Текущее время: Чт авг 27, 2026 10:25
 Заголовок сообщения: Состояние Fan на DGS-3100 по snmp
СообщениеДобавлено: Чт июл 18, 2013 16:00
Подскажите mib, по которому можно узнать состояние вентиляторов на DGS-3100.
Спасибо.
 Заголовок сообщения: Re: Состояние Fan на DGS-3100 по snmp
СообщениеДобавлено: Ср июл 24, 2013 12:15
.1.3.6.1.4.1.171.10.94.89.89.83.1.1.1.3.67109249 - OID
DLINK-3100-HWENVIROMENT (env_mib.mib) - MIB
rlEnvMonFanState OBJECT-TYPE
SYNTAX RlEnvMonState
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"The mandatory state of the fan being instrumented."
::= { rlEnvMonFanStatusEntry 3 }
RlEnvMonState ::= TEXTUAL-CONVENTION
STATUS current
DESCRIPTION
"Represents the state of a device being monitored.
Valid values are:
normal(1): the environment is good, such as low
temperature.
warning(2): the environment is bad, such as temperature
above normal operation range but not too
high.
critical(3): the environment is very bad, such as
temperature much higher than normal
operation limit.
shutdown(4): the environment is the worst, the system
should be shutdown immediately.
notPresent(5): the environmental monitor is not present,
such as temperature sensors do not exist.
notFunctioning(6): the environmental monitor does not
function properly, such as a temperature
sensor generates a abnormal data like
1000 C.
СообщениеДобавлено: Ср июл 24, 2013 15:43
Спасибо!
