Текущее время: Пн авг 31, 2026 16:56
 Заголовок сообщения: DIR 615 M1 1.0.9 firmware problem with PPTP
СообщениеДобавлено: Вт апр 09, 2013 13:13
I have been unable to set up a Dynamic PPTP connection using a DIR 615 M1 with 1.0.9 firmware. The routing table shows incorrect entries with the PPTP destination showing as 0.0.0.0 and the correct PPTP destination listed under eth1.
Комментарий к файлу: Routing table
routing-table-for-failed-PP.jpg [ 39 KiB | Просмотров: 5852 ]
Комментарий к файлу: PPTP setup
VPN.jpg [ 49.33 KiB | Просмотров: 5852 ]
 Заголовок сообщения: Re: DIR 615 M1 1.0.9 firmware problem with PPTP
СообщениеДобавлено: Вт апр 09, 2013 14:12
Do you have any problem with it?
Полезные настройки
СообщениеДобавлено: Вт апр 09, 2013 14:47
Yes. I need to use PPTP to access a VPN site in the UK. I have an old DIR 300 as backup and this works without problems using the same settings. Is there a problem with the 1.0.9 firmware with PPTP connections? Non PPTP connections works OK.
СообщениеДобавлено: Вт апр 09, 2013 15:08
No. May be you have wrong information about encryption or authentication algorithm? Did you restore your device to factory settings after upgrade the firmware? Please, show an image of network statistics.
Полезные настройки
СообщениеДобавлено: Вт апр 09, 2013 16:06
The encryption or authentication algorithms are those specified by the VPN supplier - and work correctly with a DIR 300. I have restored the factory settings. Please explain why the router table seems to have incorrect entries.
Комментарий к файлу: Network statistics page
network-statistics-for-fail.jpg [ 43.18 KiB | Просмотров: 5840 ]
СообщениеДобавлено: Ср апр 10, 2013 16:49
Others have had the same problem with PPTP.
http://www.bormotuhi.net/showthread.php?p=344975
Can anyone say that they have been able to setup a PPTP connection with this router ?
And if so what configuration did you use ?
СообщениеДобавлено: Пн апр 29, 2013 13:24
I am still not able to do a PPTP connection using this router. There are a few further pointers that seen relevant. One is that the router claims that is connected to the VPN server (on the connection status line) despite there being no functional connection. The other pointer is that immediately after setting up the router to do the PPTP connection an internet connection does become available for what seems to be a few hundred packets of data - after which the connection is frozen. Checking the connection with a DIR 130 with the same settings shows no problem with the PPTP connection. Israeli DLink support have been able to reproduce the problem but have no solution so far.
СообщениеДобавлено: Пн апр 29, 2013 14:07
Please, contact with us by e-mail and we will provide you a new firmware.
support@dlink.ru
Полезные настройки
СообщениеДобавлено: Вт апр 30, 2013 11:35
Thanks - I have sent two emails but have had no response. Do you need more information ?
СообщениеДобавлено: Вт апр 30, 2013 12:34
I answered to you.
Полезные настройки
СообщениеДобавлено: Вт апр 30, 2013 14:30
Alexey
Thanks for the file - but it does not load correctly.
About half way through the firmware update process the router reports
"Device is Ready" and the download finishes.
After this and doing a factory reset the router is unchanged - still
showing firmware to be 1.0.9 and behaving in the same way as previously -
i.e. it says that it has a PPTP connection but after a few packets of data
are received the connection freezes. Also, the router table remains
incorrect.
I have repeated the download and resets with no change.
СообщениеДобавлено: Вт апр 30, 2013 15:01
Set the static addresses for your network adapter like this:
IP 192.168.0.7
mask 255.255.255.0
gateway 192.168.0.1
primary dns 8.8.8.8
Then you need to connect to router by cable. Switch power off and hold "reset" button. Turn power on and hold the button for 10 seconds. Release the button and open 192.168.0.1 in Firefox browser. Push "Open" and find firmware. Then use Upload button.
Полезные настройки
СообщениеДобавлено: Вт апр 30, 2013 16:29
I was able to do the firmware update to 1.0.13 using the backdoor method you described - and then did a factory reset.
However, the only difference now is that a few more packets of data are passed via the PPTP connection before the connection freezes. Previously I could only manage to logon to the BBC iPlayer TV site before the connection froze - but now I get a little further with the error message of not being in the UK (so the connection was not actually using my UK VPN). I note also that the router connection table is still wrong. After a power on reset the router behaves in the same way with the ability to pass just a few packets of data and then freezing. I should emphasize that using exactly the same configuration settings on my DIR 130 I have no trouble accessing the iPlayer TV site from Israel. My PPTP connection is using MPPE 128 bit and MSChap V2 authentication.
СообщениеДобавлено: Ср май 01, 2013 14:49
Alexey
I have sent you an email with my UK PPTP logon details so that you can see if the connection works for you. Please say if it works OK.
СообщениеДобавлено: Пн май 06, 2013 09:37
All works without problem. Maybe we will talk only by e-mail?
Полезные настройки
Сейчас этот форум просматривают: Google [Bot] и гости: 38
