Текущее время: Чт окт 01, 2026 11:24
 Заголовок сообщения: Потерял мультикаст
СообщениеДобавлено: Пт июн 14, 2013 18:21
Всем доброго дня.
Потерял мультикаст на DES-3200-28. Ревизия B1.
Настроен ISM влан.
enable igmp_snooping
config igmp_snooping data_driven_learning max_learned_entry 56
enable igmp_snooping multicast_vlan
create igmp_snooping multicast_vlan IPTV 10
config igmp_snooping multicast_vlan IPTV state enable
config igmp_snooping multicast_vlan IPTV replace_source_ip 10.10.1.101
config igmp_snooping multicast_vlan IPTV add member_port 1-24
config igmp_snooping multicast_vlan IPTV add source_port 25-28
config igmp_snooping querier all query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 2
config igmp_snooping vlan_name IPTV fast_leave enable
config igmp_snooping data_driven_learning vlan_name IPTV aged_out disable
DES-3200-28:4#show igmp_snooping multicast_vlan IPTV
Command: show igmp_snooping multicast_vlan IPTV
Multicast VLAN Global State : Enabled
VID                 : 10      VLAN Name: IPTV
Member Ports        : 1-24
Tagged Member Ports :
Source Ports        : 25-28
Untagged Source Ports :
Status              : Enabled
Replace Source IP   : 10.10.1.101
Priority            : None
Querier и версия IGMP указаны верно
DES-3200-28:4#show igmp_snooping vlan IPTV
Command: show igmp_snooping vlan IPTV
 IGMP Snooping Global State            : Enabled
 Multicast Router Only                 : Disabled
 Data Driven Learning Max Entries      : 56
 VLAN  Name                    : IPTV
 Query Interval                : 125
 Max Response Time             : 10
 Robustness Value              : 2
 Last Member Query Interval    : 1
 Querier State                 : Disabled
 Querier Role                  : Non-Querier
 Querier IP                    : 10.10.1.1
 Querier Expiry Time           : 1 secs
 State                         : Enabled
 Fast Leave                    : Enabled
 Version                       : 2
 Data Driven Learning Aged Out : Disabled
Порт подключен к группе
DES-3200-28:4#show igmp_snooping host
Command: show igmp_snooping host
 VLAN ID        Group         Port No     IGMP Host
10        239.195.32.1       14         10.10.1.101
10        239.255.255.250    14         10.10.1.101
 Total Entries :  2
DES-3200-28:4#show igmp_snooping group vlan IPTV
Command: show igmp_snooping group vlan IPTV
 Source/Group      : NULL/239.195.32.1
 VLAN Name/VID     : IPTV/10
 Reports           : 10
 Member Ports      : 14
 Router Ports      : 25
 Up time           : 801
 Expire Time       : 232
 Filter Mode       : EXCLUDE
 Source/Group      : NULL/239.255.255.250
 Reports           : 4655
 Member Ports      : 14
 Router Ports      : 25
 Up time           : 125473
 Expire Time       : 237
 Total Entries in VLAN IPTV: 2
За 25м портом еще парочка таких же коммутаторов (один из них ревизии C1) в транке и дальше коммутатор аггрегации. Так вот на него не приходят IGMP запросы на группы. Не могу понять почему.
Вообще на сколько я понял, IGMP должны ходить мультикастом в данном случае только в ISM влане (vlan10). Куда он могу подеваться? И как его искать? Голову уже сломал :(
 Заголовок сообщения: Re: Потерял мультикаст
СообщениеДобавлено: Пт июн 14, 2013 18:47
Интересно. На C1 ревизии которая стоит на пути, была выключена опция
config igmp_snooping multicast_vlan forward_unmatched disable
Включил и все побежало.
СообщениеДобавлено: Пн июн 17, 2013 09:53
На промежуточном C1 у Вас какая прошивка и настройки используются?
СообщениеДобавлено: Пн июн 17, 2013 10:41
Версия
Boot PROM Version          : Build 4.00.002
Firmware Version           : Build 4.00.024
Hardware Version           : C1
Настройка сейчас такая (пропускает мультикаст)
# IGMP_MULTICAST_VLAN
config igmp_snooping multicast_vlan forward_unmatched enable
config igmp_snooping multicast_vlan IPTV state enable replace_source_ip 10.10.1.102
config igmp_snooping multicast_vlan IPTV add member_port 1,3
# IGMP_SNOOPING
config igmp_snooping vlan_name IPTV fast_leave enable report_suppression enable
config igmp_snooping querier vlan_name IPTV query_interval 125  max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 2
config igmp_snooping data_driven_learning vlan_name IPTV expiry_time 260 state enable aged_out disable
При выключенном параметре IGMP не проходил по транку через этот коммутатор
СообщениеДобавлено: Пн июн 17, 2013 10:53
На DES-3200 C1 прошивку нужно обновить до актуальной версии отсюда: http://forum.dlink.ru/viewtopic.php?f=2&t=92700
Эта проблема уже фиксилась в ней и сейчас включать Forward unmatched не нужно.
СообщениеДобавлено: Пн июн 17, 2013 10:56
Спасибо. Какие проблемы ожидать в связи с включением этой опции?
СообщениеДобавлено: Пн июн 17, 2013 12:11
По сути фильтрация с ней не будет полноценно работать, поэтому рекомендую все же обновиться.
СообщениеДобавлено: Пн июн 17, 2013 12:28
Понятно. Не могли бы ткнуть носом как удаленно обновить прошивки без потери конфигов и контроля над устройствами по сети?
СообщениеДобавлено: Пн июн 17, 2013 13:22
просто делаешь прошивку командой download через телнет
при тебе будет идти процесс в процентах
когда будет готово делаешь save и reboot
и все, конфиг не потеряется
2008-2015г. компания Экстрим Интернет. Технический директор/Главный системный администратор.
2015-по н.в. компания "Подряд". Инженер сети ШПД
Сейчас этот форум просматривают: Google [Bot] и гости: 92
