Текущее время: Ср сен 30, 2026 15:50
 Заголовок сообщения: Температура DGS-3120-24SC
СообщениеДобавлено: Ср июл 10, 2013 10:05
Всем здрасте.
Имеем 3 DGS-3120-24SC rev.A2 установленные в разных местах, но примерно в одно время.
2 из них периодически зависают и рабобта восстанавливается только если выключить, дать немного постоять и включить.
В логах:
249   2013-07-10 05:24:53 INFO(6) Temperature Sensor:1 recovers to normal state.
                                  (current temperature:45)
248   2013-07-10 05:23:52 WARN(4) Temperature Sensor:1 enter alarm state.(curren
                                  t temperature:56)
247   2013-07-10 02:35:42 INFO(6) Temperature Sensor:1 recovers to normal state.
                                  (current temperature:46)
246   2013-07-10 02:34:42 WARN(4) Temperature Sensor:1 enter alarm state.(curren
                                  t temperature:57)
245   2013-07-10 02:27:39 INFO(6) Temperature Sensor:1 recovers to normal state.
244   2013-07-10 02:26:38 WARN(4) Temperature Sensor:1 enter alarm state.(curren
                                  t temperature:58)
243   2013-07-10 01:34:16 INFO(6) Temperature Sensor:1 recovers to normal state.
                                  (current temperature:47)
242   2013-07-10 01:33:16 WARN(4) Temperature Sensor:1 enter alarm state.(curren
                                  t temperature:58)
241   2013-07-10 01:28:14 INFO(6) Temperature Sensor:1 recovers to normal state.
240   2013-07-10 01:27:13 WARN(4) Temperature Sensor:1 enter alarm state.(curren
                                  t temperature:58)
239   2013-07-10 00:13:43 INFO(6) Temperature Sensor:1 recovers to normal state.
238   2013-07-10 00:12:42 WARN(4) Temperature Sensor:1 enter alarm state.(curren
                                  t temperature:59)
237   2013-07-09 22:20:55 INFO(6) Temperature Sensor:1 recovers to normal state.
                                  (current temperature:48)
236   2013-07-09 22:19:55 WARN(4) Temperature Sensor:1 enter alarm state.(curren
                                  t temperature:60)
235   2013-07-09 22:08:50 INFO(6) Temperature Sensor:1 recovers to normal state.
234   2013-07-09 22:06:49 WARN(4) Temperature Sensor:1 enter alarm state.(curren
                                  t temperature:60)
233   2013-07-09 21:17:29 INFO(6) Temperature Sensor:1 recovers to normal state.
                                  (current temperature:49)
232   2013-07-09 21:16:28 WARN(4) Temperature Sensor:1 enter alarm state.(curren
                                  t temperature:61)
231   2013-07-09 16:44:34 INFO(6) Temperature Sensor:1 recovers to normal state.
230   2013-07-09 16:43:34 WARN(4) Temperature Sensor:1 enter alarm state.(curren
                                  t temperature:61)
229   2013-07-09 16:32:29 INFO(6) Temperature Sensor:1 recovers to normal state.
Днем на свитче в среднем температура 40-44, температура воздуха около 30:
#sh env
Command: show environment
Temperature Trap State     :  Enabled
Temperature Log State      :  Enabled
Fan Trap State             :  Enabled
Power Trap State           :  Enabled
Internal Power      : Active
External Power      : Fail
Right Fan 1         : Speed High (5500 RPM)
Right Fan 2         : Speed High (5500 RPM)
Current Temperature(Celsius) :   44
Fan High Temperature Threshold(Celsius)     :    40
Fan Low Temperature Threshold(Celsius)      :    35
High Warning Temperature Threshold(Celsius) :    50
Low Warning Temperature Threshold(Celsius)  :    11
Прошивки 3.00.B026 (основная) или 3.01.B003 - разницы в поведении нет.
Трафика пока через эти коммутаторы почти нет (<100M в пиках).
Смущают скачки температуры в ночное время - никаких оснований для такого поведения нет. Влан управления в отдельном влане и не маршрутизируется с пользовательским трафиком. Загрузка CPU коммутаторов 18-20% стабильно в любое время суток.
Какие будут рекомендации?
 Заголовок сообщения: Re: Температура DGS-3120-24SC
СообщениеДобавлено: Ср июл 10, 2013 10:40
3.01.B003 Где вы взяли такую прошивку?
СообщениеДобавлено: Ср июл 10, 2013 10:54
Киевский делинк подогнал.
По теме комментарии будут?
СообщениеДобавлено: Ср июл 10, 2013 14:14
Коммутаторы перегреваются, какие еще комментарии необходимы?
Вам следует подумать о кондиционировании помещения ли дополнительной вентиляции.
СообщениеДобавлено: Ср июл 10, 2013 18:11
Ночью перегреваются, когда днем не наблюдается проблем?
Эти коммутаторы стоят на техэтажах в ящиках. Кроме этих трех стоят еще десятка 2 и никаких проблем, температура на них стабильно 37-42 градусах. Записи в лог о перегреве почти исключительно ночью - это шутка? Ночью температура воздуха порядка 17-20 градусов.
СообщениеДобавлено: Вс июл 14, 2013 00:45
Помните о том, что температура воздуха на улице и на тех этаже это далеко не одно и то же.
У меня на узлах стоят датчики температуры и постоянно рисуется график её изменений. Так вот узлы находящиеся на тех. этажах показывают пик температуры не в полдень, а как раз ближе к ночи - с 18:00 до 23:00. В то же время самая низкая температура не в 5-6 утра, а с 8 до 11.
Тоесть тех этаж в составе здания выполняет естественную для себя функцию конденсатора тепловой энергии.
Раз пошла речь о перегреве - какая температура для боевого агрегатора района 3120 является критичной? Может стоит задуматься как минимум о автоматическом включении принудительной вентиляции?
СообщениеДобавлено: Пн июл 15, 2013 17:44
Стоят еще более 2-х десятков таких зверей (A1 и A2 ревизий) и даже в лог не ругаются на температуру.
Температуру, конечно помониторим, но странно, все равно.
СообщениеДобавлено: Сб дек 21, 2013 11:29
Заменили sfp и проблема перестала быть актуальной.
СообщениеДобавлено: Пн дек 23, 2013 10:23
passer
Если не трудно - поделитесь с сообществом - с каких и на какие меняли.
СообщениеДобавлено: Пн дек 23, 2013 18:16
И то и то были китайцы. Какие именно - уже не помню, просто зашел на форум и увидел, что не оставил решение своей проблемы.
Сейчас этот форум просматривают: Google [Bot] и гости: 110
