Текущее время: Ср сен 30, 2026 20:06
 Заголовок сообщения: DGS-3312SR и LACP
СообщениеДобавлено: Пн апр 08, 2013 13:52
Здравствуйте.
Никак не получается на коммутаторе D-Link DGS-3312SR включить lacp.
2 и 12 порты. 12 в дауне пока.
create link_aggregation group_id 2
config link_aggregation algorithm ip_source_dest
config link_aggregation group_id 2 master_port 15:2 ports 15:2,15:12 state enable
Fail!
DGS-3312SR:4#sh ports
Command: show ports
Port    Port      Settings               Connection             Address
        State     Speed/Duplex/FlowCtrl  Speed/Duplex/FlowCtrl  Learning
15:1    Enabled   Auto/Disabled           1000M/Full/None        Enabled
15:2    Enabled   Auto/Enabled            1000M/Full/None        Enabled
15:3    Enabled   Auto/Disabled           1000M/Full/None        Enabled
15:4    Enabled   Auto/Disabled           100M/Full/None         Enabled
15:5    Enabled   Auto/Disabled           1000M/Full/None        Enabled
15:6    Enabled   Auto/Disabled           1000M/Full/None        Enabled
15:7    Enabled   Auto/Disabled           1000M/Full/None        Enabled
15:8    Enabled   Auto/Disabled           1000M/Full/None        Enabled
15:9    Enabled   Auto/Disabled           Empty                  Enabled
15:10   Enabled   Auto/Disabled           1000M/Full/None        Enabled
15:11   Enabled   Auto/Disabled           1000M/Full/None        Enabled
15:12   Enabled   Auto/Enabled            Link Down              Enabled
DGS-3312SR:4#show link_aggregation group_id 2
Command: show link_aggregation group_id 2
Group ID      : 2
Type          : TRUNK
Master Port   : 15:2
Member Port   : 15:2,15:12
Active Port   :
Status        : Disabled
Flooding Port : X
DGS-3312SR:4#show switch
Command: show switch
Device Type       : DGS-3312SR Gigabit-Ethernet Switch
Module 1 Type     : DEM-340MG 4-port mini-GBIC (SFP) module
Module 2 Type     : DEM-340MG 4-port mini-GBIC (SFP) module
Unit ID           : 15
MAC Address       : 00-1E-58
IP Address        : 172.21.  (Manual)
VLAN Name         : vlan
Subnet Mask       : 255.255.255.0
Default Gateway   : 172.21.
Boot PROM Version : Build 2.00.003
Firmware Version  : Build 3.60-S21
Hardware Version  : 0A2
Device S/N        :
System Name       :
System Location   :
System Contact    :
Spanning Tree     : Disabled
GVRP              : Disabled
IGMP Snooping     : Disabled
TELNET            : Enabled (TCP 23)
WEB               : Disabled
RMON              : Disabled
RIP               : Disabled
DVMRP             : Disabled
PIM-DM            : Disabled
OSPF              : Disabled
Может я неправильно включаю Lacp?
Как быть?
 Заголовок сообщения: Re: DGS-3312SR и LACP
СообщениеДобавлено: Пн апр 08, 2013 14:30
Добрый день. Настройки на 2 и 12 портах совпадают?
Бигаров Руслан.
СообщениеДобавлено: Пн апр 08, 2013 15:58
Вы имеете ввиду вланы?
Да, вланы идентичны.
Какие ещё настройки надо смотреть?
Настраивал lacp на разных коммутаторах - никогда проблем не было, а тут такое.
СообщениеДобавлено: Пн апр 08, 2013 16:17
Пришлите, пожалуйста, конфигурационный файл мне на почту.
Бигаров Руслан.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 84
