byte hdwr sectors (4016 MB)
Jan  1 00:00:32 kernel: sda: Write Protect is off
Jan  1 00:00:32 kernel: sda: assuming drive cache: write through
Jan  1 00:00:32 kernel:  sda: sda1
Jan  1 00:00:32 kernel: sd 0:0:0:0: Attached scsi removable disk sda
Jan  1 00:00:32 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jan  1 00:00:51 login[969]: root login on 'pts/0'
Jan  1 00:01:04 kernel: Priletela cmd=0x89f3
Jan  1 00:01:33 kernel: fuse init (API version 7.3)
Jan  1 00:02:10 ntfs-3g[1106]: Version 2010.1.16 integrated FUSE 27
Jan  1 00:02:10 ntfs-3g[1106]: Mounted /dev/sda1 (Read-Write, label "", NTFS 3.1)
Jan  1 00:02:10 ntfs-3g[1106]: Cmdline options: rw,umask=0,locale=ru_RU.UTF-8
Jan  1 00:02:10 ntfs-3g[1106]: Mount options: rw,silent,allow_other,nonempty,default_permissions,relatime,fsname=/dev/sda1
Jan  1 00:02:10 ntfs-3g[1106]: Global ownership and permissions enforced
Jan  1 00:02:21 kernel: Priletela cmd=0x89f3
СообщениеДобавлено: Пт ноя 22, 2013 16:55
все именно так! но не видит зараза никак((
попробую другой диск включить..
СообщениеДобавлено: Пт ноя 22, 2013 16:57
Сообщения из телнета запостите сюда.
Полностью все, что выводит терминал.
СообщениеДобавлено: Пт ноя 22, 2013 16:58
Welcome to
$ mount
$ modprobe fuse
$ mount
ons,allow_other)
СообщениеДобавлено: Пт ноя 22, 2013 17:01
другой диск-таки подцепился (код выше)
но через минуту - отвалился
файлы даже посмотреть не успел
СообщениеДобавлено: Пт ноя 22, 2013 17:30
На файловой системе случаем сжатие не используется?
Сжатие старых файлов не было?
Как ни крути, а родные для Linux форматы работают нормально.
СообщениеДобавлено: Пт ноя 22, 2013 18:26
Вот опять обрыв связи с роутером. Вскоре связь восстанавливается, но интернет не работает, хотя, показывает, что вроде связь с интернетом есть. Лог:
eJan  1 00:00:13 resident: init lan
Jan  1 00:00:13 resident: init wan
Jan  1 00:00:13 kernel: cmd=4
Jan  1 00:00:13 kernel: ag7240_ring_free Freeing at 0x81abd000
Jan  1 00:00:13 kernel: ag7240_ring_free Freeing at 0x81878000
Jan  1 00:00:15 kernel: ag7240_ring_alloc Allocated 1280 at 0x81b4e000
Jan  1 00:00:15 kernel: ag7240_ring_alloc Allocated 4032 at 0x81878000
Jan  1 00:00:15 resident: update igmpx
Jan  1 00:00:15 resident: stop igmpx
Jan  1 00:00:15 iface: this is wan1
Jan  1 00:00:15 resident: igmpx wan1
Jan  1 06:00:18 dnsmasq[869]: vendor id = "dhcpcd-5.2.10"
Jan  1 06:00:22 resident_ppp_handler: record = action:up;iface:ppp0;link:wan1_2;ipaddr:188.73.149.28;netmask:255.255.255.255;gateway:172.30.0.1;dns1:87.224.197.1;dns2:87.224.213.1;
Jan  1 06:00:22 resident: resident_ipoe_handler - Set default type: ipv4
Jan  1 06:00:22 resident: resident_ppp_handler - l2:wan1, l3:wan1_1, tun:wan1_2
Jan  1 06:00:22 kernel: cmd=3
Jan  1 06:00:22 resident: update dns
Jan  1 06:00:22 resident: update rip
Jan  1 06:00:22 resident: update ntpclient
Jan  1 06:00:22 update_ntpclient: server string: ntpd -t -p pool.ntp.org&
Jan  1 06:00:22 triggerPingRespond: OK
Jan  1 06:01:43 kernel: Priletela cmd=0x89f3
Jan  1 06:01:47 kernel: Priletela cmd=0x89f3
Jan  1 06:01:52 kernel: Priletela cmd=0x89f3
Jan  1 06:01:55 kernel: Priletela cmd=0x89f3
https://phateev.ru
СообщениеДобавлено: Пт ноя 22, 2013 18:59
точно нет
вопрос - если я подключу диск с ext3 - dlna сработает?
цель - подключить накопитель и с него смотреть фильмы по сети
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 51
