Текущее время: Вс ноя 01, 2026 13:17
 Заголовок сообщения: DI-604
СообщениеДобавлено: Сб ноя 05, 2005 06:47
уважаемая тех поддержка:
есть сервер 2003 SP1 ENG, на нем пожнят RAS как PPPoE так и PPTP
железка ни по тому ни по тому протоколу не конктит, тут же есть сервер FreeBSD на него цепляется без проблем...
Current Firmware Version: V3.11
Firmware Date: Fri, Jun 10 2005
лог PPPTP:
Friday June 10, 2005 01:24:48 Restarted by 192.168.1.2
Friday June 10, 2005 01:24:54 DOD:triggered internally
Friday June 10, 2005 01:24:54 start to dial-up
Friday June 10, 2005 01:24:54 PPTP:PNS=192.168.0.100
Friday June 10, 2005 01:24:56 PPP1: TX LCP Request
Friday June 10, 2005 01:24:56 PPP1: RX LCP Request
Friday June 10, 2005 01:24:56 PPP1: TX LCP Reject
Friday June 10, 2005 01:24:56 PPP1: RX LCP ACK
Friday June 10, 2005 01:24:56 LCP1: terminate request
Friday June 10, 2005 01:24:57 PPP1: TX(0) LCP Request
Friday June 10, 2005 01:24:56 PPP1: TX(0) LCP Request
Friday June 10, 2005 01:24:58 PPP1: TX(1) LCP Request
Friday June 10, 2005 01:24:59 PPP1: TX(2) LCP Request
Friday June 10, 2005 01:25:00 PPP1: TX(3) LCP Request
Friday June 10, 2005 01:25:01 PPP1: TX(4) LCP Request
Friday June 10, 2005 01:25:03 PPP1: TX(5) LCP Request
Friday June 10, 2005 01:25:03 PPP1: closed
лог PPPoE:
WAN Type: PPP over Ethernet (V3.11)
Display time: Friday June 10, 2005 01:26:43
Friday June 10, 2005 01:26:33 Restarted by 192.168.1.2
Friday June 10, 2005 01:26:40 DOD:triggered internally
Friday June 10, 2005 01:26:40 start to dial-up
Friday June 10, 2005 01:26:40 PADT sent
Friday June 10, 2005 01:26:42 PADI sent
Friday June 10, 2005 01:26:42 PADO recv 0016 HOMENET
Friday June 10, 2005 01:26:42 PADR sent
Friday June 10, 2005 01:26:42 PADS recv 0002 4100
Friday June 10, 2005 01:26:44 PPP3: RX LCP Request
Friday June 10, 2005 01:26:44 PPP3: TX LCP Reject
Friday June 10, 2005 01:26:44 PPP3: RX LCP ACK
Friday June 10, 2005 01:26:44 LCP3: terminate request
Friday June 10, 2005 01:26:44 PADT recv
Friday June 10, 2005 01:26:46 PPP3: TX(0) LCP Request
Friday June 10, 2005 01:26:47 PPP3: TX(1) LCP Request
Friday June 10, 2005 01:26:48 PPP3: TX(2) LCP Request
Friday June 10, 2005 01:26:50 PPP3: TX(3) LCP Request
Friday June 10, 2005 01:26:51 PPP3: TX(4) LCP Request
Friday June 10, 2005 01:26:53 PPP3: TX(5) LCP Request
Friday June 10, 2005 01:26:53 PPP3: closed
вот вопрос- что за байда?????
СообщениеДобавлено: Пн ноя 07, 2005 10:48
Скорее всего дело в виндовом сервере раз к Free коннектиться
СообщениеДобавлено: Пн ноя 07, 2005 13:37
отменная откарячка простите за слово.......
вот только почемуто я к этому серверу конектюсь и по PPPoE и по PPTP
а кроме меня еще 10 человек.........
так что проблемма в вашей железке
не говоря про то что я FREE пачил в свое время когда этот машрутизатор первый раз законектился........
жду конструктива господа
СообщениеДобавлено: Пн ноя 07, 2005 14:48
По логам ничего не видно - нужны все настройки
СообщениеДобавлено: Пн ноя 07, 2005 16:14
какие именно???
СообщениеДобавлено: Пн ноя 07, 2005 16:37
PPTP конечно
СообщениеДобавлено: Вт ноя 08, 2005 09:21
Я думаю дело в используемых протоколах аутентификации и шифрования. DI-604 поддерживает аутентификацию по pap, chap, ms-chapv1 и не поддерживает шифрование MPPE. Какие параметры у Вас используются на Windows сервере? Настройте на сервере использование MPPE и ms-chapv2 как опциональную возможность.
СообщениеДобавлено: Вт ноя 08, 2005 16:43
сие не помогло.....
завтра на работе поговорю с людьми кто лучше знает где что менять под вынь може удумаю чего
на теущий момент не получилось....
но спасибо за участие...........
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 187
