Текущее время: Чт окт 01, 2026 08:24
 Заголовок сообщения: dgs6604 - dgs 3420-28SC и LLDP
СообщениеДобавлено: Пн июн 17, 2013 12:28
Имеем простую состыковку DGS6604{eth3.17}->DGS3420-28SC{23}.
На 6604 конфиг.
loopback-detection
loopback-detection interval-time 60
loopback-detection mode vlan-based
lldp run
cpu-protect type dhcpv6 pps 1
cpu-protect type icmpv6-ndp pps 1
cpu-protect type icmpv6-other pps 1
cpu-protect type snmp pps 180
cpu-protect safeguard threshold 85 80
Порт отписан:
interface eth3.17
description CWDM_C04-02-01
trunk allowed-vlan 201-204
trunk allowed-vlan 214-217
trunk allowed-vlan 226-229
trunk allowed-vlan 400
trunk allowed-vlan 405-407
trunk allowed-vlan 840
trunk allowed-vlan 2111
При вводе:
sho lldp neighbor interface 3.17
Remote Entities Count : 1
Entity 1
Chassis ID Subtype : MAC Address
Chassis ID : B8-A3-86-D6-90-00
Port ID Subtype : MAC Address
Port ID : B8-A3-86-D6-91-16
Port Description : D-Link DGS-3420-28SC R1.00.0
24 Port 23 on Unit 1
System Name : UDK-C04-02-01
System Description : Gigabit Ethernet Switch
System Capabilities Supported : Repeater, Bridge
System Capabilities Enabled : Repeater, Bridge
Management Address Count : 0
Port VLAN ID : 1
PPVID Entries Count : 0
VLAN Name Entries Count : 0
Protocol ID Entries Count : 0
MAC/PHY Configuration/Status : (None)
Power Via MDI : (None)
Link Aggregation : (None)
Maximum Frame Size : 0
Unknown TLVs Count : 0
LLDP-MED capabilities : (See Detail)
Extended power via MDI : (See Detail)
Network policy : (See Detail)
Inventory Management : (See Detail)
Данные имеются.
Заходим на 3420.
show config effective
disable gvrp
disable asymmetric_vlan
disable vlan_trunk
config port_vlan 1-28 gvrp_state disable ingress_checking enable acceptable_frame admit_all pvid 1
enable lldp
config lldp tx_delay 2
config lldp message_tx_interval 30
config lldp message_tx_hold_multiplier 4
config lldp reinit_delay 2
config lldp notification_interval 5
config lldp ports 1-28 notification disable
config lldp ports 1-28 admin_status tx_and_rx
config lldp ports 1-28 basic_tlvs port_description system_name system_description system_capabilities enable
show lldp remote_ports 23
Remote Entities Count : 0
Где искать правду?
Как заставить из видеть друг друга?
Пробовал уже включить все из доступного на 3420 в разрезе lldp.
 Заголовок сообщения: Re: dgs6604 - dgs 3420-28SC и LLDP
СообщениеДобавлено: Пн июн 17, 2013 12:45
Какие версии прошивок на коммутаторах?
СообщениеДобавлено: Пн июн 17, 2013 12:47
6604
Bootloader Version :1.00.010
Firmware Version :3.00.B083
3420-28SC
Boot PROM Version : Build 1.00.006
Firmware Version : Build 1.00.024
СообщениеДобавлено: Пн июн 17, 2013 13:04
Также если проследить до домового коммутатора:
DGS6604{eth3.17}->DGS3420-28SC{23}->DES3200-28
То можно увидеть, что домовой коммутатор видит по LLDP 3420-28, а 3420-28 не видит.
СообщениеДобавлено: Пн июн 17, 2013 13:16
Вам для начала сюда
viewtopic.php?f=2&t=92700
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 98
